Question about Toshiba Satellite A135 Notebook
Toshiba Satellite touchpad sensitivity
How do I adjust the pressure on the touchpad; slightest touch and an action takes place without warning!
  • Anonymous Dec 12, 2008
    touch pad moves all crazy
    An expert who has written 2 tips or uploaded 1 video tip.
  • 7 Answers
If you go to :
  1. control panel
  2. hardware and sound
  3. mouse
  4. device settings
  5. click the "setings" button
  6. then go to sensitivity
i hope this works as i have a toshiba a200 laptop. while you're there you can toggle palm check in case you lean on the touchpad.
Posted on Aug 06, 2008
Gateway the touch pad not function why?
Adjusting the touchpad sensitivity on a Gateway laptop lets you fix and prevent annoying touchpad problems.
Often the touchpad is accidentally brushed while typing, which causes the cursor to move out of place.
Or you may find yourself having to tap too hard or too often on the touchpad to open windows and programs.
These problems can be fixed by simply adjusting the touchpad's sensitivity settings.
Click the "Start" button and double-click "Control Panel."
Double-click "Hardware & Sound" and choose "Mouse" to open the mouse properties box.
Choose the "Device Settings" tab. Highlight "Synaptic Touchpad" in the Devices box by clicking on it. Click the "Settings" button underneath the Devices box.
Choose "Sensitivity" in the properties settings box.
Click "PalmCheck" to adjust the sensitivity of the touchpad to accidental brushes against the pad while typing, which causes the cursor to move.
Click and hold the pointer to adjust the setting on the sensitivity scale.
Click "Touch Sensitivity" to adjust the sensitivity of the touchpad to tapping.
A higher rating on the scale means less tapping pressure will be needed.
Click "OK" to save your touchpad settings.
May 15, 2013 | Acer Aspire Computers & Internet
How do i adjust the sensitivity of my touch pad for my Toshiba laptop PSLB8U-05202F
1.Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
2.Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
3.Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
4.Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
5.Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
Sep 14, 2011 | Toshiba Satellite L305-S5908 Notebook
The cursor jumps from line or field on its own...I could typing away and before I know it, the cursor has moved to another field or to the middle of another word! real pain in the ****
You will probably want to adjust the pressure sensitivity on your laptop's touch pad to alleviate this problem. If you have Windows, enter the control panel from the start menu.
1. START > Control Panel
2. Find Mouse or Pointing Devices.
3. Enter the Pointing Devices Control Panel.
Things can vary a bit in this section. So you should look for anything that deals with Pressure settings or Pointing Settings. One setting should be labeled "Touch Sensitivity." This setting controls how much pressure is required on the touch pad.
-If you move the setting lower (or move the slider to the left) this decreases the sensitivity. It is harder to accidently move the cursor if you brush the touchpad while typing.
-If you move the setting higher (or move the slider to the right) this increases the sensitivity. It is easier to accidently move the cursor if you brush the touchpad while typing.
(Note that in some configurations, these are opposite - left to increase senstivity and right to decrease sensitivity).
Depending on your laptop there may also be a setting labeled Touchpad Pressure. It's a setting that resgisters if you are accidently leaning on the touch pad. It's designed to reduce the chance of accidental clicks or motions. This setting is generally controlled the same way the Touchpad Sensitivity setting is controlled, through left-right sliders. I've found that keeping the touchpad sensitivity low makes it easier to avoid accidental cursor motions. I also keep the Pressure setting relatively high as well. One thing you'll note that if you adjust these settings to far into one extreme or the other, you will have difficulty using your touchpad. Fine tune these two setting until you achieve the results you want.
Dec 05, 2010 | Computers & Internet
We have a Toshiba A135 laptop with Windows 7 Home Premium. I would like to adjust the sensitivity of the touchpad, but cannot find how do make this adjustment. Please help.
Hi kipspal2,
You can adjust the sensitivity of the touchpad according to your requirement. Just follow the instructions below:
1) Click on Start.
2) Go to Control Panel
3) Double Click on 'Mouse'.
4) The Mouse Properties dialogue box pops up.
5) In the pointer options tab, under Motion, there will be a slider under 'Select a pointer speed'.
6) Move the slider with your mouse towards 'Slow'. Now you will notice that when you move your mouse, the sensitivity has decreased.
7) Apply the settings and Click OK.
Hope this information was helpful.
Thank you for using fixya,
Arun Zac
Nov 27, 2010 | Toshiba Satellite A135 Notebook
Asus touch pad too sensitive
There should be settings in the touch pad software on your machine or in the task bar that you can directly access to change all manner of personal idiosyncrasies related to HID. (Human interface device) Try also going into the control panel and looking for input devices, mouse, touchpad and adjusting the settings from within there.
Mar 11, 2010 | ASUS Computers & Internet
T-43 Laptop - Screen freezes, mouse freezes, all functions stop..
The Touchpad is pressure sensitive, you can program the Touchpad's functionality. Go to Control Panel, click, to open Mouse Properties. Click the Device settings (block), select the Settings button; after the Touchpad Wizard appear! "View the (left) "Select an item" pane, and click to start the Touchpad's actions." Follow all the instructions carefully. I hope this Fix it
Jan 21, 2010 | IBM ThinkPad T43 Notebook
Toshiba satellite touchpad much too sensitive - pointer jumps all over
You should have a Program loaded from Toshiba to configure the TouchPad including sensitivity.
Dec 10, 2009 | Toshiba Satellite A105 Notebook
I have a toshiba satellite pro and ever since i bought it whenever I go onto the internet after a few moments the screen will minimise itself. it normally does it if i click the mouse near to the edges of...
Aug 26, 2009 | Microsoft Windows XP Home Edition
Touchscreen sensitivity
Just change the mouse speed and acceleration.
Jun 12, 2009 | Toshiba Satellite A20 Satellite A25 Series...
Touchpad Sensitivity - Toshiba Satellite M55-S329: My cursor has recently begun to jump around like crazy when I type. I believe it's probably because my hands are brushing over the touchpad, which is...
If you have any dust or food particles in the cracks between the touchpad and the laptop, be sure to clean those out with a can of pressurized air. Those will sometimes cause the touchpad to think you are touching it on two places at once, which will make the touchpad jump all over the place.
Feb 26, 2009 | Toshiba Satellite M55-S329 Notebook
Toshiba Satellite A135 Notebook Logo
541 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
