Question about Toshiba 65H84 65" Rear Projection HDTV
Problem with toshiba 65H84
When switched on power light comes on then flashes slowly. No picture, no sound
  • xedwinx Feb 03, 2009
    I have same problem, I tried this solution but did not work. Any other solutions???
    Please help.
  • 927 Answers
Good Day, mowattearl;
The most common with this TOS TV is the failure of the convergence IC's, but rebooting, resetting first, unplug TV from wall for 3-5 minutes then plug back into wall. The "conv" IC's are STK's, large black devices mounted to a large heat sink on the verticle.
Good luck, big IRISH.
Posted on Jul 24, 2008
Blinking red light no picture
No picture or do u have a blue (or some other color) screen? And the blinking red light, is that the indicator light down by the power button that is blinking? I have the same tv and very similar problem, i have a blue screen and the red indicator light is blinking. If you have gotten ur problem fixed I would love to know how, or vise versa if I get mine fixed.
Sep 11, 2011 | Toshiba 65H84 65" Rear Projection HDTV
The unit will not turn on. A red light blinds and that it. No picture and no sound
I have the same problem on the same tv. If you have fixed it by now please inform me how, I would really appreciate it. And vice versa if I get mine fixed.
Aug 08, 2011 | Toshiba 65H84 65" Rear Projection HDTV
The picture on my Toshiba 65H84 - 65 Inch Theaterwide HD Projection Television is going dark. Is there a bulb that I can replace? If so, how?
This model 65H84 is a rear projection type with three picture tubes. And if I am not mistaken is around 10 years old. So, if it is at least 10 years old then the picture tubes are getting weak and burned out, therefore not producing a bright enough picture. Typical with rear projection with age on them.
Jun 28, 2011 | Televison & Video
Screen black. Power light on unit flashes red slowly. Power light on switching adaptor power supply flashed green slowly.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
May 03, 2011 | Cameras
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
TV turns off and on when hot
Check both the fan and the air entry area and make sure that both are free from dust and debris. The fan may be tuning too slowly to properly move air around. A quick vacuum of the area should help.
If that fils to correct the problem, please update this and we'll start looking at potential parts failures.
Thanks,
Dan
Jul 11, 2010 | Toshiba 65H84 65" Rear Projection HDTV
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
Not powering up
Do you hear clicking inside the TV when you switch on?
Does the red power or green timer light flash on and off?
May 28, 2009 | Toshiba 42H81 42" Rear Projection...
No picture--help
I'm assuming you are trying to view an input, like a DVD recorder or Cable/Satellite box?
If so then you need to check the connections. This problem usually occurs when there's a loose scart.
Feb 19, 2009 | Toshiba 65H84 65" Rear Projection HDTV
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
Toshiba 65H84 65" Rear Projection HDTV Logo
435 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
