Question about Sony Playstation 3 (PS3) Console
Flashing screen I have hooked up my ps3 into a dell plasma tv with a hdmi cord but when i turn it on the tv flashes between black and a normal working console i heard from someone lse that had this problem that leaving it on for a while you straighten it out but i did that for 5 hours last night and it still does it i've tried other cables and nothing fixes the problem any suggestions?
    Problem Solver:
  • 7 Answers
It sounds like its set for s video at 480p for analog tube tv's you need to hook up to tube tv and change in settings for hdmi
Posted on Mar 28, 2010
I have a LG Plasma 50 inch TV, I have Roku hooked in HDMI 1, when I turn on TV the screen is black out with invalid format flashing across screen, how do I fix it.?
you will have to go into the roku settings and change the resolution to one that works with your tv
if your roku has rca jacks hook it to that temporally so you can see a picture on your tv to change the setting
Nov 13, 2017 | LG Televison & Video
Ressetig the ps3 on a new tv
Sounds like the Tv your using is faulty. Its could have hardware failure. You did say it PS3 was working on hdmi on a plasma. If your using the default hdmi cable that came with ps3 that also can be faulty. I have always had problems with the default hdmi so i bought a new one that was not SONY and it works beautifully. Another thing the black screen with green is a video cable or graphics issue.
Does this tv work if there is no ps3 connected? if so i recommend using the standard PS3 Component AV Cable. see if that will let you reset your ps3.
Jun 24, 2014 | Sony Playstation 3 (PS3) Console
When I switch my tv to the HDMI input it appears to be normal for a few seconds but the screen stays black and I get a thin pink line running horizontally across the bottom right corner of the screen then...
You did not mention what you are connecting with HDMI but I have had problems with my PS3 and it is copy protection related. On a PS3, you have to connect it to HDMI1 otherwise some BlurRay movies will not play.
You might have a bad HDMI cable. I have heard the quality of cable does not matter these days but I still have had issues with the really cheap cables. I still do not buy the really expensive HDMI cables though.
Aug 29, 2011 | Zenith Z50PX2D 50 in. Plasma HDTV
I get a black screen when I turn on my PS3. When I turn it on I do get the normal start up sound but the screen is black. The power cord is plugged in, the HDMI cord works (I switched 3 different cords...
Your PS3 may not be in HD mode. When you turn on your PS3 hold down the button until you hear a series of beeps. This will switch the PS3 to work with your HDMI. Now turn off and turn on the PS3 normally and you should have video.
I may be wring on the steps so check your manual or reference:
http://manuals.playstation.net/document/en/ps3/current/index.html
May 18, 2011 | Sony PlayStation® 3 (80GB) Console
I had my ps3 hooked up to the plasma with a hdmi cord, my tv went out n i had the setting of the ps3 to hdmi, now idk how to change it to where i can hook it up with the original cord(red yellow white).....
To go from HD to composite you have to do while in HD mode do to the fact that the PS3 will only automatically detect HD and not composite. You can try doing the composit hook-up and then start in SAFE MODE.
SAFE MODE:
1. Place you finger on the on/off sensor leave it their until you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Good Luck!
Feb 21, 2011 | Sony Playstation 3 (PS3) Console
PS3 problems At home I have a new samsung hd 1080p TV that I normally use for my PS3. I will be in a hotel outa town for the next couple of days and I wanna watch a movie using my PS3. In my...
I had the same problem, stuck in a hotel room for 2 days. When I held down the button, next time I turned it on, I got the same prompt with using HDMI output, said yes, and screen went black. However, a screen then came up asking if I could see the image or not, but it has a 30 second time limit before it saves those setting, you have to click "No" on this screen, and it will drop the resolution to 780p instead of 1080 and it should work! Make sure you're paying attention so you don't miss the screen!
Nov 13, 2010 | Sony Playstation 3 (PS3) Console
Hdmi cable with plasma... no back to a normal tv
hi there,
you need to do a grapics reset on the PS3
easy to do, just turn the console of from the rear.
place your finger on the power button on the front while doing this hit the power switch on the back.
The console will beep 3 times and reset its self and take you to the grapics setup.
dont worry you will not loose any data doing this.
hope this helps
alex
Apr 06, 2009 | Sony Playstation 3 (PS3) Console
Hdmi wont work and it used to how do i reset the plasma
You have to set up your PS3 to use the HDMI connection. what you need to do is hook up both the component and HDMI to your tv and turn your PS3 on, the you have to go to "Settings" and find the video output settings (Sorry, i don't have the PS3 on so I can't check out exactly where to go) and select HDMI.
Your screen will go black and you have to switch over to the HDMI on your tv and select ok on your PS3
Feb 17, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Jul 23, 2008 | Televison & Video
Sony Playstation 3 (PS3) Console Logo
106 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
