Question about KitchenAid KGST307 Gas Kitchen Range
Setting the clock
I have just purchased a used stove, and am trying to set the clock. I've followed the manual instructions to the letter, and nothing happens. I'm connected properly, the display is working, the burners, etc. are working, but still can't set the clock, and also can't turn on the "surface" light. I've even pressed the "control lock" button, and the "cancel" button, but I only get the occasional 3-tone signal, and then nothing happens.
Any suggestions?
  • kwsvictoria Jul 24, 2008
    I did the un-plug thing a couple of times, and both times the control panel lit up with all the bells and whistles, but no clock pictures. The instructions say to press the Clock/Set button, which I did, but nothing happens. No tones sound, and nothing changes. Sigh.....
    Most other buttons work fine.
  • 93 Answers
Remove the plug from the socket for a few minutes. Then plug it back. Does the clock control blicking? look at the pictures on the control as a whole.
Do you see anything like a table clock? press it once, then press the numeric pad or up and down arrow button depending on the model you have. press enter or start if set correctly.
Posted on Jul 24, 2008
  • Femi Omojogberun Jul 24, 2008
    Ok,replaced the control overlay instead if not work, it shows that relay board that controling time was bad. Needs to be replaced
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
How to set timer
I found a pdf of the manual for your stove. See the link below to download the pdf.
If you press the button that looks like a bell under the clock you can use + an - keys to set the minutes for a reminder timer that won't turn off the oven.
After turning the thermostat to the temp you want and function knob to the setting you want set the cooking time as follows.
You press the button that looks like steam coming off a pan below the clock for 1/2 second .
Then use + an - keys to set the minutes. Every 12 minutes will make a new segment light up on the inside ring so the numbers corospond to hours on the inside ring.
When the time is where you want it, wait 6 to 10 seconds and the cooking and timer will start.
Smeg A42 5 Instruction Manual
Jun 05, 2014 | Smeg A42-5 Dual Fuel (Electric and Gas)...
I wana fix the time for this stove
tahts should help
Nov 06, 2012 | Kitchen Ranges
Icant change the time on my stoves HAP0050 ELECTRIC OVEN,any ideas Thanks
In most cases. Simply press the appropriate button for the feature you want to access, and then use the "+" and "-" buttons to increase and decrease the number values. For example, to set the clock, press the "Clock" button, followed by the "Time/Temp" button; use the "+" and "-" buttons to set the clock to the desired time. When you are finished, press the "Start" button to save your setting. Use the same process to set the oven temperature and timer.
Read more: Whirlpool Stove Instructions '
Mar 19, 2011 | Ovens
Miele H 5240 B CS oven Purchased E & S Trading, Ashburton, 1 October, 2010 When I press the arrows and the OKin between, about 70% of the time nothing happens. Sometimes wetting my fingers seems...
Hi the is a two year g/tee on all Miele appliances. I would contact Miele and book a service call. The appliance most likely requires new clock. Modified clocks are available which allow you to change setting via control knobs rather than keypad.
Jan 16, 2011 | Miele Novotronic H350-2B Electric Single...
I am unable to set my clock on the Magic Chef MCM1110 W/B Microwave Oven I just purchased following the Instruction Manual
Typically all you have to do to set the clock is to press the Clock button, enter the time, and press Clock again. However on some models, clock set is accessed through the main menu, by pressing the Help button and following the prompts.
Aug 17, 2010 | Magic Chef MCD1110ST Microwave Oven
How do I set my Sentry talking clock?
Many Sentry product manuals can be down loaded from the following URL
The instructions for Sentry CR104 is located at the following URL
This may be unrelated to your problem, but
I have noticed sometimes the instructions tell you to use the ADJUST key.
If that does not work try the SET key sometimes it will work instead of the ADJUST key.
Mar 12, 2010 | Sentry CR104 Clock Radio
Cannot reset clock on my electric stove after a power failure!
Unplug the stove for 10 minutes, then plug it back in.
This should resolve your problem...
Nov 20, 2008 | General Electric Stove/Oven/Range Chrome...
KitchenAid KGST307 Gas Kitchen Range Logo
196 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
