LG 42LH50 42 in. HDTV LCD Logo
Christi Huizenga Posted on Feb 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The sound from the amp does not match up with the video on the TV. We have 2- 25' RCA jacks, 1 to the "Video" and 1 to the "Audio-R" in the "AV IN 1" section. Are our cables to long? Thanks, Chad
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Apr 03, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
2491
Points
16
The 42" LG 42H50 does not have any audio outputs ports only inputs.
Anonymous
Level 3:
  • Master 699 Answers
  • Posted on Feb 13, 2011
Anonymous
Master
Level 3:
Answers
699
Questions
Helped
218543
Points
2363
If those are rca jacks on tv being used to go to amp ?
Are you sure they are not input TO tv rather than outputs ?
YOu must use the AV out connectors on TV to go to amp.
25 inces is fine.
Please dont forget to vote if you liked my answer
thanks
Need to know step by step instructions 0n how to record from my tv to my vcr including plug ins
I am assuming you wish to record what is playing on your TV to the VCR and not just asking how to record on a VCR, which is much easier, just put your cable from your antenna/cable box on the vcr and pick a channel from antenna or use channel 3 or 4 for cable box and press record. To watch TV with or without recording connect VCR output (Either coax or Composite) to same type input on the TV. If this is your question, then comment if you have trouble and I will get more detailed. This is a good video on doing this: https://www.youtube.com/watch?v=zgb7uoLIaQE
So if you want to record what is playing on your TV to the VCR, you must have a TV OUT on the TV. The only types of TV OUT that I have seen that would match to a VCR are either coax or RCA.
If the TV OUT is coax just connect one end of coax cable to the TV OUT on the TV and connect the other end to the Antenna/Cable IN on the VCR. Play the program on the TV and record on the VCR usually on either channel 3 or 4. Unless you have the VCR set up to play on another TV you will just have to use trial and error (record on one channel and playback on TV to see if you recorded anything, is so that is right channel, if not, then try the other one.) to find out which.
So, on to recording the signal from a TV on a VCR. If the TV OUT is Composite (RCA jacks, yellow, red, and white or black) you will need some RCA (Composite) cables. They may be labeled patch cords or dubbing cables at the store. That is if you can find them. I don't know if they are still being sold as a video accessory. If not just use RCA audio cords.
There will be two plugs on each end for mono sound recording and three for stereo sound recording. You will have to have audio or L & R audio, and video OUT on your TV and audio or L & R audio, and video IN on your VCR. Plug the yellow cable end into the video OUT on your TV and the yellow on the other end into the video IN on your VCR. Do the same for audio. I have always seen yellow as the color for video, but audio is sometimes white and sometimes black, and in stereo audio right is usually red, but left can be either white or black. With a little luck the cable plugs and TV and VCR IN & OUT jacks will match in color. If sound is mono the is nothing to get wrong. If audio is stereo the worst that can happen is the sound for right side will play on the left and sound for the left side will play on the right. As long as red is used for right it should be correct.
If there is only one set of input jacks on the VCR, the VCR input will probably need to be set to 'Line In'. If there are multiple sets of input jacks they should be labeled 'Input 1', 'Input 2', etc.. The VCR input setting will need to be set to the input you plugged the RCA cables into. The jacks you plugged cable ends into should be labeled. The setting for input on the VCR and TV should match the label on that device.
Now turn on the TV and put it on what you want to record. Do this before it comes on if you want to record all of it. Having set the VCR on 'Line In' or on the correct input, just press record on the VCR. Leave the TV on while recording.
As long as the TV is on and going to play something you want to record, you can set the timer on the VCR to record it, but instead of setting a channel you will choose either 'Line In' or the input number you are using.
This should always work to record a show on the TV when the signal is coming in through a coax cable from an antenna or cable box. But there are some TVs that only send that signal to the TV Out jacks. So if you are watching something from another source, like another VCR, a DVD player, or a video camera on TV on the TV and try to record that you will only record the incoming signal from the antenna or cable box.
In that case just connect the other VCR, the DVD or the camera to the recording VCR and play it on the one using the OUT jacks and record on the VCR using the Input jacks. This should make a better recording too. You can see what is happening by using the OUT jacks on the VCR and connecting the cable from them to the IN jacks on the TV and selecting the 'Line In' or 'Input 1, 2 etc.' matching where you plugged the cable from the VCR in on the TV.
Summary:
Device playing what you want to record is the: SOURCE
1. Using RCA dubbing cables plug them into the OUT jacks on the source and the IN jacks on the VCR.
2. Set the VCR input to the setting that matches the label on the jacks in which the RCA cables are plugged.
3. Play the program on the source and press record on the VCR to begin to record it.
Note: Leave the TV on if that is the source.
If you have any questions I assume I will get a notification if you leave a comment and I will be happy to answer.
Hope this helps. Good Luck!,
Ron
INSTRUCTIONS FOR (EMERSON DVD/VCR) MODEL EWD2004
it sounds that your tv has no audio/video input jack so you don't have place to insert the rca cable. what you need is an RF converter where you can hooked up the 3 cable wire for audio( L/R), video.then the other end you need to use an RF plug with wire that you can plug into the RF tuner of the tv and the other end to the RF converter.hope this can helped thanks for using the fixya.
I do not know what color to use the RCA jack in
RCA Jacks are usually white & red for left and right speakers and yellow for video. If you don't have a three piece set - then they are probably just for speakers and its one for right speaker and the other for left speaker.
On the back of the tv, the RCA jacks plug into the incoming area - with the red & white going to the speakers right and left and the yellow to the video jack. Then you need to choose the input method on the tv menu set up that matches in the one you chose on the tv. Examples of input methods are AUX, Antenna One, Antenna two, ect. With the tv turned on - keep changing the choice of input until you find the one that gives you a picture.
Cannnot hear the music from video
you have not stated whether you want to hear the sound on TV or Stereo Receiver..
Here are 2 possible solution for both alternative..
1. thru TV
Your VCR has either 2x Audio (red and whitw ) and 1x Video output (yellow) RCA jacks or a SCART jack on the back side..
you need to connect all 3xRCA jacks to your TV's respective input.(or SCART ) than you will manage to see both video and hear the sound by selecting the VIDEO input on the TV .
2.thru RECEIVER
** you need to connect "Audio Output " RCA jacks of your VCR
** to "AUX input " or "DVD " OR "Any input" of your receiver ( except Phone )
** than just switch to respective mode on
RECEIVER corresponding your RCA connection...
There you go..VCR sound on the
Receiver..
*** pls remember you can connect VCR to either TV or Receiver to listen audio ,not both..the yellow RCA video output connection always goes to TV..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote for us to continue f
or Helping out the Community :)
Trying to set up digital set top box to our old LG tv model no CF-21F80KX . Have red white and yellow on set top box and 2 white and 2 yellow on back of tv. Kerrie
The RED and White RCA jacks on the set top box are for Right and Left channel audio to go into the TV Video 1 or Video 2 input jacks of the TV. The Yellow jack is for the Video, that will go into the Yellow jack on the TV Video 1 or Video 2. If you want to use Video 1 INPUT, then all 3 jacks (RED, WHITE, YELLOW) will be use. Just match the color, they should be grouped together per each set of input on the TV.
I hope I explain it well enough.
What do i need to play back recorded video onto my t.v from my sony handycam dcr-trv260...i have s cord, usb cord, yellow rca jack??? so what else do i need!!!...nothing i have tried has worked???please...
You can connect this camera to a suitable TV with either the S-Video lead or the RCA lead, but only if the TV is equipped with the appropriate inputs. The S-Video lead looks like a tiny DIN plug, and the RCA jacks are three separate plugs coloured red, white and yellow (yellow is composite video, red and white are left and right stereo sound). If you use S-Video you will also need to make a separate connection for sound (using the red and white RCA connectors). Sometimes the TV sound input is a mini stereo jack, and you will need a Y connector to adapt the two RCA connectors to the mini jack, or maybe the camera's sound output is also by mini jack, in which case you may need the reverse Y connector. Most TVs have some way of accepting a video signal, but you may already be using it for a DVD player or the like.
If your TV lacks these connections, you may be able to use an adapter. In the UK, most recent TVs have a SCART (Peritel) socket, which takes a big plug with 21 connections on it. You can get an adapter to fit that socket that will allow you to plug in the RCA connectors and maybe the S-video too. I don't know what country you are in, or what adapters are available in your country if it isn't the UK.
Once you have made the connections, you must select the appropriate input on your TV. The other possible hiccup is setting the camera to the right video standard, NTSC or PAL., to match that used by your TV.
The USB cord will not connect your camera to the TV.
Can I connect this player to a hdtv?or do I need additional cables because it is only playing in black and white
Basically -yes; the picture quality may not be to your liking (there are ways to minimize this).
First let's get the units 'talking' to each other. There is no info showing re: the HDTV you're using, so I'll keep things generic.
Easiest: if both units have RF cable connectors (the old screw in cable TV types), hook 'em up with a short piece of cable, and make sure that the channels out & in match (they are ch. 3 or 4).
Next up: Look for RCA jacks for out & in on both units. The colors will be yellow, red & white. The yellow is video, the red & white are audio (lt. & rt. channels) Check the jack's labels to be sure. Fire up the player, and run the set up- Sources In on the TV, and follow the prompts to get both sources 'seeing' each other.
Better quality: Look for S Video connectors on both units (they will be round with 1 square & 3-6 round pins). If you have these & a cable, hook 'em up; you'll also have to do seperate audio connections too. With S video you'll have to check the TV's source menu, and go from there.
Best quality (short of HDMI): at the Video Output & Inputs of both units see if there are 3 RCA jacks (usually grouped & 1ea yellow, green & red (colors can vary due units ages)), match 'em up red->red, etc. this is important since this is how the colors will be displayed!! Now You also have to hook up your audio too. Again, fire up both units, with this type connection the TV may automatically detect the new input; otherwise let the units detect each other and go from there.
Out of the methods above, only the 'S' Video is a specialized cable; for the RCA type cables, regular Audio type cables will work. If there is a lot of RF interferance upgrading to better quality and shielded cables may be necessary.
I hope this helps out.
Regards.
How do I get sounds when I use the red green blue rca hook ups?
The red, blue and green RCA hook up is just video. You must also use the red and white pair of RCA jacks for the audio. You can usually find the audio red and white jacks right below the video red, blue and green RCA jacks. Get yourself an audio RCA cord with the red and white connectors and run that from your video device audio output to the audio input of the TV that corresponds with the video input of the TV. An example would be if the red, blue and green are on the "Video 1" input of your TV you will find the red and white audio input for "Video 1" right below or right next to the video inputs.
The red, blue and green video jacks are called "component video" and they only have a video signal for high definition video, so you must also run a separate audio line for it. The same holds true for the yellow video RCA connector, that one is called "composite video" and it also has only a video signal with no audio.
I hope this helps, if so a "FixYa!" rating would be very much appreciated.
If you need more help just post your concerns right here onthis thread.
Dave
I am helping a friend to connect a 60 inch Hitachi Projection screen, model no. 60u85b it says on the back, to a Sony str485 amp that can run 6 devices - to get the sound from cable TV to come out the...
The coax should go from the wall to the cable box to the TV, just like you have it. Then you should run audio only (L and R RCA) from the cable box (if it has it) to the amp. Don't worry about running a video signal to the amp.
I want to setup my logitech x540 surround sound through my tv (which is LG 37LC2D the jacks at the back are Inputs: AV In 1 RF In Y AV In 1 S-Video In 1 Scart Jacks 3 Component in Audio 1 Digital Audio...
Based on your query "...which jack...put the green cable ...", I would suggest that you replace that green cable with a 3.5mm Stereo Phone Male to Twin RCA Male as shown below.
19ba6b8.jpg. The stereo phone would match the green INput ((Front) of the Logitech X-540 while the twin RCA (white & red) would match the RCA AUDIO OUTput of the LG 37LC2D.
Of course hooking it up this way would not fully utilize the 5.1 features of the X-540 (Rear and Sub/Center) but the TV sound will come out of the front speakers.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
