Question about Sony VAIO VGN-A150 Notebook
How do I have access to the hard drive on my vaio VGN-a150
I need to replace the hard disk but I cannot find the way to open it. I inescrewd 23 screws from the bottom cover and still nothing happen. Can you help me? Is there a hidden key that I should be aware of? I contacted Sony Tech Support but they refused to give me any technical information and their solution on send it over takes too much money and time. Thanks.
Hi my frieed l saw your messange in box the only thing you can do is that you need the change , Just change it? later
Posted on Sep 05, 2008
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Sony vaio vgn series laptop - when xp os loading blue screen appears and display the msg hard disk drive not detected.
system not found in my experience generally leads to a damaged or loose hard drive, try to open the cover at the bottom side of the machine, and reseat the hard drive, if it still says system not found, get a 2.5 inch drive case, put your laptop drive in the case and connect it to another machine, if you can access the drive great! save all your files and once complete return the drive to your machine and try to reinstall the OS from a dvd then reinstall your files.. and if still having the same problem replace hard drive thanks.
Oct 26, 2010 | Sony VAIO VGN-NS135E/S Notebook PC
Dead hard drive
it will be real silm like and it will be on the side where the cd player is not you may have to unsrew to srews and it should just slide out
Feb 14, 2010 | Audio Players & Recorders
I need to remove the hard disk and to replace it because it is bad. How do get to it to remove it? I don't see anywhere it is accessible.
most sony laptops either have the hard drive internal and either access is via a back plate with a few screws underneith or you have to undo all bottom screws then were the track pad is the top borrom half with either come away reveling the hard disk or the complete bottom will come away.
Feb 11, 2010 | Sony VAIO VGN-N220E/W Notebook
Need service manual or instructions on replacing hard drive on a Sony Viao VGN-ns135e or Sony VGN-NS100 Series Laptop
The hard drive is inside of the laptop and not accessible from the outside. The way to get to the hard drive is to take out all the screws from the bottom of the laptop, take the keyboard out and there may be some screws there that need to be removed. The dvd drive needs to come out and where the dvd drive normally is, check for screws there.
At this point you can remove the top cover assembly and you will see the hard drive. Remove the screws that are holding the hard drive in place and then it will come out.
Nov 30, 2009 | Sony VAIO VGN-NS135E/S Notebook PC
OPEN Sony VAIO VGN-T330FP TO CHANGE HDD
turn the laptop upside down ...remove a partial plastic cover attached by a screw on its edge ( there is a small sign showing the hard drive usually) after taking the cover of plastic away the hard disk is visible . pull it gently aside (sideway)
and replace it with the new one.
May 29, 2009 | Sony VAIO VGN-T350 Notebook
I like to replace old hard disk
There are panel/covers on the base or near the bottom edge of most laptops these enclose the RAM and hard drive. Remove these screws and covers to reveal the hard drive and possibly the hard drive carrier.
Before you attempt this I suggest to login to the Sony WEB site and download the drivers for the graphics and sound device including modem and LAN if you don't already have them and back up your data. You will need these drivers when you install a new and larger hard disk and the operating system.
Nov 15, 2008 | Sony VAIO VGN-SZ460N/C Notebook
Replacing Hard Drive in a Sony VAIO SZ330P/B
Turn your Vaio upside down and look for an easy access panel or release lever to remove the hard drive carriage. You will probably need a small Philip's screw driver to remove the carriage, but I don't think you need to remove the keyboard.
Aug 10, 2008 | Sony VAIO VGN-SZ330P/B Notebook
Replacement of hard disk in Vaio VGN-A150
Well, it's not good news. Official word from Sony:
Knowledge Article C309925...
Can the notebook hard drive be upgraded or replaced
Hard drive upgrades in the notebook computer are not supported.
NOTES:
* Some notebook computer have instructions for warranty replacement of the hard drive by an end user.
* Although third-party upgrades may be available for some models, they are not supported.
* If the hard drive needs service, repair should be done by an authorized Sony service center.
* External hard drives may be attached if the appropriate connections are available.
This basically means complete disassembly of the laptop is required to get at the hard drive. Not that it can't be done. Just that it'll be a major pain in the .... you know.
There is no hidden key!
Jul 24, 2008 | Sony VAIO VGN-A150 Notebook
Replacing Hard Disk Drive
all machines are slightly different for accessing the components, but if you flip over the laptop look for some screws on the bottom that hold an access plate. the hard drive is about three by four inches.
Dec 28, 2007 | Sony VAIO VGN-N130G/W Notebook
Sony VAIO VGN-A150 Notebook Logo
209 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
