Question about Canon Office Equipment & Supplies
Cannon Pixma printer plastic with two spings at each end that moves the printer carriage snaped(spring at one end but the spring for the other end is somewhere in the printer) What do I do? Printer is only about 8 monts old. [email protected]
  • Canon Master
  • 1,662 Answers
Try turning the printer upside down and rocking it back and forth to see if you can tip the original spring out. If you can't locate it or hear it rattling around inside, find a replacement spring at the hardware store and hope the spring flew out of the printer when it broke.
If it's a tension spring (hooked on each end), drill a small hole (probably #60-#54 drill size - choose the smallest size that will accommodate the spring wire) in the remaining plastic, and hook it up on this end. Reinforce the area around the new hole with the spring in it with a couple of thin layers of epoxy before connecting the other end of the spring.
Posted on Feb 13, 2011
SOURCE:
How do i change ink in my cannon mp480 printer
Lift the cover. A spring loaded lid support will hold the lid open. The carriage will move all the way to the left. Press down lightly on the cartridges one at a time to release them from the carriage. To replace, remove the protective strip fron the contacts of the new cartridges and insert and lfit slightly to lock in place.
Jul 19, 2010 | Canon Pixma MP480 All-In-One InkJet...
Error 5100
5100 is a Carriage Home Position Error.
Clean the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab.
Then clean the contact strip of your ink head cartridges, replace it on the carriage then move the carriage end to end and position it on the center.
Now reboot the printer ..
it should work
All The Best!!!
Please come back to vote, it would be a great appreciation for me and boost my determination to help so that I can keep on helping.
Zooless
May 27, 2010 | Canon PIXMA MP210 InkJet Printer
What is error message 5100 for this printer?
Code 5100 refers to a carriage that is not freely moving from side to side. Look to the far left and right for anything that would impede the carriage path.
Also, it is possible that the clear plastic encoder strip just behind the carriage path has become smudged with (most often) grease. You can clean the strip with a cotton swab dibbed in alcohol.
I hope this helps!
Mar 27, 2010 | Canon Pixma MP450 All-In-One InkJet...
My cannon mx300 is giving me an alarm code 5100
5100 means either the carriage is not moving freely back and forth or there is grease or ink on the encoder strip. You can clean that clear plastic strip behind the carriage with a Q-tip, but also check on the right and left side for paper scraps stopping the carriage.
Nov 23, 2009 | Canon PIXMA MX310 All-In-One Printer
Cannon pixma mp510 ~ error code 5100 help
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 19, 2009 | Canon PIXMA MP510 All-In-One InkJet...
I have an apple computer and Cannon MP 830 printer. Printer has a code 5100e error - how do I fix - can only find answer for a PC
As far as I am aware a 5100 error is a carriage problem and shouldn't be affected by what the printer is connected to. Have you confirmed that the printer doesn't display the error when connected to a Windows based machine such as a laptop? If it does then check that nothing is obstructing the carriage from moving across the printer and that the timing **** (clear plastic) is not damaged.
Dec 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Solve error 5100.cannon pixma 145 error always out # 5100
5100 error is a carriage error. Could be caused by the carriage unit, timing strip, logic board or carriage motor. Check that nothing is obstructing the carriage from moving freely and that the clear timing strip is ok.
Nov 20, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Error 5100
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
see if that helps
Robert
Please rate this solution thanks
Aug 26, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon Pixma ip3000
the code strip is the plastic strip that runs across the printer and through the head
carriage, it is supported at each end (one end under spring tension).
If it has become dislodged it will cause this problem. carefully try to place it back into place
Oct 11, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma ip1800
this strip feeds through the back of the carriage and tells the printer where the cariage is so it can tell how far along the page it is. it shuold be quite simple to hook it back on though many ayre spring loaded, if so this means a strip down of all exterior parts so that you can release the spring Hope this helps Cops
Oct 08, 2007 | Canon PIXMA iP1800 InkJet Photo Printer
43 people viewed this question
Clive
Clive
old marine
old marine
Ekse
