Commerical Speedqueen washer model C35MD2....machine fills with water at the beginnig of prewash cycle - tumbler rotates forward then backward through ALL cycle. Problem,, water never drains out - same water as prewash - and the spin cycle never kicks in. after all cycles are complete, machine stops at normal end of spin cycle and water slowly drains at that time. Washer has new drain value, new timer, and new door lock board... Any help out there?? Wayne
  • 1462 Answers
SOURCE: Door locked,wont spin or drain.
humming noise suggests a foreign object in the pump. crack open filter and drain water into a shallow tray. repeat till empty. remove filter completely and clean it. check if something stuck in pump impellor. this should be visible by looking into the filter hole
Posted on Jun 22, 2007
  • 30 Answers
SOURCE: Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to with the model number off your washer.
Posted on Mar 14, 2008
SOURCE: kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Posted on Aug 11, 2008
  • 1952 Answers
SOURCE: washer will not drain water or go into rinse and spin cycle
First thin I would try is to check your thermal fuse for continuity. Its located on the tunnel that incases the heasting element.
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
You also want to check the drain hose, the end of the hose is tapperd and tends to collect lint. Run a coat hanger up the hose and see if you can fish something out also check that belt.
Posted on Oct 06, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ... > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
Sep 6, 2013 - Uploaded by
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Speedqueen washer model number RWM373W-3062 after water is filled up the machine does not start, now my question is what to check first, the switch or the motor? please help thanks.
Have you checked the lid switch? Have you tried running it on spin cycle? If it runs on spin cycle, then your motor is fine.
Aug 09, 2014 | Washing Machines
When the 'wash' cycle finishes, the machine stops at the 'rinse and spin' cycle, and the 'prewash' LED flashes.
Victor. The prewash flashing is indicating a water fill issue. Rinse uses cold water only. check for clogged inlet screen on the cold water valve, and check if there is a screen on the supply valve also. If the inlet screen is all clogged up at the valve on the washer, you can clean it with a little windex and an old soft tooth brush. gently brush away any sediment or debris. If no filters are clogged, you will need to replace the fill valve assembley.
Apr 10, 2014 | Hotpoint WMA50 Front Load Washer
If your PreWash is flashing then you have a pressure problem. You can dry using a washer machine cleaner or doing a hot cycle with white vinegar. If that doesn't help the electronic would have to be changed.
Jan 08, 2012 | Miele W412 Front Load Washer
Out of balance
Did your clutch pulley use the upper One-Way Bearing ring?
What are the first two digits of your Serial Number of the machine?
What is the history of the Clutch install? Did the unbalance issue continue right away with the new Clutch Install?
How much rust did you find on the Clutch Pulley and the Upper One-Way Roller clutches bearing ring if used? Any Pic’s of the old Clutch Pulley?
If you shut off the water source valves to the machine and release the top the washer so you can lift the washer top and observe the wash basket rotating CCW at 50 RPM during the water fill part of the wash cycle.
Start a quick wash cycle and lift the washer top to observe the wash basket rotation CCW. The wash Basket will rotate CCW at 50 RPM. You can go into Service Mode and observe on the LED console FAV6800A machine. Not sure about the FAV9800A LCD flavor of the machine.
Do the tumblers rotate slightly during the water fill part of the cycle?
The machine may error out with NF for No Fill don’t worry about that I just want to determine if the tumblers are rotating during the CCW/Spin direction of the wash basket. You may have to put some dry laundry in the wash basket to help with the observation.
Let me know what you see……..Rich
Jul 02, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Asko Front load washer model W6021 Prewash
hi you need to replace the inlet valve,take off the top panel and you will see the valve behind the soap drawer with the black can get a book from
Jun 15, 2010 | Asko W6021 Front Load Washer
I have a whirlpool duet washer that will not spin at high speed and shows error code f 06
Error F06 is Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes. Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Will not spin, therefore will not drain
Hey Joe,
Let’s check to see if the wash basket will rotate CCW in Spin Only Cycle with no clothes in the wash basket
1. Open the lid and rotate the wash basket by hand Counter Clockwise, CCW. The wash basket should rotate freely with no restriction. The wash basket will not rotate Clockwise, CW by hand.
2. Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. Raise the top of the machine to observe the wash basket and tumbler action described in step 3. (See page 33 of the Service Manual for putty knife insertion point).
3. With the top raised start a Spin Only cycle with no clothes in the wash basket, observe the wash basket it should begin to rotate CCW does it?. Watch the tumblers, they should not rotate in spin cycle (maybe ½ turn at the start of spin cycle and that’s all). If the tumblers rotate while the wash basket is rotating you have a clutch malfunction. If the basket does spin CCW and the tumblers are rotating then you have a broken clutch spring. Let do those checks and observations and see what the next troubleshooting steps will be. Rich
Apr 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Indesit Dishwasher DI67.Cycle phase lights(prewash and wash)flash
I,d suggest Paying The $19.99 fee, on this site to get premium assistance. You,ll have technicians queuing up to solve your problem. And You,ll Have Solutions Within An Hour.
****** Please Do Not Rate This******
This Suggestion Is Information Only.
Good-Luck Mike @ Compurepair.
Feb 28, 2008 | Indesit 24 in. DI67 Free-standing...
Washer fills, drains instead of agitating, fills, etc
Nov 24, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
103 people viewed this question
Top Washing Machines Experts
