Question about JVC Gumy Ear Bud Headphone - Peppermint Blue
One earbud is not working - JVC Gumy Ear Bud Headphone - Peppermint Blue
My right side earbud stop working and it's a lg tech hbs 770
Only one earbud working means, most often, the thin cable that lead to right side earbud is broken inside.
Sep 29, 2017 | LG Radio Communications
Tip
How to make your earbuds and headphones last longer
something that used to happen allot to my headphones and earbuds is that one of the ears (sides) would stop working!I found a quite simple solution that made my 1 year lasting earbuds into 3-4 year earbuds!on the connector end, wrap 1 inch of electrical tape around the wire (not on the metal though).that way it wont bend back and forth allot near the base.Hope this helps someone!
on Mar 30, 2011 | Audio Players & Recorders
Is there a way to fix my earbuds when only one side works, but when i move around the wire both sides work. Or do I need to get new earbuds?
This happens because on of the wires inside the cable that goes to the faulty earbud is broken so it makes contact just by accident. This is unfixable, you need new ones.
Sep 06, 2011 | Audio Players & Recorders
Why did my left earbud become silent?
you can make both of the earbuds work. You can open the earbud where the speaker is that you use to hear the musik. Use a soldering iron and a lead. check if the wire inside has removed, fix it back and you will hear sound on both earbuds.
Take care.
Jun 01, 2010 | Sony EX33LPS Headphones
Sony MDR-NC11 Left Earbud has no sound
They should come apart right where the metal meets the plastic, just below the buds themselves - be careful, one set like that I took apart were actually surface-mounted to the housing, there weren't any leads to repair...
May 27, 2009 | Sony MDR-NC11 Consumer Headphones
When I put my earbuds into my ipod touch only one side works
You need to get the headphone jack replaced from apple.
Feb 19, 2009 | Apple iPod nano
My left earbuds on my JVC gummy earphones went out.
I have this problem all the time with my JVC earbuds. This may sound a little gross but it will work. I put the ear phone in my mouth and **** on the end of it pretty hard. What I have found is that sweat or even wax will plug the little hole and prevent the sound from coming out.
Nov 16, 2008 | JVC Gumy Ear Bud Headphone - Peppermint...
Skullcandy earbuds one earbud not working
It is likely that your right stereo channel has either been severed somehow or there is a severe short in one of the cables. What you can try to do to test this theory is first turn on your music. Then wiggle the cable at the very base of the right earbud. If nothing happens wiggle the cord right where it connects to the stereo jack. If still nothing happens run your fingers along the right earbud audio cable bending and twisting it. If at any point you hear music again then you likely have a short. If it is near the earbud then it is going to be difficult to fix since these earbudfs have a large gauard. If the short is at the stereo jack then the fix is simple. A standard 1/8" stereo jack can be purchased from any electronics or audio store. You can then fairly easily seperate teh old stereo jack and solder this new one in place. Search the internet for tutorials on how to do this if need be. Even if you do not get any kind of sound when wiggling it at the base of the jack this is the most likely culprit since this is where most of the stress on the headphones occur. Be wary though, if you do attempt a stereo jack repair you will void whatever kind of warranty your earbuds may have so check before you try. But, in teh end you may end up saving a 60-100 dollar set of earbuds for 5-8 dollars. Hope this helped.
Aug 13, 2008 | Skull Candy LINK Earbuds Consumer...
The earbuds have stopped working
one earbud is working!
How can I fix the problem or have repaired?
Mar 21, 2008 | V-Moda Vibe Earbuds Professional...
JVC Gumy Ear Bud Headphone - Peppermint Blue Logo
275 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
