Question about Lexmark Office Equipment & Supplies
I have my printer hooked up correctly but i can not get it to install on my computer.
    Novelist:
    Scholar:
  • 125 Answers
I'm not sure but some Lexmarks require you to install first the CD then you can connect the printer. What does the instruction say? Can't help you much if I don't know the printer model and what procedure you did.
Posted on Jul 24, 2008
Printer not wireless, does windows 8.1 accept it?
If your computer has USB ports, you can hook the printer up to the computer, and download the correct software to install that printer to your computer. I have a printer that is not wireless, and windows 8.1, and all I had to do was turn on the laptop, and the printer, and plug the printer into a USB. It automatically installed the printer, and I set it as my default printer.
Feb 07, 2016 | Office Equipment & Supplies
I just moved apartments, reset up my printer/computer, now computer is not acknowledging the printer. When I try to print it will say "connecting, 78% completed) and then nothing actually comes out.
MAKE SURE YOU HAVE YOUR PRINTER SET ON DEFAULT AND THAT IT IS INSTALLED PROPERLY! OR YOU CAN ALSO TRY...UNHOOKING YOUR PRINTER, SHUT DOWN YOUR COMPUTER AND HOOK YOUR PRINTER BACK UP BEFORE RESTARTING TO LET YOUR COMPUTER INSTALL YOUR PRINTER.
IF YOUR COMPUTER DOESN'T RECOGINIZE NEW HARDWARE, SUCH AS YOUR PRINTER, THAN IT IS NOT SET AS YOUR DEFAULT PRINTER!
YOUR SOFTWARE MAY NEED TO BE CORRECTLY INSTALLED, MAKE SURE YOUR PRINTER IS NOT HOOKED UP WHEN INSTALLING SOFTWARE.
SOFTWARE HAS BE INSTALLED FIRST, AND RECOGNIZED...THEN RESTART COMPUTER WITH PRINTER (HARDWARE) HOOKED UP!
Aug 25, 2011 | Office Equipment & Supplies
Installing a PSC 1200 Series
Have you already hooked it up? If so you will have to uninstall it. go to control panel, then printers and faxes click on your printer and uninstall it and unplug the USB cord from your PC. then run your install disk you got with the printer, if you don't have one you may be able to get one from HP or download the correct driver from their website. once you run the install CD follow the onscreen instructions and don't hook the printer to the PC until it tells you to.
Dec 04, 2009 | Dell Computers & Internet
I have a new computer with Windows 7. I installed the HP 3500 driver and now the printer won't print. I hooked up the printer to my old computer that ran the 3500 and now the 3500 won't print from that...
If it no longer prints to the old computer, begin by powered down the printer and unplugging the power for at least 1 minute.
Hook it back up to the old computer powered down.
Once powered back on, goto control panel, printers and make sure that printer is set to default.
Try and print again. If it works moving on to the other computer make sure you are using the correct windows 7 driver (32 bit or 64 bit) if you are using the correct one I would try and install the vista driver instead as windows 7 and vista are quite similar
Lets start with that If you still need further assistance please leave a comment Thanks :)
Nov 21, 2009 | HP Color LaserJet 3500 Printer
Connect pc printer to imac
hi,
You can install it with following specification
1) Install the diver for the printer on each device. I actually had to carry the printer into another room and hook it directly to the PeeCee to get the driver to install on it. I also noticed that it was better to download the driver than use the disk. Software online was newer than the disk, even though I just purchased the printer.
2) Plug the printer into the router and power cycle the router.
3) Download the Apple software "Bonjour" from the Apple website. Run it from the computer you want to hook to the printer.
Remember to make SURE the driver for your printer is installed ON the computer you want to print from or it won't work. As I found out you may actually have to carry the printer around to each computer to get the driver to install correctly.
Hope this helps! BTW the Mac software with my HP7580 is AWESOME!
Sep 18, 2009 | Computers & Internet
Says I need to reinstall drivers
TRY:
http://admin.utep.edu/Default.aspx?tabid=56
Downloading and installing.
Remove printer from 'printers & faxes'.
Uninstall printer software from 'add & remove' programs.
Disconnect the printer from your computer.
Reboot your computer.
Install the printer software that you downloaded. Connect printer to computer following on screen instructions.
Jun 08, 2009 | Lexmark X1150 All-In-One InkJet Printer
Need help to hook up IBM color flatbed scanner
Attach one end of a parallel port cable to the parallel (printer) port on your computer and the other end of the cable to the computer port on the rear of the scanner. If you have a printer connected to your computer, you must disconnect the printer cable from the computer before connecting the scanner cable.
If you have trouble attaching a cable connector to a port, be sure that you are connecting the correct end of the cable to the correct port.
IF. . . you want to use a printer WITH your scanner, attach one end of the printer cable to the printer port on the rear of the scanner and attach the other end of the cable to the printer.
Plug in power cord and then power up PC.
Power on scanner. Install drivers. Restart PC to activate EZ Station buttons.
Oct 11, 2008 | IBM Color Scanner Flatbed Scanner
How to stall a printer
You have everything plugged in correctly, re-track your steps and see.. and you have installed the software that comes with it? a lots of the times it is something we did not hook up correctly.
Hope this helps
Jun 05, 2008 | Lexmark X2500 All-In-One Printer
13 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
