Question about Whirlpool MH3185XPS Microwave Oven
Door handle How can I replace the door handle on my Whirlpool Microwave Oven the handle crack and broke at the bottom
  • Anonymous Mar 28, 2009
    EXACTLY the same problem, the handle broke off the bottom screw. I bought a new handle on-line (arrived the next day)but then I couldn't figure out how to screw in that bottom screw. This really helped ! Thank you.
    Same problem except the YouTube that goes with this only shows how to take off the choke cover. Then you have to take the inner window with frame out of the door ... which means you first have to take the whole door off its hinges. Then the lower screw head is hidden under the foam insulation.
    When putting the whole thing back together make sure the upper hinge pin is locked in place with the thin aluminum slide, otherwise the top of the door will wobble 1/8-1/4" and not lock well enough to protect from microwaves.
  • Whirlpool Master
  • 9,098 Answers
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
Door frame on microwave broke apart
If it is out of warranty, I'd just buy another. Most repairs would cost more than a replacement nowadays.
Nov 13, 2013 | Maytag MMV5208W Microwave Oven
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at khader_abu@yahoo.com........
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
I have a whirlpool mh1150xms-3 and the handle is broke! how do i replace it without breaking the glass? i took out the 3 screws on the left side and it wont seperate from the outside case!
Unplug the microwave oven from its power outlet or turn off its circuit breaker. Remove the right fuse from the home fuse-box if your microwave is a built-in model.
Open the microwave door and take the top pin off its pivot bracket. Lift up the door and remove it from the bottom bracket. Lay the microwave door with its front side down on a folded towel. Remove the two choke screws from the door frame using a Phillips head screwdriver.
Remove the choke cover with the knife blade, starting from the microwave door's top right corner. Pry out the bottom and top right sides, leaving the side which houses the door handle in place.
Remove the choke tabs from their slots on the microwave door frame using the knife blade. Continue to work clockwise around your microwave door; remove the choker cover when you get to your handle's side to separate it from your choke.
Remove the two handles with the Phillips screwdriver. Remove the handle from the microwave.
Screw the new handle in the position of the original handle. Lay the choke on the microwave door; set the choke cover right on top of it. Insert the choke tabs into their slots on the microwave door frame using the knife blade.
Secure the two choke screws using a Phillips head screwdriver; set the microwave door back on the bottom bracket. Slide the top pin into the microwave's pivot bracket.
Press the top pin down until it pops securely into place.
Oct 03, 2011 | Whirlpool MH1150XM Convection/Microwave...
There is a whirlpool Microwave (model:MH1150XMB4) in our apartment. Unfortunately, there is a crack in the door. Although the crack is only in the plastic frame of the door, the landlord asked us to...
Got the same problem. Still inquiring but I might have found a solution here : http://midwestapplianceparts.com/microwave-parts-537/whirlpool-microwave-parts-648/microwave-door-panel-663/whirlpool-microwave-door-panel-w-glass-4212.html
$79 for the panel only
Jul 01, 2010 | Whirlpool MH1150XMQ Microwave Oven
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Replacing door handle of Whirlpool GH6178XP
I kept prying on the frame case until it disengaged, came loose and exposed the bottom screw.
Feb 17, 2009 | Whirlpool GH6178XPS Microwave Oven
The door handle on my microwave broke away from the door. Is it
Of course it is.  You can glue it on with gorilla glue, perhaps using a screw shaft (be sure to drill pilot holes) like a dowel in carpentry to secure and add area for the glue to adhere to.  Drill the pilot hole in the handle bit the thread diameter rather than the shaft diameter, so you don't have to screw the handle on once you cut off the screw head.
Dec 23, 2008 | GE Advantium 120 Convection/Microwave Oven
How do you replace the handle on my advantium 120 oven
If it's just the bottom one and you don't want to disassemble things to reconnect things right, drill a pilot hole in at an angle through handle and door to permit screwing in a wood screw to fix it up.  Brutish, yet sexy.
Dec 13, 2008 | GE Advantium 120 Convection/Microwave Oven
Whirlpool MH7140XFQ
It's most likely caulk. It can usually be sliced with a razor blade.
Sep 21, 2008 | Whirlpool MH7155XM Microwave Oven
Broken Handle
On almost any microwave oven door if you open the door,on the inside part of the door,theres a square plate thats plastic that is a one piece unit that goes all the way around the edge of the door . That held on by little plastic clips that are molded right on the suround and easy to break, so take a small screw driver(of course the ovens unplugged by now) and start at one end and start prying it out inch by inch. Being care full not to crack it. If yop do crack it, you must replace it, but its not that expensive. Once you have off the cover surround, you will see the screws that hold on the handle. If you need help getting the part go to http://www.repairclinic.com as even if its not listed get the phone # and call them and they will assist you. Good Luck
Jun 03, 2006 | GE JVM1640 Microwave Oven
Whirlpool MH3185XPS Microwave Oven Logo
295 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
