Question about Whirlpool 24 in. GU2548XTP Built-in Dishwasher
Dishwasher will not start
Accusense button and heated dry button will light, but no other buttons will. Pushing cancel starts a 2 minute cycle where the machine makes noise, but does not really do anything that I can tell.
  • 17 more comments
  • map12c02 Jul 24, 2008
    Machine Model is Whirlpool GU2548XTPQ0
    I read in some forums about resetting using heated dry and sani rinse as well as normal and heated dry. This did not work. I also tried holding start for 30 secs. This makes the normal button flash, but does not seem to help either.
  • map12c02 Jul 25, 2008
    Delayed Start button will light and display 1H, but does not initiate after 1 hour. Also in my first comment I noted that pressing cancle starts a 2 min cycle with a noise. I belive that is an attempt to drain, so the pump turns on and that is the noise I hear.
    Tried unplugging washer for 15 mins and did not help.
    The washer still exhibits the same symptoms.
    The clean light is not flashing. I can not get the cycle to start.
    The start indicator is not flashing.
    I know that I am getting power because I am getting lights. The cancel button starts the drain cycle, so I know the door is shut. Any other ideas on how to reset the electronics?
  • map12c02 Jul 28, 2008
    The sequencr of normal wash and heated dry does not work. When I unplugged the washer for 25 mins, and tried the reset sequence, the sani rinse button lit, but did not flash. I hit the cancel/drain buttin and it started the drain sequence. The sani-rinse button went off and did not come back on.
    Still trying to figure it out.
    I shut off the breaker for 30 mins.
    Washer does not start, but power is getting ot the panel since the drain cycle works and some lights come on when pushed.
  • map12c02 Jul 29, 2008
    no error codes
  • map12c02 Aug 03, 2008
    I think the problem is narrowed down to something wrong with the latch sensors or the circuit board. When I press accusense the display shows "- - " which is supposed to mean not latched. This is the only button that allows the "- -" to light up. I took a multimeter to both sensors. The sensor to the left shows 0 volts and then when depressed shows 5 volts. The other sensor shows 120 volts and then when depressed shows 0 volts (I thought that was odd that this sensor showed 0 volts when depressed).
    The washer has worked a couple of times by pressing on the left and right and center of the door just right, but this took 15 minutes and is not repeatable. I then thought maybe it is the display buttons. This is probably not it either since holding the start button for 30 secs makes the normal light flash, showing that the start button is registering.
    This leaves me to the question
    #1 is it a sensor (they both seem to either show voltage or no voltage)
    #2 is it the circuit board?
    #3 is it the button panel?
    HELP...................
    Ant ideas?
    Any ideas?
    This model does not have a power button
  • map12c02 Aug 07, 2008
    Replaced circuit board and door sensors. Now the Normal button is flashing, but will not start.
    Problem Fixed. It was one of the connectors going to the circuit board that was not properly connecting.
  • 813 Answers
  • Door latch.
    Make sure door is closed and properly latched.
  • Delay start option.
    If delay start option is available, has it been set and is unit still in time delay before starting.
  • Cycle setting.
    Check to see if cycle is set correctly (refer to Operating Instructions in the "Use & Care Manual").
  • Posted on Jul 29, 2008
      Sergeant:
      Champion:
    • 246 Answers
    If you can try to set the refresh button in the circuit board.
    if does not work i think you have to replace the circuit board .
    Because the problems coming from the circuit board
    Posted on Aug 07, 2008
    • 876 Answers
    My dishwasher is not the same model but a similar one and it will not do a proper cycle unless I open the door all the way down before I program my cycles at about 2/3 of the way up and then close the door. Strange huh? But it works everytime. I know it sounds simplistic, but it works for me.
    • 640 Answers
    Hi map,i hate to be the bearer of bad news but i belive the control board is acting up.Im a commercial service mechanic for hobart and service these units often,from the symptoms you desribe it points to the board as faulty.If you need any ? answered let me know.
    Posted on Aug 04, 2008
    • 659 Answers
    There is a potential over heating condition in the wash pump motor. In rare instances , this could cause a fire. The drain pump imotor is not affected and can be reused. Replace the pump-motor assy with motor kit # 8194160
    Posted on Aug 03, 2008
    • Wesley Gardner
      Wesley Gardner Aug 03, 2008
      here is a link to the parts list.
      http://shared.whirlpoolcorp.com/product_...
      but first please contact a whirlpool
      Contact Customer Support at 1-866-698-2538.
      this might not be the first of this model to have this issue maybe they can also help put you into the right direction if the part does need to be replaced or not.
    • Wesley Gardner
      looking through the manual and it say that it is covered by your warrenty as well.
      Genius:
    • 1,226 Answers
    If this not start at all then you have to continuity test from the power input to the circuit panel board.
    Posted on Jul 28, 2008
    • Emelio Navaja
      Emelio Navaja Jul 29, 2008
      Thank you for using fixya,
      one last recommendation is to consult the repairman near your location to resolve the issue personally.
      melnavz
    • Emelio Navaja
      Emelio Navaja Aug 04, 2008
      all the comments are very useful, however; there is still error, so the best way either is to consult repairman personally in your location.
    • 2,071 Answers
    I believe the reset sequence is accomplished by pushing the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. Let me know if this helps.If not, there should be a tech sheet that came with the dishwasher located behind the lower kick panel under the door. This sheet includes all diagnostics codes and troubleshooting diagram...
    Hope this may help;
    Regards,
    VOTIT
    Posted on Jul 25, 2008
      Genius:
    • 1,665 Answers
    It doesn't work at all If your dishwasher doesn't work at all, check these:
    Power from the house
    Door switch
    Wiring
    Timer or selector switch
    Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
    Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
    Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
    Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
      Genius:
    • 2,035 Answers
    Is the Start/Resume indicator flashing? Opening the door or
    interrupting the power stopped the cycle. Close the door and
    press START/RESUME.
    Does the Start/Resume indicator flash 3 times when you
    press START/RESUME? The dishwasher is waiting for you to
    open the door after the last cycle. Open and close the door,
    then press START/RESUME.
    Is the door closed tightly and latched?
    (NOTE: On models with a dual-digit display, the control
    displays “- -” during a cycle if it believes the door is not
    latched.)
    Is the right cycle selected? Refer to the “Cycle Selection
    Charts.”
    Is there power to the dishwasher? Has a household fuse
    blown, or has a circuit breaker tripped?
    Has the motor stopped due to an overload? The motor
    automatically resets itself within a few minutes. If it does not
    restart, call for service.
    Is the water shutoff valve (if installed) turned on?
    It is normal for certain cycles to repeatedly pause for several
    seconds during the main wash.
    • Anand Kumar
      Anand Kumar Jul 26, 2008
      Please unplug the unit from the wall unit for 30 minutes from the AC power this will reset the unit ..
    • Anand Kumar
      Anand Kumar Jul 28, 2008
      This could be due the faulty on board ckt problem you need to replace the board .....
    • 3,037 Answers
    Is the clean LED blinking at all and if so, how many times
    So no water is entering but it is trying to enter? I would take a look at the water valve/solenoid and possibly think about replacing it. Also try resetting the main circuit breaker to the machine to see if that will work. Please let me know how this all goes
    • Whirlpool Master
    • 19,396 Answers
    Try first unplugging puwer cable for five minutes with no load, see if it reset.
    • 13,433 Answers
      Guru:
    • 1,894 Answers
    Are you able to see any error code in the display of the unit?
    please let me know
    • dewan nafees ahmed Jul 29, 2008
      If your dishwasher doesn't work at all, check the power
      supply, door latch switch, selector switch and timer, and the wiring.
      If your model has a child lock-out feature, verify that the feature is
      set to the Off position. Make sure cycle has ended. Make sure the Delay
      Start option is not set for a delayed start.
      If you can, verify that you have power at the dishwasher. This
      might be difficult because many dishwashers are wired directly into the
      household wiring under the counter. Usually only the portable
      dishwashers get plugged into a wall outlet. You will also want to check
      your fuse box or circuit breaker panel for a blown fuse or tripped
      breaker.
      The door latch switch is a safety switch that prevents the
      dishwasher from working if it is defective. When working properly, the
      switch doesn't allow power through it when the plunger is out, and it
      allows power when the plunger is in. If the plunger is broken or if the
      internal parts are not working properly, power is stopped at the switch
      and it needs to be replaced.
      The timer and the selector switch are other possibilities. If
      one of these is defective, your dishwasher won’t operate
      normally, and the part will need to be replaced.
      Running the dishwasher regularly may help prevent any seals
      from drying out and sticking. This includes the motor seals.
      Visually inspect the wiring to see if any looks disconnected
      or burned. Repair or replace as necessary.
    Model #DU1015XTXS2
    With the dishwasher door closed and the unit in standby mode or with no cycle selected and all lights off, press - heated-dry, normal, heated-dry, normal buttons in that sequence. Then press cancel..... wait until 2 minute cycle is done. Open and close the door and make sure it is closed. Then run another cycle.
    Apr 06, 2014 | Whirlpool Dishwashers
    I have a whirlpool gold quiet partner III Black dishwasher. All of a sudden it stopped working. I push the accusense button and start the cycle for washing, it looks like everything is working normally, I...
    Hi
    If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry . Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
    Daniel
    Aug 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
    The "cancel" light blinks on and off rapidly. If we push start for the cycle the dishwasher clicks off and on intermitently.
    To solve this you will have to reset the console. Do this by closing the door and press these buttons in sequence
    -high temp wash -heated dry -high temp wash -heated dry
    After doing this sequence all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).You should now be able to run the dishwasher as normal.
    Thank you!
    May 16, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
    Whirlpool Dishwasher won't drain during normal cycle
    As you say a clogged line or valve does not make sense.
    Try running it without the heated drying and see if it empties or if the cancel button will work then.
    The dishes should air dry quickly if you empty it and open the door.
    It could be a defective thermostat allowing it to get too hot during the heat cycle
    May 18, 2009 | Dishwashers
    ''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
    If the clean light flashes 7 times, pauses, then repeats...
    When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
    To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
    -high temp wash
    -heated dry
    -high temp wash
    -heated dry
    ...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
    If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
    It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
    Apr 01, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
    Kenmore Ultra Wash Dishwasher LIghts are blinking....
    I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
    Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
    Whirlpool 24 in. DU1055XTP Built-in Dishwasher
    I don't know if your dishwasher is the same as mine, but this solution may be what you need. For electronic panel dishwashers made by whirlpool (mine is a whirlpool but with a kenmore name on it), some of them can be reset by pushing in sequence the Heated-Dry button followed by the Normal-Wash button, several times in a row. that is... Push Heated-Dry, then Normal-Wash, Then Heated-Dry, then Normal-Wash... Repeat until all lights light up. When all lights light up you can stop. The washer will then take 5-10 minutes to go through a diagnostics cycle, which is about 18-25 steps or so. You can bypass one step at a time by pushing the STart button. This may not apply to your washer, but is pure gold if it does. Good Luck!
    May 26, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
    Cycle buttons work, option buttons dont, Cant deselect heated dry, Wont start
    The part is covered by warranty. However, the labor is not and Whirlpool will not replace the part without having someone service the unit. Every place I checked wanted $100 just to come out and tell me what was wrong. Any service would be extra. Seems like Whirlpool figured out how not to stand behind its products. They should be held accountable.
    Dec 27, 2006 | Whirlpool 24 in. GU2500 XTP Built-in...
    Whirlpool 24 in. GU2548XTP Built-in Dishwasher Logo
    446 people viewed this question
    Top Whirlpool Dishwashers Experts
    Oloyede Monsuru
    Mike
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
