Question about Whirlpool GH7155XHS Microwave Oven
Replacing the outer door cover
How do I get to the screws to take the last 2 out for replacing the cover?
I don't want to break anything and I haven't found a drawing for it.
  • Whirlpool Master
  • 9,098 Answers
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
How to repair a broken lower door hinge?
You may need to remove the microwave off the wall but lets try this first. Unplug the micro and then remove the screws around the bottom cover plate. The cover should drop down--watch the wiring to the light system mounted to the cover. Now look at the bottom hinge area. Can yo see and access the screws to the hinge??? Should be 2 or 3 screws. If you can get to them then you can change the hinge there. Tape the door in place so it doesn't drop while doing the repair. If you can't see the screws, you may need to pull the micro off the wall and remove the outer case to do the repair. In some rare cases the hinges are welded to the case and not replaceable.
Mar 30, 2015 | Frigidaire PLMV169DC Microwave Oven
How do I replace kitchenaid microwave door handle?
This is not a fun one if you take a putty knife and go in between the outer door and frame you can release the outer door cover hears the catch over time the door frame becomes brittle so there is a 50/50 chance the frame will break trying to separate it
Feb 18, 2015 | KitchenAid Microwave Ovens
I have a Kenmore Elite Microwave Oven - that I need to replace the door latch on... (plastic prong broke off - and I got new piece in the mail without any install instructions or door design) So, I do not...
Most of them you do have to carefully pry. You look on the inside of the door and you will see the choke seal. It runs around the whole outer edge on the inside of the door. Take a butter knife or a small screw driver and start to pop it up and out of the door. Slowly work around the door until it is completely free. Once you get that out you will see the door hook and will just have to look how it is mounted into the door. There will be a spring attached to it to allow it to pull up and down as the door is opened and closed. Make note of where the spring is attached to the inside of the door frame. It will have to hook onto your new part and back on the inner door.
Oct 15, 2017 | Kenmore Microwave Ovens
The locker (latch) on my microwave broke. We just got the replacement part in the mail. Sears says we should be able to replace it ourselves. I see no screws to get inside the door. Does the plastic flange...
If there are no screws to hold the inside door cover in place then they are probably using snap or lock in tabs around the edges to hold it
in place. You will have to disassemble the door to replace the door latch. ----------
Its a latch spring assembly.-------- Click this link below and follow the door lock latch replacing procedure:---- http://technoanswers.blogspot.com/2011/07/how-to-replace-door-lock-latch-on.html ------------------- This will help.Thanks.Helpmech.
Jul 14, 2011 | Microwave Ovens
Replace door
Pretty simple actually, open the door and remove the clipped on black trim that surrounds the edge by prying with a putty knife or similar flat edge- be careful not to break the latches. Inside and under the trim is a few screws that allow you to seperate the inner and outer door. Once you have the outer door off you can lift the inner door from the pinned hinges. Rerverse to install.
Oct 17, 2010 | GE Advantium 120 Convection/Microwave Oven
GE Microwave model JVM1650CH01. Trying to replace door handle." I have removed panel on inside of door and removed 2 screws to handle. It appears that there are screws holding the outside cover of door...
This image might help. If not it looks like you have to disassemble the door until you get to the very outer frame, as that is where the handle screws are
May 07, 2010 | GE JVM1650 1000 Watts Microwave Oven
I have a JVM 1650BB008 GE microwave oven. I am trying to replace the outer door frame and handle, which are broken. I have removed the door and have pried off the choke cover. Now I need to remove the old...
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You have to remove the door handle screw(s) and the door handle, then look for subtle clips that may be holding the outer door screen in place.
Some models have two screws holding the door handle, but some have only one. In that case, remove the screw, then you either lift or rotate the handle to free it.
If you still need help, please write me at prototech@usa.net for the service manual link (no charge, no obligation).
Sep 27, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
How to install latch and spring in microwave door
You need to know where the 'catches' are inside the choke cover on the door to remove it carefully without breaking anything or marring the cover. You might get inside and find that the post for mounting the return spring has broken and that is part of the outer door panel.
Sep 11, 2009 | Sharp R-1610 Microwave Oven
How do I change the light bulb in an Amana microwave model# ACM1580AS?
The whole metal cover should be removed, 2 special tamper proof screws are at the bottom back end use a small screw driver to pry or break the center post and then use torx screw driver to take it out, the bulb is a specialty bulb available in partselect.com for almost 30 bucks. good luck!
Jun 20, 2008 | Amana Microwave Ovens
Door Disassembly
Actually, the spring is probably okay. What breaks is either the latch head (with the hook-like protrusions) OR the spring mounting tab on the inner side of the outer door panel. The spring connects to both of these parts. The outer door panel is not availablke as a separate part, so if that's where the break is, you'll have to get a bit creative and clean it squeaky and use epoxy (like JB Weld, but never use "super glue") or you can drill into the panel slightly and install a small screw eye or glue it in place. Even if the spring mount on the inner door panel is not yet broken, while you're in there, it's a good idea to clean it squeaky and add some epoxy to strengthen it. To get to the screws, you have to remove the choke cover (see sample photo below). It's usually not necessary and is better not to remove the door. You can set the oven on its left side on a table top, open the door carefully, and ease it down to the table top. Then you have a level, stable area to work on the door. If the problem is the latch head (ref # 5-2-2) then I would recommend replacing that part instead of gluing it. That's because the new part may be an improved version. Plus you'll start out fresh. The part # is LSTPPB030MRF0 (zero on the end, not an "oh") You can order Sharp parts from http://wwww.wehaveparts.com You can find a helpful exploded view of the door here: http://207.234.249.73/mwd/r1480_control_door_exp.pdf
May 11, 2007 | Sharp R-1480 Microwave Oven
Whirlpool GH7155XHS Microwave Oven Logo
29 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
