When you say the spring is loaded tight I assume that you mean that the bracket is hard against the oven door. The brackets/arms have to point away from the door so they click into the oven. Normally when you pull the bracket down and away from the door you put tension on the spring. Once the bracket travels more that 180 degrees, probably to about 200 degrees the bracket won't normally spring back and should stay there by itself.
