the lock/unlock button on the Cuisinart Smart Stick CSB-75 blender may not stay locked when pressed in. The solution is to hold the blender in the palm of your dominant hand, press the low or high button and hold, then push and release the lock button on top with a finger on your other hand. The blender motor should start as soon as you push the lock button down and stay running until you release the high or low button.
However, fix.com offers OEM Black and Decker blender parts and accessories, including rubber gaskets, jar bases, measuring cup lid inserts, and blade assemblies. You may want to check if the parts you need are available and replaceable.
If you are unable to repair the blender yourself, you can contact Black and Decker customer service for assistance. They may be able to provide you with additional information on how to repair your blender or direct you to a local repair shop.
The official replacement site for Kenmore products advises that this part is no longer available. See here.
You might try taking your old blade assembly to a local small appliance repair shop and see if they can source a part from a used model or recommend a compatible part from another manufacturer.
Do you hear it hum when you try to turn it on?
If yes, remove the cup. Try again... if the motor runs, try moving the blade by hand. If it is seized, remove it and clean it to free it again.
If not, possibly blown windings on the motor or divider circuit (which supplies different voltages to the motor for the different blend speeds). Repair will be required in either case.
either the motor is inoperable, or is improperly wired. return it to the retailer. that is assuming you have the cup firmly seated before you try to operate the machine.also if the control panel has more than one speed make certain that only one button, or switch position is engaged
I have had my blender sitting for over a year ( only used it once ) because of the same problem and asked my husband to take a look at it... he opened it ... cut the zip ties took the metal banding off ( note only one side of the motor has the metal banding). What you need to get at is behind the first (I think) resistor. Behind that is a thermal fuse (found at radio shack part # 270-1320 about $1.96). you will need some kind of tester to check the ohms going through it (should read zero) the bad one on mine read 334 ohms and you will need a soldering iron to put it back together. Actually a good project for someone who loves to tinker with this.
Alternating blinking lights on a Kitchenaid blender indicate a bad
circuit board which is unable to run the motor properly. Unplug the
blender, take the jar off, and turn the spindle by hand. Then plug it
back in. If it does not work properly, try a different outlet (perhaps
not in the kitchen). If nothing works, the blender needs to be
repaired.
