Question about Dryers
Kitchenaid Superba Dryer also stopped working (3 years old)
Sounds like we have the same problem with our Kithchenaid Superba dryer (model - KEYS850LT1). It's getting power as the timer still ticks, but dryer won't work all of a sudden. It got very hot to the touch on last cycle when it quit working. It's also been taking a good while to dry clothes lately.
Is the white fuse with 2 wires coming out the one that is located on the outside of the blower housing to the right of the blower wheel?
  • 254 Answers
Yes it is, you can bypass it for testing purposes only, also clean out your vent too the outside it is probably clogged that is what usually blows them out.
Posted on Jul 25, 2008
Kitchenaid superba electric dryer doesn't dry on timed dry
Sounds like a controller problem. May be unable to start a normal dry cycle
Sep 11, 2012 | KitchenAid Dryers
The drum turns and the dyer blows air. It does not light, when I took it apart the ignitor does not come on. We replaced our gas coils about a year ago. what do you think might be causing the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 26, 2011 | KitchenAid KGYS850LT Gas Dryer
I have a kitchen aid dryer SUPERBA electric dryer. It stopped drying. still runs ok but no heat. Checket the Element . looks fine . what could be the reason.?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 05, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Replacing moisture sensor in Kitchenaid dryer. I have Kitchen Aid electric superba dryer model KEYS850GT0, ~15 years old. Runs great except the moisture sensor came out into the drum. The part appears to...
Go to www.repairclinic.com and enter KEYS850GT0. With luck you will be presented with a list of common replacement parts and may be able to view a generic KitchenAid dryer disassembly video.
Jul 17, 2017 | KitchenAid Dryers
The icemaker on my KitchenAid superba KSBS25in does not work
Their might be an easy fix here. Try a hair dryer. heat the ice maker and dislodge a possible stuck ice cube( a common problem)
More HERE
Dec 15, 2009 | Kitchen Ranges
No heat when timer is in Electronic Sensor selections.
The electronic sensor needs to be replaced.
Sep 16, 2009 | Dryers
How do I relight the pilot light on an old kicthen aid superba dryer?
This isn't a dryer but it's the same idea. Follow the gas line into the dryer. Take the little cover off and you need stick matches. Watch the video to get the technique....
Jul 21, 2009 | KitchenAid Dryers
Icemaker stuck in 'vacation mode'
Feel inside the ice slots are there any old cubes that have evaporated in time? Take the ice maker out and clean it up and place it back inside to see if it will fill with fresh water. Take a hair dryer and melt the old ice inside the slots and see if it will try to fill. I will wait for a response from you.
KSCS25INWH00 Kitchenaid Parts
APPLIANCE 911
KitchenAid Refrigerator Ice Maker Assembly 2198597
May 06, 2009 | KitchenAid Superba Architect KSCS25IN Side...
KitchenAid Superba dryer(electric) will not run. I have power. All I hear is what sounds like the timer running.
You probably have a bad thermal fuse, small white two teminal fuse on the blower housing.
Jul 11, 2008 | Dryers
Dryers Logo
194 people viewed this question
Top Dryers Experts
