Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint CTD80 Tumble Dryer F03 error
Hi
To set the scene, I am an expat living in Oz and the tumble dryer I shipped over has an F03 - no one has heard of Hotpoint over here for 20years so no one will fix it.
The dry starts fine and runs for for about 30 seconds then the error appears on the dash but the drum still spins as normal.
Can anyone suggest which parts to change so that I can get them shipped over from the UK. Any help or advise would be most appricated.
Thanks Craig
Hi
We had the same problem as you and the hotpoint engineer fitted the three part numbers listed below to fix the code f-03 error.( Info taken from his computer printout )
EEPROM CTD80/85 DF 14 PART NUMBER C00195636
THERMISTOR FRONT " " 1703413
MODULE POWER CONDENS " " COO194077
Hope this helps and not to late for you
John
Posted on Oct 22, 2008
    Scholar:
  • 97 Answers
Hiya
sounds like you will need a thermostat kit and possibly a heater unit, if your getting them shipped to oz you will probably use them. i would change the thermostats first as this will more than likely be the cause.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj.
p.s if its still broken this time next year i'll come and have a look just waiting of my visa :)
Posted on Aug 03, 2008
How to fit belt on Creda Reversair 37643 Tumble dryer
New belt is very tight, so you have to use more strength. Put it on motor and all other on "drum". Spin it easily and slowly but with strength until its done.
Be carefully, use gloves.
Apr 13, 2013 | Indesit Hotpoint Creda Tumble Dryer Belt...
Replacing belt on service tumble dryer
see this videos and fix it. use the common sense. God bless you
Sep 30, 2012 | Hotpoint Creda Servis Tumble Dryer Belt...
By hotpoint ultima ctd80 tumble dryer has error code f11. What does this mean?
F11 - No pump connection. the pump that pumps the water up to the draw has gone wrong. hope this helps.
Sep 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
We have a washer dryer hotpoint bwd129. Can you
a washer dryer has a different approach to cleaning fluff. It has an internal flushing system.. only do routine check on pump filter.
Oct 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
Tumble dryer isn't woking
You may need to replace the thermostat or the heating element.
Apr 13, 2009 | Hotpoint -Ariston Aquarius WD645 Front...
Tumble dryer
Go to:
www.hotpoint .co.uk
Click on After sales, then on download user instruction books, put in you model number, and down load to your computer, or your printer.
Problem solved.
Plz rate my solution.
thanks, and merry xmas.
Dec 21, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Tumble dryer not drying
Either dryer element has failed, thermostat for drying or the drying condenser fan not working.
There are two heating elements and the top one is for drying.
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima tumble dryer error code f-03
i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Jan 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hot point WD440 wash/dry :How to put tumble spin off.
i know this may sound stupid but did you follow the instructions on removing the Transit Braket? with tht un removed it will cause the machine to "Dance" around the room
Jan 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
274 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
