Question about Sony KP-51HW40 51" Rear Projection Television
Power Originally the tv started having green lines shoot across the screen and then eventually shut off. If you turn the tv on it lights up for a second then the screen goes down to a green line across the middle of the screen and then the tv powers off on its own. Total time for it so this is about 3 seconds
    Problem Solver:
  • 9 Answers
Sounds to me like its your green tube. Kind of expensive replacement, but easy.
Posted on Jul 29, 2008
Screen issues
I think better to replace the set as all this sounds like a light engine failing.
Dec 08, 2012 | Televison & Video
I have evenly spaced, rows of two vertical green and red lines from top to bottom of my vizio plasma P50HDTV10A
Somehow when switching between the tv and the dvd my wife encountered the pink and green, thin, parallel, vertical lines on the screen. The picture was visible with the lines. I turned the tv off and on but the problem persisted. Unplugged tv for about two minutes and after plugging it back in and turning it on the vertical lines very gone and the picture was back to normal.
Jan 12, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
When I turn on the TV with the remote or on the front, it comes on for a second and then shuts off. I was able to keep it on once, and all I got was a horizontal white and colored line across the TV, but...
horizontal lines indicates that the vertical section is most likely the defect..a defective deflection yoke could cause this and eventually damage the vertical output ic causing an overloading in the power supply then can caused to shut down
Jul 16, 2011 | Toshiba 27D46 27" TV
The power comes on and then turns off and the front green power light blinks.
There is a small IC in the power supply section,
not the IC regulator that's the problem.
Jan 06, 2010 | Philips 32PT6441/37 32" TV
Thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Sep 02, 2009 | RCA P52926 52" Rear Projection Television
Power shuts off
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Jul 07, 2009 | LG 50PC1DRA 50 in. Plasma Television
Sony 2002, kpws500
Minium is the green picture tube need to be replaced, if you can take the front cover and access panel off there is a control with 3 focus and screen controls.
you can adjust the 3 screen controls to possibly get a little more time out of it before the crt's need to be replaced. careful if you turn them down too much there will be no picture, and if you turn them too high the tv will go bright and shut off
Apr 13, 2008 | Sony KP-57WS500 57" Rear Projection...
TV Problem
memory ic lang yan pogi
Mar 28, 2008 | Televison & Video
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
JVC AC32F702
22uf/250v from the 180v flyback output and 100 uf/50v in vertical and the last 220uf/16-25v from 16v line of flyback.
Apr 28, 2007 | JVC AV-32F702 32" TV
Sony KP-51HW40 51" Rear Projection Television Logo
109 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
