Question about Estate TAWX700JQ Top Load Washer
Funny noise when machine is emptying
My washing machine works fine,until it comes to emptying,it makes a very loud whiring noise,at first it was now and then but now its all the time,i`ve taken the back off it and taken out the small pump that is connected dirrectly to the outlet pipe at the base of the washing machine,just to check to see if this may be the problem,but that seams to be fine,the small wheel inside is free from any mess,please help,this noise is driving me mad,i`ve only had the machine about 18 months,thanks in advance to any suggestions Makes a funny noise when machine is emptying. It pumps water out fine but the noise is not a good sign!
  • Anonymous Apr 18, 2009
    I have a GE Prodigy and I've had it maybe 7 years now. But when it gets to the spin cycle, it makes a loud roaring noise that's very irritating. Also, sometimes when it's time to spin, it won't. It'll hum but won't spin. It's like it's stuck or something. Sometimes i'll lift up the lid a few times and it'll start to spin. But this last time I had to unplug it for a while to get it to spin. Could this be the pump or a belt ? Please help!! Thanks!
Accurate call? WTH? The problem isn't with the agitator. The problem described is with the drain pump!
Posted on Sep 10, 2008
  • 166 Answers
Service before you have real problems!
Sounds like the coupling connector from the trans. to the agitator is worn and ready to fail.
Bless you
Please give me a good rating for my accurate call!
happy to be of service.
Hi wont start. just making a loud whiring noise.
According to your description of the fault, something was blocking drain turbine of main motor. Dishwashers always first start drain water because calibration of water level inside dishwasher (empty). In your case, the main motor is same motor for washing and draining. Runing in one direction means washing, runing to oposite side means draining.
The solution is to open a turbine pump and remove all obstacles and visual check turbine impeller,ceramic seal and plastic sleeve on the motor shaft.
Mar 26, 2015 | Electrolux Dishwashers
My washer makes alound grindin noise wen trying to empty
1) most Noises coming from washing machines coming during the cycles of SPIN .Clothes load can be un-balance. Stop the machine and balance the clothes.Start again, and repeat the step if necessary.
God bless you
Jun 28, 2012 | Washing Machines
It will spin but the water does not come out, then it makes a funny sound-like a high rattle noise. We have never had any problems - we checked the hoses, they are clear. I has worked like a tip for years,...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Aug 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer made a funny noise, stopped working. I shut
Here is a tip that will help you with the not spinning or agitating problems....
Washing Machine2_bing.gif does not Pump or Spin
May 13, 2010 | Maytag PAV2300 Top Load Washer
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
The washing machine makes loud banging noises when its running.
Either the machine is not balancing correctly or something mechanical has broken. If it works fine when empty then it is a balancing issue. If it does this even when empty then something has broken that supports the tub.
Jan 07, 2009 | Washing Machines
Makes a loud noise when machine emptys
Hi there
Hope you got your machine fixed
Thank you for using Fixya
Nov 15, 2008 | Estate TAWX700JQ Top Load Washer
Does the "whirring noise" sound like a jet engine?  If so your bearings are going.  Check your warranty.  It's a big job to replace them.
Oct 06, 2007 | Summit Commercial SPW-1100 Front Load...
Estate TAWX700JQ Top Load Washer Logo
94 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
