Question about Garmin GPS
My gps330(i bought 4 -1 for each of my children) goes on and then shuts off .when i try to recharge it it doesnot charge the cord seens to be alright...is there a fuse in it that i should change i bought it in nov of 08 as a xmas gift for my hubby.yo
    Novelist:
  • 113 Answers
There is a fuse in the tip of the plug that plugs into your cigarette lighter. Does the LED light up on the plug when you plug it in? Does the 330 stay on when plugged in? If the answer to those two questions is yes, then you probably have a bad battery.
Posted on Jul 24, 2008
On my charger both, lights flash green as i try to recharge, but it only recharges a little.
Hi , use the scooter for about 10 minutes, okay now plug in the charger, do any of the lights go red or orange to indicate it's charging, if not , remember one green light is to indicate it's turned on...
1. Check the voltage can be seen at the charger socket, (mulitmeter required here volt DC setting looking at the two outside holes)
2. Is it not possible to try another charger ? as long as it the same fitting ...
3. Is there a fuse for the charging line?.
4. If all fails then it seems the batteries need be replaced.
Regards
www.gewizrepairs.co.uk
Nov 26, 2013 | Health & Beauty
My laptop goes off when I unplug the cord from laptop!
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 30, 2012 | HP Pavilion dv9000z Notebook
Nikon Coolpix L110 camera was bought for me for Christmas 2010. Worked fine at first, but now seems to be having problems. Batteries don't last. I just bought new batteries in Feb/March this year...
You have to charge the batteries for nearly 8-10 hours. Brand new batteries also require a full recharge of 8-10 hours.Not only making sure the batteries are charged, have you changed the battery in the menu under type of batteries.
Download this manual :
http://www.nikonusa.com/pdf/manuals/noprint/L110_ENnoprint.pdf and go to page #114
Buy EN-MH2-B4/MH-73 Kit (4 Rechargeable Batteries + Charger)
Jun 14, 2011 | Nikon Coolpix L110 Digital Camera
My mp3 player wont charge up,soon as i turn it on it says turning off battery low,my daughter only used it three or four times.bought it on 6/16/10
You have not mentioned the brand or model #.
Just remember the life span of a typical rechargeable battery is only 3 years from the date of manufacture. And the life of the battery also depends on how one charges it. Its important that you allow the battery to soak in charge uninterrupted for the stipulated time ( as given by the gadget manual ). Typically would be 3 to 5 hours and children some how do not have the patients or the discipline to do so. Frequent and short charging sessions ruin the battery.
In fact the first charge is the most important-- it should be a long one. But in the excitement to try out the device very often I have seen people charge it for 5 minutes and then turn on the device to see how it works or sounds !!!
This is the reason when you buy a cordless phone there is a sticker on the handset telling you to initially charge the phone for 6 to 7 hours prior to use.Some even tell you to leave it overnight on the charger.
Any way your problem might be solved with a new battery and follow the instructions thereafter.
Good luck.
Apr 28, 2011 | Audio Players & Recorders
We have rechargeable controllers. They no longer accept a charge. We bought a new battery pack - when you plug in the USB cord from the console to the controller, it says they are fully charged, but when...
it seems like the charge cable isnt charging the pack. have u tried using an alternate charging method like a charge stand? or try on another controller, if it still doesnt work on another controller, its your charge cable.
Apr 11, 2010 | Microsoft Xbox 360 Wireless Controller
My MPC t2300 laptop wom't turn on.
The Transport T2300 has an internal battery that will run the laptop for several minutes after the main battery goes dead. This feature allows you to save your work and shut down safely. If you run the laptop until both batteries are dead, even a brand new battery can't start the unit again. You have to follow this procedure:
1.Unplug power cord
2. Remove any attached periphal components including the cd rom and/or floppy disk module if you have one. Both remove with a push button switch located on the bottom of the unit.
3. Plug in power cord and charge the unit for a minimum of 24 hours straight. 30 hours is better. This whole time will be spent slowly recharging the internal back up battery.
4. Once that is done, unplug power cord again and reinstall any floppy/cd drives. Plug power cord back in now and charge for at least 24 hours again.
If your backup battery is dead, you can't charge the main battery or turn the unit on. The longer you charge, the better. We had one unit here that had to be on the initial battery backup for 72 hours before it finally took hold. Then, one overnight recharge on the regular battery and all was well.
If you need drivers or manuals for the 2300, all are available on cd at mpcsupport@cox.net for around $9.50 including shipping, handling, and owners manual
Apr 11, 2009 | MPC Computers TransPort T2300 Notebook
Compaq Presario needed a new battery was installed labtop will not charge up!
When you install a new battery and remove a battery always make sure the laptop is completely shut off and have the power cord removed so that you avoid any possible power surge.
Batteries generally don't last much longer than a year and I have found removing the power cord or battery when it is off to be a good practice.
Before you charge a battery make sure it is run most all the way down. Recharging a battery when it is not run down can give it a memory and you may only be able to charge it up to the point you started charging it.
Anyway, if the computer won't charge a new battery then you could have a bad motherboard. To be sure try another battery.
Sep 09, 2008 | Compaq Presario Notebook
V smile pocket problems
Do you still have your receipt? You could try to echange it at the store. Vsmile is coming out with a newer slightly different handheld model you could try. Though, we have a vsmile for the home and a leapster as a handheld game. Which both of my children have loved. Have you tried calling Vtech about the problem? I've had to call before about the home unit and they were very helpful. (Incedently, I have had problems with that, so if you ever do here's a helpful tip: Reset the machine by unplugging EVERY cord and pressing the two front buttons together for one full timed minute! We were having problems with a power issue and this solved it) They may be just as helpful as Leapster's Leap Frog company and send you a replacement! Once on a long car trip my daughter got sick in the car, while playing, so needless to say the game system got it too. And when I called Vtech about what to do, they sent a replacement! Try calling Vtech and see. You never know! Good luck!! :)
Sep 05, 2008 | Vtech V.Smile Pocket
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
