My linksys WAP router has "little or no connectivity". I think there is a problem with the network key, as I was trying to find it so I could get access on a second wireless computer. Now the 'original' computer will not connect.
  • dupree71 Jul 24, 2008
    did not seem to do the trick.
    Genius:
  • 1,342 Answers
Reset your Linksys back to factory default if you can't remember the key/password. Just push and hold down the recessed button on the back for 30 seconds. This will rest it back to they day you bought it.
Posted on Jul 24, 2008
  • Chris Hunt Jul 25, 2008
    Then check to see if you actually have a Net connect buy pluging in your PC directly to the cable/DSL modem and bypass the linksys.
    If that works then your Linksys could be toast or the firmware is hosed.
Cant connect to my dell inspiron 8100
I think you should check the wireless settings of your router first.
If your wireless network is secured then make sure that you have the correct wireless network key WEP / WPA .
If your router is too old then it will be better to upgrade the firmware of your Linksys router.
Jan 01, 2012 | Linksys Wireless-G WRT54G Router
Tip
How do I set up the wireless network key on my linksys router?
Hi.
This tip applies to any Linksys wireless router.
First you need to access the router control panel , and check wireless settings.
Therouter control panel is accessed connecting a computer to the router.This is done using an Ethernet cable, and entering router IP address in Internet Explorer address bar.
Here the cable:
Here the procedure.
Connect router to computer using a network cable (LAN cable with RJ45 connector).
On computer open Internet explorer and type router IP in the address bar (where you use to typewww.this.that ).The IP address is indicated on router user manual. Ifit has not been changed, 192.168.1.1 is the default for LinkSys brand home broadband routers. Press enter after typing the IP.
Enter router user name and passord. On older LinkSys routers, the default username is blank and the default password is "admin." On newer LinkSys routers, both the default usernameand the password are "admin". If that does not work, then defaultsettings had been changed. In that case you will need to reset therouter. See: Reset a LinkSys Router Password.
After entering right ID and password you will open the router control pane as HTML page in Internet Explorer.
In the router control panel choose the wireless setting tab to see or modify the password:
If you do not need to change wireless settings, then write down the encryption key, and set the same key on the laptop. Once the right key is set on the laptop, the connection will start automatically.
If more computersare connecting to this network, then do not reset or change thewireless settings. Simply write down the key on paper and setup thelaptop.
Remember that WAP encryption keys are case sensitive, Wep encryption keys are not.
The simplest encryption to choose is WEP.
WEP means wireless encryption key.
Open the router panel, go to wireless, and find key settings or set your own key.
If you have to set the key:
If you choose WEP 64, then the key that you need to set will be 10 characters key made by numbers and letters from A to F.
Close Internet Explorer to get out of the Linksys control panel.
Regards.
on Mar 16, 2010 | Linksys Wireless-G WRT54GS Router...
Hi Support team, I use Modem Motorola SB100 with Linksys WAP54G, and DLink Wireless G DWA USB Adapter to connect to Linksys WAP from my PCDesktop. Connection from the PC to Linksys is ok but can't...
peter_picasa:
You cannot use a Wireless Access Point (WAP) to connect directly to your IPS's modem. A WAP does not provide the ability to share a single IP address on the internet like a router does.
Either return the WAP for a refund and buy a wireless router or buy an Ethernet wired-only router and plug the WAP into the LAN side of that router. You would then plug the WAN side of the Ethernet wired router into your modem.
Thanks for using FixYa.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
How can I secure my wireless connection?
By using a WEP key, please find your manual below, download it, and go to SECURITY, it shows one step by step how to set your WAP/WEP "KEY" Once set, you are secure. As to logon to the WiFi network, you need the special "KEY" to do so.
http://www.retrevo.com/support/Linksys-WRT54GS-Wireless-Routers-manual/id/421ci076/t/2/
Nov 24, 2010 | Linksys Wireless-G WRT54GS Router...
I'm trying to connect to my mobile phone and it's asking for the network key. What's a network key?
First connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then you can see configuration page of router settings.
Go to wi fi or wireless menu then find WEP or WAP security code key it is your password to connect wi fi network.If it is in * or # format then add new code so you can connect it with new code.
then save settings and restart router.
Then add that code key in mobile for connect wi fi .
Let me know if you need more assistance.
Thanks.
Nov 11, 2009 | Linksys WRT160N Wireless Router
I need a networking key to set up my lynskys wireless
do you own the network's router? if so, then simply visit the router's config page. to do this, turn on your router and connect a working PC. then in that PC, visit http://192.168.1.1 and you will be brought to the router's config page where you can setup the wifi's key
Oct 20, 2009 | Linksys Wireless-G Broadband Router
How to get step by step to secure a wireless router for a linksy
First connect your router to computer with ehtenret cable.
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
then go to wi fi security then check WEP or WAP key you have to set new key because it is in * or # format then save settings and restart router.
WEP or WAP key it is your password to connect wi fi internet ,
Let me know if you need more assistanse.
Thanks.
Sep 07, 2009 | Linksys Wireless-G WRT54G Router
Cannot connect 2nd computer to internet
Well, sounds like you have a wep or wap encryption on your network...Usually to fix it (if you don't know your wep or wap) just press the reset button on your router. This has happened to me before, and that is all i had to do.
Jan 10, 2009 | Linksys -Cisco Wireless-G VPN Broadband...
Network key
Lkrawlings:
Can you go into your router from IE? like http://192.168.x.x, then from this configuration page of your router you can find what key you had put into your router. Make sure the type of security you are using like WEP, WPA, PSK, WPA2 etc. This key should match on your desktop or laptop machine to gain connection to your router.
If you are unable to find your key like this then:
You could refresh your router to factory defaults by pressing for 5 seconds, you will find this hole at the back of your router. try going again into your router like I said above and make up any other key.
Hope that helped!
Dec 07, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
