Question about HP Officejet 5510 All-In-One Thermal Printer
Changing the cartridge hp 5510
Lost my manual and can't find the opening to replace the cartridge- copier produces blank pages
On the front of the unit, reach into the place where the paper comes OUT of the printer and GENTLY pull on the panel. It should swing up and the cartridge carrier will then automatically align in the center of the opening.
There should be instructions on the inside of this panel for replacing the cartridges.
Posted on Jul 31, 2008
Why will my printer only produce blank pages
Might be catridges are clogged.,Remove cartridges clean nozzles manually( you can findout in youtube how to clean cartridges), fix it back try it. If not succeeded, replace the cartridges..
Mar 22, 2015 | HP Deskjet F340 All-In-One Printer
How to change the cartrige for hp 5510; chere are the cartgages stored in the pinter. I do not have a manual.
Here is the link to download a copy of the manual for the HP 5510 All-in-One Office Jet Thermal Printer at
Step-by step instructions along with illustrations on how to replace the print cartridge is found on p. 63
Apr 20, 2011 | HP Officejet 5510 All-In-One Thermal...
I have an hp injet 5510 and I cannot remove the printer cartridge in order to replace the old with the new. Help! I have the door open with the printer on and cannot get it to come out.
You often have to tilt the cartridge to get it out. Some cartridges have plastic holders you have to disengage. Refer to your manual, or just inspect the cartridge holder carefully to figure out how to dislodge it.
Mar 13, 2010 | HP Officejet 5510 All-In-One Thermal...
Printer 5510
If you use your printer occasionally, it might be that the print head on the cartridges is clogged. I don't know what was serviced, but if your cartridges haven't been printing for a while, that is surely your problem. You can try this:
  1. Try cleaning the print cartridge from the Maintenance utility by following the steps below:
    1. On the all-in-one front panel, press Setup (or Menu) repeatedly until "Maintenance " displays, then press Enter .
    2. When "Clean Cartridges " displays, press Enter .
    3. At the end of the cartridge cleaning cycle, a page will print. Examine the page to determine if the problem is corrected.
  2. If the problem still exists, clean the cartridge following the directions below in the "Clean under the cartridges and the carriage " section below.
  3. Verify that the ink cartridge is not low on ink by checking the estimated ink levels as indicated in the "Colors on printout are wrong or fade in and out while printing " section above.
  4. Replace the print cartridge for the color that is not printing correctly.
Mar 05, 2010 | HP 5510 4-in-one Printer
Hp 5510 printer display shows ''Print Cartridge Error. See the product documentation for details.'' Cannot find the manual. I have reseated the blank ink cartridge but the message remains.
Clean the contacts on BOTH the cartridge and the printer... the little gold dots... try it again.
Note that HP imbeds a serial number in each cartridge and in an effort to thwart refilling, you need to present a different cartridge to the printer and power on when you change. That is, temporarily put a a different one and turn on power to fool it into thinking it is a different one before going back to the one you intend to use...
Feb 01, 2010 | HP Officejet 5510 All-In-One Thermal...
Printer # 5510 - How do I open to replace ink cartridge?
If you mean HP OfficeJet 5510 then the following tutorial is for you:
HP OfficeJet 5510 Replace Ink Cartridges
If you do NOT mean HP OfficeJet 5510, please do not fail my solution. Instead, start a new thread with your make, model clearly defined.
Jan 13, 2010 | Office Equipment & Supplies
HP p2015 printer has stopped printing
check inside the toner door on the right side. there should be a plastic tab which opens the laser shutter when the door is closed. if this is broken then the lase shutter will not open and will produce blank pages.
Jan 15, 2009 | HP LaserJet P2015 Printer
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
Changing cartridges
for the 5510, the manual says to turn the machine on, then lift the catridge cover piece, which is the flap under the hp symbol on the scanner/copy's the flap that hangs down just above where your print copies come takes a little tugging, but it comes up and then you can see your cartidges...after that, push down on the cartridge and pull it out..
Mar 15, 2008 | HP Officejet 5510 All-In-One Thermal...
HP Officejet 5510 All-In-One Thermal Printer Logo
1,253 people viewed this question
Ben Johnson
