Question about X2Gen MG19MY 19" LCD Monitor
Monitor shows out of range when not in safe mode
My daughter changed the color settings . would this cause the screen to read out of range when not in safe mode? can,t get the screen to work !!!!!
please help
  • tareqsaeda Jul 26, 2008
    my monitor x2gen/ mw19R
    describe the steps you've taken to resolve the problem thanks.
Mine displayed out of range when i tried to go too high with the screen resolution. Totally flipping out like an untuned tv. Display properties of 1280x800 work best for me... though i wish i could go bigger without weird stretching of the view
Posted on Aug 30, 2008
How do I get rid of a flashing message "Display Mode out of range"
Here is an article from Microsoft on this problem. Good Luck !
20x20_grey_minus.pngCause This behavior can occur if the signal from the video adapter exceeds the scan range of the new monitor. The video adapter setting for updating the screen (the refresh rate) is incompatible with the monitor. uparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.pngResolution To resolve this behavior, either change the refresh rate, or change the video adapter settings.
To change the refresh rate:
  1. Restart the computer, and while it is restarting, press F8 until the Startup menu appears. Press 3, and then press ENTER to start the computer in Safe mode.
  2. Right-click the desktop, click Properties, and then click Settings.
  3. Click Advanced, click Adapter, and then click Adapter Default from the Refresh Rate list.
  4. Click OK, click OK again, and then click Yes to restart the computer in Normal mode.
You can set the colors and screen area to your preferences under Display Properties.
To change the video adapter settings:
  3. Click Advanced, click Adapter, and then click Change.
  4. Click Next, and then click Display a list of all the drivers in a specific location, so you can select the driver you want.
  5. Click Next, click Show all hardware, and then click Standard display types under Manufacturers.
  6. Click Standard Display Adapter (VGA), and then click Next.
  7. Click Yes, click Next, click Finish, and then click Yes to restart the computer.
  8. After the computer starts, right-click the desktop, click Properties, and then click Settings.
  9. Click 256 colors, click Apply, and then restart the computer.
  10. After the computer starts, click Start, point to Settings, click Control Panel, and then double-click System.
  11. Click Device Manager, click View devices by type, and then click Display adapters.
  12. Click Standard Display Adapter (VGA), click Remove, and then click OK.
  13. Install all updated monitor drivers.
Jan 24, 2015 | Computers & Internet
Monitor says out of range
If you are connected to a started computer, the resolution of your display adapter is not supported by your monitor. To solve this, you must restart your PC in safe mode and change the display settings (right click on the desktop/Properties/settings tab and you must try for the begining with a lower resolution, for example 800x600).
To start the PC in safe mode you must press the F8 key (or check the key for your operating system) before the OS loading (imediately after the PC starts or after the reset/restart) and than select the safe mode VGA.
Jan 03, 2014 | Envision G918W1 Monitor
SOYO DYLM24E6 DISPLAYS OUT OF RANGE WAS TOLD MONITOR HAS A RESET BUTTON IF SO WHERE OR IS THERE A FIX FOR THIS MONITOR IT IS NEW
Restart your computer in Safe Mode
(or reconnect your previous monitor).
Set the screen-resolution to 800 by 600 at 60 Hertz.
Shutdown, connect the new monitor, and restart, and your Soyo monitor will be able to display something, using these "NOT-out-of-range" values.
Try changing the resolution to 1024-by-768, or 1280-by-1024,
and "test' these values, to see what values are "in-range" for your new monitor.
Jan 07, 2010 | Soyo DYLM24D6 LCD Monitor
I get a message, "Frequency out of range. Nothibng else. The menue and other buttons don't do anything. Nothing else shows. I swapped out the monitor and the new one works.
This problem arise when your computer AGP driver not adjust monitor frequency.you fix it restart your computer and run safe mode settings resolution area(must be choice less area)or select 1024X768 pixel monitor frequency 60Hz press apply set OK.restart your computer.Run again normal mode.May be fix your problem.
Dec 27, 2009 | Princeton Digital VL1916 19" LCD Monitor
Error : out of range
Out of range mean your monitor can not configure grafics resulation.Run your computer safe mode configure or setting resulation area. must be set less area apply your choice.restart your computer then fix it.
Dec 27, 2009 | ViewSonic VX910 19" LCD Monitor
Screen is black. Power lignt is on. Mouse works.
Does it make a difference in Safe mode? Its Possible that your monitor or vidio are out of range Safe mode (f8) on botting will boot with the bare system settings, if safe mode works then reduce the resalution, Color and Possibly the monitor refresh rate
Nov 02, 2009 | Samsung SyncMaster 540N 15" LCD Monitor
Outof Range error message & black screen
To resolve this behavior, either change the refresh rate which is what is chnaged or the resolution or change the video adapter settings.
If the above problem does not help ypu then change the resolution and select the correct resolution which your CPU and monitor both support....
Try the below solution if you know it or else leave it
  5. Click Next, click Show all hardware, and then click Standard display types underManufacturers.
  8. After the computer starts, right-click the desktop, click Properties, and then clickSettings.
If the above solutions is not working for you then contact your nearest Harware person for the solution... All the best.
Mar 18, 2009 | HP L1940 19" LCD Monitor
Out of Range message displays when PC boots
The settings that you have for you tower needs to be changed if you have a old monitor connect that to the tower then right click on your screen go to settings and set it real low once this is done connect the new monitor up and set where you would like it,
The out of range is just letting you know that the settings thats set the monitor can see
Mar 12, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Medion monitor shows analog out of range and will not turn on
Two options here. 1) Boot into safe mode, open control panel, display, settings, change the screen resolution to the lowest setting and color quality to their lowest setting and reboot. If that works move your setting up to where you used to have it (i.e. 800x600 pixels. Another option is to use System Restore to restore your system to an earlier date...a program you recently installed could be the culprit. System Restore is located at Start, All Programs, Accessories, System Tools.
Jan 14, 2009 | LG Flatron L1750S 17" LCD Monitor
I was adjusting picture on monitor and now picture completely messed up
  • Signal out of Range.
  • Out Of Scan Range
  • Horizontal frequency is out of range.
  • Cannot Display This Video Mode Out of Sync
This issue may occur if the signal from the video adapter exceeds the scan range of the monitor. The video adapter setting for updating the screen (the refresh rate) is incompatible with the monitor.
you should reinstall your video drivers in safe mode.
To restart in safe mode repeatedly press the F8 key during the computer startup. This will bring a menu where you'll be able to choose safe mode.
LCD monitor 60 - 75 Hz
Jan 25, 2008 | IBM E74 17" CRT Monitor
X2Gen MG19MY 19" LCD Monitor Logo
136 people viewed this question
Top X2Gen Computers & Internet Experts
Sandy Moore
Sandy Moore
Jack Hunter
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
