Question about Dell Latitude C610 Notebook
Dell d610 battery does not charge--
The chip that controls the charging circuit of the battery has to be replaced--defective-- it is a 8 pin surace mount-- the only number on the chip is 4805---believe it to be a mosfet--need the original part number or the specs
thks
    Genius:
  • 2,028 Answers
Check the other post for suggestions.
Posted on Jul 24, 2008
MY SAMSUNG ES25 CAMERA BATTERIES DISCHARGE AFTER 5 OR 6 PHOTOGRAPHS
The problem is the part where the flash unit (ES_TOP_PCB). It's a small plate on top. Failure of the "chip" (SMD FET 8 pin ZBOC4), which controls the high voltage capacitor charge (80mF / 310V) and circuit continuously draws current from 250 mA. The problem is in the feedback when a flash capacitor charge circuit should stop charging the capacitor. Chip is located next to the high-voltage capacitors. On this plate are two chips, one control, and the other driver and it was a mistake. Check and diode (R 8) before the capacitor. This failure was in one of the serviced cameras. Another possible defect in the display. The third failure was in transport lenses and there is a malfunction focus electric motor, but this can be heard as the motor constantly running back and forth. This fault and the fault display requires a change modules. Lots of luck ..... ERNESTO from Croatien
Nov 27, 2013 | Nikon Coolpix 990 Digital Camera
Why wont my dell D610 charge i have changed the battery and charger
Hey!
If you are still encountering the problem charging your laptop's battery, it is possible that the port where you connect the adapter or the port for the battery is damaged. It will still receive power but it won't charge.
Best solution is to replace the motherboard. Just make sure you would get the exact same devices on a replacement board.
Hope this helps! :D
Sep 09, 2010 | Dell Latitude D610 Notebook
LIGHT COMES ON AC ADAPTER BUT GOES OFF WHEN PLUGGED INTO NOTEBOOK
This is possibly an internal power Supply fault. take the battery out, plug in the adapter, IF the unit works now, you have A: A battery problem, or B: a charging circuit problem. If the unit still fails to work, the power supply in the PC has faulted. You need to get a "Quote: for a repair.
Mar 17, 2010 | Dell Latitude D610 Notebook
Dell Latitude D610 wont charge
the charging system on your motherboard has blown a capacitor, if it is still under warenty you should call 1-800-456-3355. to get it repaired.
if it's out of warenty, they can help you buy the right part
Aug 14, 2009 | Dell Latitude D600 Notebook
My Dell latitude d610 charging circuit not working on board
What needs to be done is the jack that your adaptor plugs into has solder points underneath it. All the solder points need to be resoldered to make sure that there are no cracks in the solder that are preventing the jack from charging your battery.
After this is done if the laptop still isn't charging then if you know for sure your using the correct ac adaptor with your laptop then at that point the moterboard would have to be replaced.
Jul 31, 2009 | Dell Latitude D610 Notebook
My Dell Latitude D610 Battery Stopped Working
The battery light flashing RED/AMber is an indication of a failed battery.
Portable batteries have a life expectancy of 300 to 500 recharge/discharge cycles. (roughly 18 months under normal use) After that, the charge life starts to drop off and eventually it will not hold a charge. Because of this, the battery is considered a consumable item and is only warranted for one year from the manufacturer.
Since all the systems listed in the post are D610's (4 to 5 years old) it is not surprising that the batteries are failing.
Dropped Puck, if you replace the battery and a new battery doesn't charge/run the system, then the charging circuit on the MB is failed.
Feb 22, 2009 | Dell Latitude D610 Notebook
Dell d610 latitude wont charge new battery
Hey,
First off, do you have a way to check the output of the ac adapter to ensure it's putting out the correct current?
If you've done that and have a multimeter handy, you can remove the battery, system off, and check the charge pins for current/voltage. I believe one of the end pins is neg (ground) and at least one of the other pins should show 2.6-3.6V, as well as other various voltages. If you fail to get any response at the charger pins, we'll need to look at the board circuitry, assuming again that the ac adapter is operating properly.
Good luck
Nov 26, 2008 | Dell Computers & Internet
Dell latidue D610
The light indicator for the battery is; green-charging, yellow-battery failure, and red-charging system failure. The charging system failure happens when the power management chip fails. The pm chip regulates and controls the power input & usage, allows the machine to switch from AC to battery, and cotrols the charging. This will also cause the problem with the power button not workin or being hard to start. Unfortunately, the motherboard will have to be replaced in order to fix this.
Jul 26, 2008 | Dell (F2273) Motherboard
Dell d610--battery will not charge
I had the same problem on D610, it was not charging the battery and also the CPU speed was showing only the minimum 800Mhz though maximum was 2Ghz. I updated the bios (though it had the newest version) and ran intel chipset driver for D610. Viola! it set the speed to 2Ghz and the battery started charging. Was it a miracle or a solution I dont know!!!
Jul 24, 2008 | Dell Latitude D600 Notebook
Dell Latitude C610 Notebook Logo
180 people viewed this question
Alun Cox
