Question about Maytag Kitchen Ranges
Oven does not light, model #LCRG760A serial#201993Fk top burners light ok.
    Scholar:
  • 93 Answers
Open the range door, remove racks so that you can have enough room for your troubleshooting or observation.
Remove the two nuts of the oven cover.
Turn ON your oven knobs observe the ignitor for about 14 seconds if glow at all.
If the ignitor glow weak "orange" it shows that the ignitor need to be replace bcos it doesnt draw enough current to light up the gas.If it does not glow at all. visualized the ignitor if shorted "whites fume" on the surface or broken.If not, remove the power plug from wall socket, check the leads of the ignitor connectors, set your meter to resistance(ohmic value). if no reading or beeping sound - that indicate bad ignitor . part # for your model is PS50459.
If does not glow at all, check the safety valve perhaps one or two pins burnt with the wire harness.You may also check connectors leads that goes to your ignitor.
Good luck.
Prince P- rate my comment
Posted on Jul 24, 2008
Where to find the model seriel numbers
Hello there and thank you for choosing fixya
Ok normally the model number will be posted on one of the following
i have the diagram listed below for you ok this is for both gas and electrictbirdfan1_14.jpg
Jan 21, 2011 | Ovens
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Mar 30, 2010 | Ovens
Gas oven does not light
I called the service where the item was purchased.
You were no help at all
Dec 03, 2009 | KitchenAid Ovens
Oven wont light
Check the amp draw on the ignitor. If 2.9 amps or less, replace the ignitor. If 2.9 amps or more, replace the gas safety valve.
Aug 02, 2009 | GE Ovens
Oven will not light
One of the Ignitor/orifice assy.,electrode is bad expecially the one your wife have to light.The circuitry is ok,but change that bad ignitor/orifice assy electrode.
Part number is Item # 833121: check it out @ www.repairclinic.com
Jul 04, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven & broiler not working
you ignitor is going out you will need to replace it the ignitor needs to draw a min of 3.2 amps in order to open the gas valve coil if short of this it will not open at thimes it may just have enough to open
Jun 28, 2008 | Hotpoint RGB528 Gas Kitchen Range
Serial Number:
Ok remove the burners first,then with a thin 25b4c19.jpgscrewdriver or even a butter knife push it between the front cabinet and the top to release the clips (2) that are holding this top down.see pix.
Jun 10, 2008 | Hotpoint RA620F Electric Kitchen Range
Oven range does not work (broiler and oven)or heat up. Upper burners are working. Whirpool Model # RF 3663XDWO Serial # FF 4705148 Fault code Lights as F3
F3 on that model should be a sensor problem. It's the metal probe coming in from the back top inside the oven. Check for a loose wire first between sensor and oven control. Be sure to unplug unit before taking back off to check for wires.
Apr 17, 2008 | Kitchen Ranges
Gas burners won't light
I would check the pilot orfices and the regulator on the unit.Seems like not enough gas pressure.Let me know
Dec 10, 2007 | Kitchen Ranges
Lighting a pilot light in a 30 year old roper gas range
Lift the top lid and look for a cylinder or something similar with tubing going into it there should be a button of some sort on the side. if you are lucky the button will have a red cap on it. press the button in and light the pilot inside the oven. hold the button for a minute or so until the pilot stays on. kind of like lighting a water heater.
Oct 31, 2007 | Ovens
Kitchen Ranges Logo
116 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
