Question about Kenwood KAC-9102D Car Audio Amplifier
Car audio when i trun my truck on my amp trun off
  • antivirus_fr May 11, 2010
    i have a kenwood amp and iam rally happy to have it.because i have found out that this amp can play any kind of subs even if it is a 18".but i only got one problem.and that is my car battery gets flats every time i turn on my amps.its a high powerd amps i no but it stil does when i put in a new battery o brigde it with two.and i also dont have a remote with it.so if any one can sell me thier remote if your not using it.ill be happy to buy it from you.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 108 Answers
Make sure that you are running the engine every time that the stereo is playing or you'll deplete your battery's voltage. Also, make sure your alternator can supply the amount of current necessary to produce that kind of power. Amps X Volts = Watts is the formula you use to calculate this demand.
Posted on Aug 03, 2008
My amp have a 30 sec dalay when trun on
you have a delay as the current from you battery running to your amp is slow. if you buy a capacitor that will solve the problem as the current from the capacitor is faster than it is from your battery
Mar 02, 2011 | Kicker ZR600 Car Audio Amplifier
My jbl gto75.4 red light is staying on and no sound what can the problem be.
check the cord from deck to amp when you trun on the deck it should go from red to green some of amps you do need to run a blue wire from deck to amp. that the remot wire.. so you don,t need it going bysingle from the rca cable... I hope this help you out ty
Feb 19, 2011 | JBL GTO75.4 Car Audio Amplifier
Will not stay on
gwm_inc, Please verify all speakers work or are not shorting the outputs of this Yamaha 100w/ch amp. Also this unit could have bad capacitors and or failed output transistors if the speaker terminals or connecting cables get shorted. I would guess that the power supply is detecting a FAULT condition and is shutting itself down to prevent a catastrpohic, nonrecoverable failure event!! Best shot would be to have a technician evaluate unit. 12fixlouie
Jun 04, 2010 | Yamaha HTR-6030 Receiver
Radio works intermittenly,Sometimes all day,Then not at all. I have replaced Amp..Worked great for a few days.You think its the radio head unit?
had same problem in a dodge... turned out the interface module was bad. but try a relay on the amp trun on lead. there may not be enough power to trigger the factory amp
Feb 10, 2010 | Metra CHTO-02 Chrysler Pacifica 04-Up...
WANT TO PLUG IN A TRUN TABLE
Try using the AUX but you mightr have to buy a Phono pre amp first , then you connect the turntable to the pre amp and the pre amp to the AUX plug
May 23, 2009 | Yamaha HTR-5830 Receiver
Wiggle the positive wire to get power and have to unplug subs to turn car off
Ok it sounds to me that your remote wire is not hooked up right casue if you trun your car off then your amp should power down an when you trun your car on it should power up
May 07, 2009 | Car Audio & Video
Amps will turn on but cd player won't
if this is a stand alone cd changer, make sure you have the power wire running to an accessory that can handle the load, not the fuse your amps are hooked to as will be too much of a power draw, just step it over to another acc switch
Apr 28, 2009 | JVC KD-G140 Car CD Player
Kole kx2-1440 wiring da amp up right
It is correct to connect the amp turn on wire to the amplifier remote. 5V is sufficient to turn most amplifiers on... It should be 12V optimally.
If the amplifier is not turning on with the ant. remote, the problem is with the amplifier.
Dec 30, 2008 | Kole audio QX1-2400D Car Audio Amplifier
Settings
you will want to turn your radio volume up till you hear distortion then trun it down slightly. then turn your amp up until you hear distortion then trun you amp down slightly.
Aug 06, 2008 | Alphasonik PMA600HC Car Audio Amplifier
Kenwood KAC-9102D Car Audio Amplifier Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
