Back to:
Tags:
1999 Daewoo Lanos
Timing belt
posted by krazzle on Jul 24, 2008
timing belt
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 24, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
tiempo de los piñones
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on timing belt:
I don't want to Accept this solution
Solution #2
posted on Sep 15, 2008
Not Rated (0)
Brentonsmyth
Rating: 0%, 0 votes
Hi, I have a 1997, Daewoo celio 1,5 I and the cam belt snapped. I dont think that the pistons hit the valves but I cant be sure, I have a new belt and woud like some info on how to go about changing the belt and setting the timing on this car. I am not a novice mechanic but need some advise. Thanks Brent
Thank You!
Solution #3
posted on Aug 15, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
how to remove water pump from daewoo cielo
Thank You!
Can you Help with these Cars problems?
1999 Daewoo Lanos
i would like to know how expensive Daewoo Lanos 2...
1999 Daewoo Lanos
I would like to check the transmission fluid in my Daewoo...
1999 Daewoo Lanos
My car will not start and I was wondering if you know the...
1999 Daewoo Lanos
Car will not start at all it is not pumping petrol through
1999 Daewoo Lanos
1997 Daewoo cielo starts fine and runs well until hot then...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
