After a lighting strike the graphics card and modem fried.. ok thats fine can replace those but the computer will no longer shut down, goes through the process then immediatly restarts, goes through loading windows then hits a blank screen and stays there. I then have to press the reset/restart button and do it all again. It would then load the front screen with "start wondows normally" option and then would load fine but now i need to reset it about 7-10 times before it loads properly. Always the blank screen. Is this a mother board, graphics, or power problem. I am now too scared to turn it off in case it does not start agian!! Any help appreciated Thanks
  • 22 Answers
Suggest you format your PC and install a fresh copy of windows and update all the driver. If the problem still exist, most probably is the motherboard problem.
Posted on Jul 24, 2008
When i came home last night my system was on sleep mode. when i tried to wake up it would not do so. i restarted system. when it started i got the beeping that i usually get when something is loose inside...
try running from the on borad graphics(disconnect the graphics card from the motherboard completly) if the computer works ok and how should be after this then possibly look at the physical conection that was once between the motherboard and graphics cardand check for any physical obvious problems on the graphics card...i hope this helps kev
Nov 27, 2010 | Nvidia GeForce FX 5500 Video Card Graphic...
Ok so got black screen disconnected nvidia slot to on board monitor slot. seemed to be fine until restarted and back at black screen. sounds like loading upon startup. what say u?
The first thing you need to know about working on the inside of your computer is that if you don't ground yourself you can fry a graphics card and not even know it....You may have already done this....At the very least you should make sure that you're not on carpet and that you don't build up a static charge from your computer chair...If you build up a static charge like rubbing your feet on a carpet or sliding your **** off a vinyl computer chair...you can build up a static charge that can reach 30,000 volts......Yes, that little zap can do some real damage....At the very least...take off your shoes and socks and touch a friend or family member to make sure you don't have a charge.
You may want to turn off the computer...disconnect the graphics card...turn on the computer.....give it at least 15 seconds to a minute....(You won't be able to see anything)....Turn off the computer...(Hard shut down...Press the power button and hold it).....wait a minute and put the graphics card back in....turn on the computer....and hopefully your computer will recognize the graphics card and you will be able to see your system on the screen...Hope this helps....
Oct 29, 2010 | Computers & Internet
I am having problems with my nvidia geforce 6800 gt. When i turn on my pc everything is fine but whenever i play games for ex. Bioshock or counter strike source my pc screan turns off and says no signal....
i suspect youyr graphics card is heating up and shutting off to prevent damage. windows will also shut it off but usually repaorts that it did. here is my reccomendation:
1. open side case and place a fan right nest to it. if this makes it work then heat is definitely trhe culprit. if so install a video card cooler or another exhaust fan.
2 turn all the graphics options down on the game. shut anti aliasing off and all options to minimun. then try to play if it still shuts off then your card may be on its last leg from over heating. the 6800 gt was ok when it came out but todays games require more. in fact the newer games won't run on a 6800 gt.
the big thing is heat. the standard 6800 gt just doesn't get rid of enough heat. in fact the 9800 gt i had overheated and burned out. i stay away from gt and now use gtx cards. they have a better cooler and ususally the vent outside of the case.
May 15, 2010 | XFX GeForce 6800 GT, (256 MB) Graphic Card
Video card shut down
you probably need a higher watt power supply in your case. Most stock ones are only about 350 watt. you'l need like a 450 watt or better with that power hungry card.
Sep 17, 2009 | Palit Microsystems GeForce 9600GT, DDR3...
Monitor starts to come on and then goes to sleep. This started after a lightning strike very close by as I was shutting down the computer.
I think the monitor curcuit board or the graphics card has been badly damaged. Chek both or to do it call support.
Aug 15, 2009 | Computers & Internet
Internet Connection Issues
Very well could have toasted you network card. If everything else works, try installing a different one (and drivers) that is known to work. MM85
Jul 26, 2008 | HP Compaq Presario SR1820NX (ER919AA) PC...
Ethernet Port failure on Acer Aspire T180-GB7Z
Type of your O.S (Operating System) Windows, MAC, Linux Etc?
May 12, 2008 | Acer Aspire™ T180 PC Desktop
Lightning
In a nutshell, yes and not only to a Dell but to most computer brands/models. In some instances, it's only the modem, router, LAN card that gets fried while some gets everything toasted.
Incidentally, even a near lightning strike is enough to cause big problems.
Kind regards.
Dec 12, 2007 | Dell Dimension 2400 PC Desktop
My computer won't start?!
well if ytou were already using ur PC then may be the last time ur PC was improperly shutdown. this can cause many mail functions.
now 1st thing to do is remove all the hardware and just leave the Processor, Memory & Graphic card if Any. then start the PC if its power on then Motherboard is OK if wont then Dis Assemble all The parts and then assemble again and try as mention above if it still wont work then may b ur chipset of the board friedd out that you cant visually say its fried.
Dec 02, 2007 | Soltek SL-86SPE2 Motherboard
Nvidia geforce FX 5200 having poblems booting pc....
as your primary pc now has a working graphics card . I would guess your graphics card is fried in all honesty there is really no hope in repairing it especially for the cost of one of those cards, if you are simply using your second pc for non graphic intensive apps then I am sure you could find an ol pci grpahics card down the local dump for next to nothing hope this helps. Genius2k4
Oct 12, 2006 | Nvidia GeForce FX 5200 Video Card, 128MB...
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
