RCA HD52W140 52 in. Rear Projection Television
Problem for RCA HD52W140 52 in. Rear Projection Television
HD52W140 will not power on
By rsherrett1 on Jul 24, 2008
Much like many of the other posts here, my RCA tv will not turn on. I don't know any history of this television, as it was handed to me to see if I could fix. The report was, it was working fine and then one morning he turned it on and it was on for a few seconds and then "turned off" and would never turn back on. He did not recall hearing any strange sounds or smelling any smoke, it just quit.
There is no activity on the set at all. When plugged in there are no standby lights or any other sights or sounds. When the power button is pressed, nothing happens.
I have gone through the many posts here, as well as other forums, to try to get some idea of what might be wrong. The vast majority refer to the HV Splitter causing issues including a particular resistor blowing (R14705). I have checked that particular resistor as well as the leads and the traces on the board with a meter and they all seem to be fine. I am not sure how to check the HV splitter without just simply replacing it.
I'd rather not just do trial and error if I can check it to see if there is an issue. Does anyone know how to check the HV splitter for trouble before replacing it? Also, assuming that is not the issue, what other possible issues could be causing the tv to appear completely dead?
Comments:
Aug 06, 2008
- Update...
I checked the power supply and did in fact find a fuse that had blown. A small tube style fuse. I replaced the fuse, plugged the set back in and nothing happened. Still know response. I unplugged the set again and pulled the fuse back out and it was blown again.
This happened twice, except on the second attempt there was a spark on the board that the power cord connects to directly and there is a small black piece (sorry, don't know the names of all the small components on the board) as a little burn mark around where it connects to the board. The numbers on the component is KSP D6-226, I believe (the lettering is quite small). The number on the board location is Q24602 (again, I think...it is hard at times to determine which number goes with which location).
Unfortunately I don't have the necessary equipment to run the tests described above, although do appreciate the very thorough description.
Aug 06, 2008
- I appreciate the very thorough description above, but unfortunately I do not have access to the necessary equipment to run those tests.
However, I did check the power supply and found a blown fuse. Felt kind of silly...should have checked that first. So, got new fuses and replaced the fuse, plugged it back in, and still nothing. Unplugged it and checked the fuse again and the new one had blown already. This happened one other time, only the second time it also appeared to blow another component on teh board. A small black piece (looks like a small black cylinder, but cut in half length-ways, so when you are looking down on top it looks like a half-circle) with the numbers KSP D6-226 stamped on it.
At that point, I stopped putting in more fuses. Clearly there is something else going on there. Does this additional information change the suggestion at all, or are we still at the suggestions above?
Thanks...
Same Problem
Sep 08, 2008
-   WONT POWER ON-   Guest
Best Solution
posted on Jul 24, 2008
Helpful)
Shuttle83
Rank: Guru  RCA Expert
Rating: 85%, 982 votes
Hello rsherrett1,
Ok first of all the only way the trippler could have caused this was if it shorted, and you would have known if that happened, because of the fire that would have occurred. So let's go back to square one. did you check the primary power supply in the back of the chassis? check it first for a blown fuse. I you can not find that then disconnect the power connection to the high voltage board and secondary power supply (switching power supply) and see if you can get the supply rail to the secondary board up (you will need a schematic to see the voltage values that should be there. Now if that fails to produce results you will have to assume that the secondary power supply is the culprit (it usually is). The funny part about this is the one component no one ever tells you to test is the one you should test all of the time and that is the IHVT (Integrated High Voltage Transformer) some folks refer to it as the "flyback" transformer. Now one of the biggest problems happens at this point there are three tests that you have to run the equipment needed is a s follows:
1) an oscilloscope
2) Universal Signal Analyzer/Generator with Ring Test ports
3) A capacitance meter or a LCR 103 (I prefer the LCR103)
4) an ohmmeter
Now here is what you need to do to test the IHVT
1) Remove the IHVT from the circuit board (desolder it)
2) Remove the HV cable clamp (holding the HV cable to the base of the IHVT)
3) (Test 1) Perform a resistance test between the posts of the IHVT looking at the schematic to see which posts are wired to each other. (now this test is only good for pointing out open coil windings not shorted coil windings) if this test passes (no opens) go to test 2
4) (Test 2) perform a ring test of the IHVT. Now this is why you need the Signal Generator with ring test ports. Connect the cable from the ring test ports to the primary side of the transformer, see the schematic to determine the primary os the transformer (the side connected to (actually between) the Horizontal Output transistor and the power supply. turn the ring test actuator fully counterclockwise, turn the test selector to ring test and slowly turn the ring test actuator clockwise until the screen reads greater then 10 rings, if ten rings can not be achieved then the IHVT has a short in it and should be considered as bad and in need of replacement. if this test passes go to test 3
5) (Test 3) The last test is the capacitance test. This test is a test of the internal capacitance of the IHVT. This is measured from the HV anode of the transformer to the ground post of the transformer. connect the negative end of the capacitance meter to the ground post of the transformer and the connect the positive end of the capacitance meter to the anode of the IHVT (this is the end that the cable was removed from, You will have to use a probe with a wire attachment to it to make contact with the anode connection in the IHVT. Once that is done the capacitance meter should read around 2.7nf or above. A reading of .3nf means the capacitor is open. Note: However certain flybacks may have the value of 4.5nf, 6nf and 7.2nf and sometimes the internal capacitor pin is connected to circuits (feedback) instead of ground, so be aware of this when testing. If this test passes then the problem is not the IHVT.
However if any of these test fail then the IHVT is to be considered as bad.
Now if the IHVT is good, then you will have to test the following components and their respective circuits:
The Horizontal Output Transistor, The Switching power supply MOSFET, The switching power supply transformer (perform ring test just like the IHVT), and pay special attention to the capacitor on the 6 volt rail (This capacitor is known to go bad often) as seen on the circuit board, The schematic will have all of the part location numbers as seen on the board.
This is a logical start as opposed to the shotgun approach a lot of forums seem to lead to. Let me know if this helps you.
Thank you,
Shuttle83
Comments:
Aug 06, 2008
- Hello rsherrett1,
If you want to try to fix this we can, we will have to do this in steps. You may even have to send me components that have to be checked with the equipment I mentioned.
Send me some photos of the circuit boards and we can begin if you want to.
First let's start by checking the Horizontal Output Transistor (HOT). You will see the three lead component attached to a heat sink the writing will read Q(and a number) and have E B C (Emitter, Base, Collector) on the board where the leads go. Measure from C to ground with the Rx1 setting of your ohmmeter (the reading should be very high) if it reads 0 ohms then you have a shorted Transistor. If the transistor is shorted you will have to replace it first and then replace the fuse. That still is not everything but it is a start in the troubleshooting process. let me know how this goes. Because if you see that the HOT is shorted this may have shorted out the IHVT (Integrated High Voltage Transformer) too.
Let's see where this takes us.
Thank you,
Shuttle83
Was this helpful?
Yes
No
Popular Solutions for RCA HD52W140 52 in. Rear
Questions and Unsolved Problems for RCA HD52W140 52 in. Rear
Do you recommend RCA HD52W140 52 in. Rear Projection Television?
Answer
Answer
just wonder where i can buy or order this and if it's ez to do urself?
Answer
my rca tv wil turn on sometimes other times it acts like its going to turn off but it just turns its... (More)
Answer
picture is fine but there is like a white noise sound like a fuzz when there is no reception.it just... (More)
Answer
tried turning on the tv but it only clicks like its going to turn on but then it clicks again and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For RCA HD52W140 52 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 821
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
