Question about Cingular Wireless Cingular 8525 Smartphone
8525 Camera button
I just received my 8525 used, and up until today the camera worked fine. Now, it randomly opens the camera. Sometimes it will start snapping pictures on it's own, other times it just sits there. I can not manually take a picture. I tried setting the timer option, but in order for that to work you need to push the camera button. It's almost as if it's stuck. Is there maybe a setting somewhere that I messed up while playing with everything?
  • SweetChild75 Jul 24, 2008
    I followed your directions. I set the button to and tried going to camera via start. It opens the app just fine, but I still can not take a picture.
    Novelist:
  • 167 Answers
Go to Start -> Settings -> Personal -> Buttons
change the option for the camera button to 'None' or make it blank.
Now start the camera through regular start menu program list, see if that helps
Posted on Jul 24, 2008
  • Steve Stonebraker
    Steve Stonebraker Jul 24, 2008
    to take a picture hit the button between the navigational buttons, see this picture:
CameraWindow won't open or will suddenly close before loading
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jun 03, 2012 | Canon PowerShot S90 Digital Camera
I dropped my phone in the pool, got a new battery for it and it worked fine untill the battery ran out and now it will not charge or turn on (lg xenon)
Since it's a new battery it might be the battery. If a battery will fail it will do so with the first 30 days of use. It sounds like you have never charged it before. You should bring it back to the store for a replacement to test it if possible with another phone. But since the phone suffered water damage the real issue is most probably the phone. If a phone gets wet sometimes it will work fine for a while after it dries or it won't work at all. But even if it does work you could start having random issues with it everything from random shutdowns/reboots, can't charge, can't stay on to issues like preventing you from receiving txt msgs or using the camera or media player. You might have to start shopping around.
Jul 07, 2011 | Cell Phones
Fuji Finepics E550: Menu buttons sometimes do not work.
could be the ribbon for the keypad has come loose from it's socket if it is affected randomly. Or it could be dirt or moisture on the keypad membrane affecting it. Only way to be sure is to open it up and have a look
Oct 05, 2009 | Fuji FinePix E550 Digital Camera
Camera wont turn off
Remove the battery. The same thing happened to mine and once I put the battery back it worked fine.
Dec 31, 2007 | Vivitar Vivicam 5105s Digital Camera
Samsung S630 junk
the beeping is the battery being dead but the black screen with random stuff sounds like the LCD panel is busted. i work at a repair shop and have the same problem with my samsung s630 major problem...lcd panel is not available anylonger for that model.
Dec 25, 2007 | Samsung Digimax S630 Digital Camera
Printer not working!
the printer is certainly having s connection problem  and the camera is not able to connect
Jul 03, 2007 | Samsung SPP-2020 Thermal Photo Printer
C-8080 Turns off/on randomly..
Hi Galaxy,
Try running camera directly on DC from charger and see if it stays functioning.
If it does, they you either have:-
1) a faulty Lion battery
2) the battery detect circuit in the camera is faulty (reporting low battery and forcing shutdown)
3) the power switch on top of the camera may be leaky or partially collapsed
4) internal power supply circuit in camera has developed a fault.
Good luck...hope that the issue is the battery.
Kiwi-Mark
Jun 05, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Problem taking pictures
The only solution is to ask the help from Authorized Sony Service. If you need more info please advice. Arpi
Feb 26, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Lumix DMC FX8 lens cap opens intermitently,some images shoot rotated 180 degrees
hi, i've an fx8. i had a problem 2 weeks ago. my objective didn't want to close when i switched the camera off. it remained open. when i switched the camera on again, the objetcive has closed and opened again, and the _Turn Off the Camera and Turn On again_ message appeared on the sisplay. and remained in open position after switching it off. i tried some button combination, like menu button on, and power the camera on. it didn't work, but the second was the shotting button on, power on combination. an it worked, my camera did some kind of reset. it returned to the original position, and everithing is working since then.
Feb 12, 2007 | Panasonic Lumix DMC-FX8 Digital Camera
Cingular Wireless Cingular 8525 Smartphone Logo
Top Cingular Wireless Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
fordexpert
Erik Walters
Are you a Cingular Wireless Computer and Internet Expert? Answer questions, earn points and help others
