Question about Whirlpool Dryers
The dryer belt broke and the plastic piece to the belt tensioner broke. the model is LGN2000LWO, SER# MP3817457,TYPE:BWSR-NAT-1206006-CV22.WHERE COULD I PURCHASE THESE PARTS IN EAST PEORIA AND/OR PEORIA,ILLLINOIS ?
    Genius:
  • 1,028 Answers
Sears..belt part #341241 probably and idler 691366 i think
Posted on Jul 24, 2008
MR0849046 DWSR-NAT-1206006-CV22
Could be the element or any of the fuses.
Jul 12, 2014 | Kenmore Dryers
Notice a "rubber"smell this winter. The lint vent is clean after each use, outside vent is clear of any debris. can the wind blow smell back into house or is it a belt? Installed new by dealer 1/9/13.
I have found that when people start smelling things in the dryer it's from chemicals from like paint or varnish,all the dryer does is move air when it gets hot you start smelling it.you can pull it apart and check the belt and rollers but your dryer has the lint filter on top and there isn't anything in there that could really make it smell,on some of these dryers the belt pulley doesn't have a wheel on it,the pulley is just a piece of metal with no moving parts and the belt rubs on the pulley but i've never smelt anything from that,like i say usually it's from having your floors done over the smell from the polyurethane coating or from paint can make the dryer smell.go here to take dryer apart
http://www.youtube.com/watch?v=xGIG8Wo5-N4
hope this helps
Jan 19, 2014 | Whirlpool Dryers
Dwsr nat 1206006 cv22 fm22 whirlpool ser
take a picture or more info where is it center side back wall ?
Nov 09, 2013 | Kenmore 74602 Gas Dryer
Hi more info. I posted wrong. my dryer is model 11079912990. ser # mj1607152. type ddot-nat-1206006, cv22. 120 volt, 60 hz. 22000 btu .27 inch wide kenmore gas dryer. The dryer would run for a few...
You could have a blown fuse because of a clogged vent or a bad thermistor. A thermistor is used by electronic controls to measure temp changes inside the dryer. If the sensor is open then the brain does not have a clue how hot the dryer is. So it shuts down. Repair clinic has an excellent thermistor replacement video.
Oct 25, 2013 | Sears Kenmore 7.3 cu. ft. Gas Dryer Model...
Whirlpool dryer dwsr nat 1206006 fm22 will not turn on when on button is pressed. There is a black plastic piece to the right of the metal catch on the dryer that if pressed the right way, the dryer will...
The peice your refering to is called a door switch, and its a pretty easy repair. You'll need your model number handy, and then contact a local parts distributor in your area. Once that is done, if your dryer is a standard whirlpool, you'll just take the two screws out of the top by the lint trap and pop the top up. Once thats done look down to the right and you'll aee the switch which is held in by two screws on the outside portion of the door.
Apr 28, 2012 | Whirlpool Dryers
Type:DWSR-NAT-1206006-CV22. The Kenmore gas dryer runs and spins but does not heat up -the clothes remain wet. Lint is not the issue . Iclean the lint trap every load. I also vacuumed out the coil vent ...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 03, 2011 | Dryers
Light comes on wont spin wsr-maytag mod m6d5600tqo ser mw2607338 type bwsr-nat-1206006-fm22 light wont turn off even with door closed dryer is not old new in 2008
Check the door switch. It just might be sticking which is why the light remains on and the dryer won't spin...
J. Lewis
Dec 21, 2009 | Maytag Dryers
Change the digital read out for time and charge.
There are actually two hidden buttons that you cant see below the start button... Change the amount to what you prefer and press the hidden button across from the low temp. button twice.
Hope that helps, Mike
Nov 19, 2008 | Dryers
Dryers Logo
169 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
