Sony Playstation 3 (PS3) Console Logo
Posted on Feb 12, 2011
I was playing modern warfare black ops and the system decided to randomly shut off. When it did this it beeped 3 times and shut off and the red light just stays blinking. It will not eject the cd or turn back on. When you turn it on the light goes green for a second then beeps and shuts back off, what happened?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Feb 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
673
Points
28
Your console has an overheating problem. send it in.
1helpful
Call of Duty Black Ops II will not play online
Crowded servers lead to this issue, try connecting at a different time.
My PS3 won't play Call of Duty Black Ops or Modern Warfare anymore. It was playing them just fine then one day it stopped. The game loads and then just goes to a blue/black screen and makes noises. The...
I would take the game to a friends house and see if they work their. If they do, then your PS3 must be having some issues reading the Call of Duty formats. If they do not work, then you know it's the disc and it needs to be replaced.
2answers
HOW DO I UNLOCK ZOMBIE MODE ON MODERN WARFARE 2 ON PS3
there is not zombie mode on modern warfare 2 its on call of duty black ops
2helpful
My PS3 (40Gb) has just shut down on me. I was playing COD Modern Warfare 2 when the PS3 just shut down and then beeped at me 3 times the red light started flashing and when I pressed the power area the...
Its called yellow light of death. Here is a link to my step-by-step instructions on how to fix.
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
Playing call of duty modern warfare 2 and in the midle of online play it just shuts off now i turn it on the green light comes on then turns to amber then back to red whats the deal.
Yep, this is the red light error and it is caused by overheating on the main chips - you can stop this by using a good repair guide or by sending it in for a fix.
1helpful
Error creating session. wind i go online or multiplayer willnt read or go online
Hopefully this will help solve your problem:
1. Press and hold down the power button located at the front of the PS3 console, until you hear a first beep, then eventually a second – before the console shuts down, then let go of the button;
2. Now press and hold the button again until you hear a first beep, then a second beep then eventually a quick double-beep, then let go of the button;
3. The TV screen should now display a six option menu, where you can select what’s required, i.e. `Restart System`, `Restore System` etc. `Reset System` should only be used after other attempts with the other options, as your game saved data may be lost. If you play Modern Warfare 2 online, then this won’t be affected as your data is saved on the Sony Server.
4. During any of the above actions, your best having your handset controller connected to the PS3 via the USB cord, which includes pressing the `P` button when required (located between `Start` and `Select`).
These actions should help solve `freeze` problems and others such as update errors etc – which restrict you starting up or playing your console.
Don’t hesitate to contact Sony UK if required, who are very helpful. Their UK number is: 0844 7360595
Good Luck!
4helpful
2answers
Xbox 360 wireless controller left analog stick problem
Thats how modern warfare is made, I also had the same problem. Try keeping it pressed for longer instead of letting go early.
PS3 Turning off at random(overheating?)
your ps3 could be in the process of breaking i got the ylod just last night your warranty has expired you could just run your ps3 untill it breaks then open it up and try to repair it but thats a tricky thing to do. and dont leave games in it incase it breaks they will be trapped inside, my modern warfare 2 is stuck in mine -.-
Ps3 shutdown
i do not know what is wrong
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
