Question about Compaq ARMADA M300 11.3" Flat Panel LCD Monitor
Armada m3000 screen
Screem iss broken
  • 119 Answers
You can mess around and try to fix it but on those old machines its really not worth it(I own 5 of these).Might I suggest the Armada M700 or the E500--e500 is what im on now and it runs better than a brand new dell or compaq)you might get a new screen on ebay for about 40 bucks. It might be a better idea to buy a new one and save the parts from your old one. You can get a new one for 70 bucks on ebay.
http://cgi.ebay.com/COMPAQ-ARMADA-M300-Intel-Pentium-3-LAPTOP_W0QQitemZ200297181300QQcmdZViewItemQQptZLH_DefaultDomain_0?_trksid=p3286.m20.l1116
Posted on Jan 18, 2009
2010 Malibu error codes po700,po716,po717
DTC P0700: Transmission Control Module (TCM) Requested MIL Illumination
Which one of these transmissions does your Malibu have ?
Automatic Transmission - 4T45-E
Automatic Transmission - 6T40/6T45
Automatic Transmission - 6T70/6T75
Do you know how to find out look at the VIN # ?
DTC P0716: Input Speed Sensor Performance
DTC P0717: Input Speed Sensor Circuit Low Voltage
The automatic transmission input speed sensor (ISS) is a permanent magnet with a coil of wire wound around. The ISS mounts in the case cover facing the reluctor wheel of the input shaft. As the reluctor wheel is driven by the turbine shaft, an AC signal is induced in the input speed sensor. Higher vehicle speeds induce a higher frequency and voltage at the sensor. There is a fixed air gap between the sensor and the teeth on the sensor reluctor wheel. The ISS input is used by the transmission control module (TCM) in order to control line pressure, torque converter clutch (TCC) apply and release, and transmission shift patterns. This sensor is also used to calculate the appropriate gear ratios and TCC slippage. This diagnostic indicates stuck, erratic, or intermittent conditions in the system.
Diagnostic Aids
• Road test the vehicle while monitoring the Transmission ISS parameter on the scan tool. The Transmission ISS parameter should vary with engine speed changes and not abruptly drop out.
• Inspect for an open or shorted AT ISS wire.
• Inspect for a disconnected AT ISS connector.
• Inspect for a faulty AT ISS.
Trouble Code P0717 Input speed sensor
Jan 19, 2017 | Cars & Trucks
24:10 code error
The system error 24:10 is a critical error in which the printer cannot be used until has been corrected.
Turn the printer on in Diagnostic Mode. Turn On the printer holding down Power + Cancel + DOWN buttons until you hear one beep before releasing ALL three keys.
Note:This could take few attempts to find correct timing on holding the buttons down, remember to hold the down key and cancel key and then hold the power button key so all 3 buttons are pressed until bleep at 5 seconds then release. Each attempt you have to wait for boot up to see if it powers up to the below diagnostics menu.
Scroll down to "Service Special Utilities" and select OK
Scroll down to "Bag Broken Recovery" and press OK to start the process.
Note: This procedure will only help if problem is just with a ink carriage just been fitted in the last 6 hours.
The front panel will display a series of questions which you answer Yes or No depending on the status of the printer. Use the Up and Down arrow keys to select Yes/No and the OK key to confirm the selection in each case.
Remove the Ink Cartridges and check for any ink leaking from the cartridge. In extreme cases ink
can contaminate the ISS PCA area which will then require instalIing a new ISS PCA.
If the message 'Please replace one of the defective cartridges (*). The asterisk represents a
number which will identify the failed ink cartridge.
Number displayed Ink Cartridge Color Failed
0 Magenta
1 Light Magenta
2 PhotoBlack
3 Matt Black
4 Yellow
5 Light Cyan
6 Light Gray
7 Cyan
  • Question 1:'Are the Tubes from the Air Pressure System (APS) to Ink Supply System (ISS) Clean?' YESIf the tubes are clean of ink select the Yesoption. However if the tubes have sections of tubing that have ink in them, select the Nooption and replace the Tube assembly.
  • Question 2: 'Do tubes from the ISS to Carriage contain visible air?' NOIf the tubes between the ISS and the Carriage Assembly do not have air bubbles, or clear sections of ink tubes where air is present mixed with ink, select the No option. However if you can see air in them, select the Yes option and replace the SRK assembly.
  • Question 3: 'Do you want to remove the broken bag condition?' YES At this question select the Yes option to clear the broken bag error.
To finish the procedure select any key on the Front Panel and the printer will shut down.
Insert the new Ink Cartridges into the printer and turn On the printer.
Note: If the Tube assembly needs to be replaced, the Broken Bag Recovery procedure will still need to be performed after they have been replaced.
If you need any more help or service please contact 1st Call 4 Service Ltd.
Feb 15, 2014 | HP Designjet Z6100 InkJet Printer
HP Designjet 110 inconsistent printing of magenta
>Check ISS pumping, >Check ISS tubes is there air gap?>Check cartridge bag broken in side?>Check for leakage at cartridge bank & carriage assm.>Do the following force priming to fil ink in tubes as well as in print heads:****Hold the power button down and press the cancel button three times and the resume button three times.****Switch Off the printer and then On again in order to start the priming of the ink supply tubes.
Jan 04, 2012 | HP DesignJet 110 Plus NR InkJet Printer
My HP DesignJet 500 plotter printer doesn't recognize any of the 4 ink cartridges
>Your have new cartridges,not refilled right?
>Remove cartridges,
>Remove right door,
>Check ISS unit cables,PCB & connectors as shown in snap shot,
Most of the cases ISS arrested with ink leakage from cartridges, result connectors,PCB tracks & cables got damaged.. check perfectly if found shoot the problem....
> Replace ISS unit,, But only professionals can do the replacement..
*** Reading, writing & initializing the backup EEROM located in ISS unit, if any thing goes wrong both ISS & Formatter assm will loose their memory..be careful..
Dec 05, 2011 | HP DesignJet 500 InkJet Printer
HP DesignJet 500 - Printer will not recognize any of the four ink cartridges
>Remove cartridges,
>Remove right door,
*** Reading, writing & initializing the backup EEROM located in ISS unit, if any thing goes wrong both ISS & Formatter assm both will loose their memory..be careful..
Screem Comes on brefly and then fades to black
go to control panel and click on screem after click on screem saver select none or try configurate to more time for to active the screem saver, and if it is not that you must take it to a technician
Jul 15, 2009 | Sony STYLEPRO SDM-S91 19" LCD Monitor
What causes an error 24.10 on a designjet 4500ps
System Error: 24:10
Problem
Description:
Broken bag detected in Ink Cartridge.
Corrective Action: Try the following:
�� Remove the Ink Cartridges and check for ink leakage in the ISS area.
�� Perform the "Bag Broken Recovery" Diagnostic (→ Page 4-51) to further
troubleshoot the error code.
Download the service manual at: www.lpscomputer.com/ec/manuals.htm
Jun 11, 2009 | HP Designjet 4500ps InkJet Printer
The screem has broken and it can not power on
well you need to get a new LCD panel for your Armada M700. You could get something like this from eBay:
http://cgi.ebay.com/Compaq-Armada-M700-Laptop-For-Parts-or-Rebuild_W0QQitemZ360053106104QQihZ023QQcategoryZ177QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
(hurry....less than 8 hours left)
You could do this yourself if you are technically inclined.
May 23, 2008 | Compaq Armada M700 Notebook
Compaq ARMADA M300 11.3" Flat Panel LCD Monitor Logo
553 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
