Question about Haier hwr10xc6 Air Conditioner
I have an E8 error message on my Haier hwr10xc6 Thru-Wall/Window Air Conditioner
Was wondering if you knew a fix for this?
  • CManry Jul 25, 2008
    No not running and after sitting all night I am getting the E-1 error. Thermostat is not kinked.
    We actually drained it thats when it stopped because it froze up. Now apparently that means we did not have it angled like we should have but the way the AC is built it sits flush in the window if it should have been angle I would have thought they would build it that way :)
    Anyway there is a fix for the E-1 error do you have one that is easier to understand. I found the big post there too hard to follow...not mechanically inclined but very hot so lol I am willing to try.
I had a problem with my Haier Air Conditioner also and was getting an E8 error message. We had taken the air conditioner out to clean it and when we put it back in all we could get was the E8 error message. We tried several different things so I don't know if it was a combination or luck. Here is what we did.
First we tried holding in all the buttons on the panel and another person hit the on/off button on the remote (per a suggestion on the internet). The fan stayed on, but the compressor would cycle and it would get cold for a few minutes then kick off, but we never could get the buttons on the control panel to work. Nothing happened when we pushed them.
Then we checked the thermostat (the little tube in the front) . The thermostat tube was touching the coils. We rearranged the tube so it was not kinked or touching the coils. It was then getting cold, but we couldn't control the buttons. So we unplugged it (reluctantly because it was cool then) and plugged it back in and it started working. Hope this helps someone! I don't know if what we did worked or the mother board got wet and just happened to dry out or something.
Posted on May 09, 2009
The e8 code has something to do with getting the control board wet. When u try to do it wit the controls on the unit nothing happens. But u can still use the remote to turn it on and adjust the fan and cooliant settings.
Posted on Jun 29, 2009
Hmm E-8 don't now that one...Duz it still run at all..??? would check for build up on inside coils,,, and is small capillary tube "thermostat" in little plastic bracket and not kinked or touching the coils inside under the filter screen"evaporator"? did unit drain ok outside slightly lower than level ??
Posted on Jul 25, 2008
Can someone please tell me if this amp is an easy fix?
I would Scrap it most of the parts look fried from this picture
May 12, 2015 | MTX RFL600D Car Amp
Hi, I was wondering if you knew anything about the 3com routers. There is literally nothing on the internet of any kind detailing information about them, they're from Taiwan or something. I was wondering...
Traditionally, they are more of a corporate supplier than consumer product in my experience. When I had dealings with the devices they were more complicated and more robust ... I have not seen a new device for a long time. This is not my line of business, however. If you are a consumer, I much prefer LinkSys and D-link products.
I used to know about the internals of the 3Com ... has gone by the wayside.
Feb 06, 2011 | Computers & Internet
I have a Sony Vaio labtop model number PCG-7V1L that seems to have a motherboard problem. I am a network techinician in college so i know a bit but i was wondering if anyone knew if this was a common...
try with out battery.
if no results its been overheated and the board damaged.
could be a bad harddrive. run a disk on drive.
if you don't how. go to you-tube look for video to do that
Jul 31, 2017 | Sony VAIO VGN-FE890 Laptop
2000 Chevy Impala rear right door doesn't lock manually or auto
first the door panel must be removed to gain access to the lock linkage.after reading your post I would be willing to bet the linkage or the retaning clip broke.It is a pretty simple system.
Jul 26, 2009 | 2000 Chevrolet Impala
1997 firebird my tachometer dosent work
the conection fro a tach is on the negative side of the distrubutor somtimes they come lose
Jun 10, 2009 | 1996 Toyota Camry
MP210 canon printer showing E6 error
it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release it.
Mar 15, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Blank screen with coulered lines on it
I guess you need to have the software re-installed!!
Oct 07, 2008 | Sony Ericsson K800i Cellular Phone
98 Ford Explorer Brake Line Twisted
This hose located at left front behind the brake disk, when the repair man fix your break who didn’t put right, when he put in was twisted.
  1. Do you know how to put a pat on you disk?
  2. Do you have tools to fix your brake?
If you know and you have the tools, that you can try, and I am willing to help.
Jun 26, 2008 | 1998 Ford Explorer
Haier hwr10xc6 Air Conditioner Logo
2,308 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
