Question about Toshiba DP80F Printer
Power supply cable
I lost the power supply cable for the Toshiba Fax Machine DP80F, any specification for the cable. I did test using CPU power supply cable but failed although it can fit nicely to the 3 pin socket. Please advice, thanks.
  • Toshiba Master
  • 643 Answers
The power cable using is the normal 3 pin power chord used on computer.
U need to check the power chord and the wall socket...
Posted on Feb 26, 2009
Can I block junk faxes on a DP80F Fax
I suggest a informative links please visit and read it.
Block Unwanted Junk Fax Numbers and HP Printer Support
Thanks,
Sep 10, 2014 | Toshiba DP80F Printer
Screen says memory overflow, what do I do?
You have Fax's in the Buffer that need to be cleaned out and or Printed. Clear Memory will do both but if you have Fax;s that should be printed, then you need to print your Que..
Jun 19, 2014 | Toshiba Dp-80f - *220 Volt Commercial...
Can i recieve a fax in color for a toshiba dp80f
This device is a group 3 fax and therefore dont support colour only group 4 faxes support colour and there are not many about . if the person sending has a group 4 fax there'splenty of fax software for the pc about that will receive group 4
Jun 01, 2012 | Toshiba DP80F Printer
How do I print a journal for a specific date or number for the Toshiba DP80F?
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Apr 08, 2011 | Toshiba DP80F Printer
Toshiba fax dp80f power failure what is and how to fix?
just switch one machine then press STOP button on controll pennel.
Mar 03, 2011 | Toshiba DP80F Printer
How do you program the one touch buttons on a DP80F Fax Machine
please go to MENU 32 and follow instructions on desplay of the machine.
Oct 26, 2010 | Toshiba DP80F Printer
Where can I get the entire user manual for the
you can down load it from toshiba.com
Jan 12, 2010 | Toshiba DP80F Printer
Toshiba dp80f-Drum unit warning
menu, 5, 2, 0, 4, 1, enter
This will reset the counter for the drum unit.
Feb 12, 2009 | Toshiba DP80F Printer
BROADCAST FAXES
http://www.eserviceinfo.com/downloadsm/20153/Toshiba_DP80F%20DP85F.html
Sep 17, 2008 | Toshiba DP80F Printer
No LCD display at all on my Toshiba Dp80f fax
Once your open up the machine (like how u change toner kit),u will see a connector connected the LCD display to the base machine. Makesure the connector is firmly plugged.
May 29, 2008 | Toshiba DP80F Printer
Toshiba DP80F Printer Logo
81 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
