Have you check the fan blades?, is the fan loose at the motor shaft?, check inside the pipe of the blower housing for blockage. did you replace the thermal fuse alone or as a kit?, are ALL the seals in place including the blower seal?. after checking all that try to run dryer without the vent pipe attached and see if it hold.
did all of the above, hose is only 3 ft. long and clear. current draw is aprox. 22 amps when heater is on and 6.5 when off. operating t'stat cycling on at aprox. 115 degrees and off at aprox 155 degrees at lint trap. air flow appears to be good. I dont know what else to check.
what happened when you ran the dryer with the disconnected vent pipe?.
