Question about Sharp Office Equipment & Supplies
The ribbon with the numbers came loose. at what point of the ribbon do you replace it so that the numbers line up properly.
  • bkplus Jul 24, 2008
    Sorry I am trying to fix a Sharp EL-2192RII calculator.
  • Sharp Master
  • 19,396 Answers
  • Ginko
    Ginko Jul 24, 2008
    Here is picture at the bottom of manual:
Wincor nixdorf 4915xe, i get "carrier error" on display, occasionally. what is this error pointing at?
Carrier error relates to ribbon. If ribbon is very loose or not properly installed it will give carrier error. Reseat the ribbon assembly and tighten the ribbon using knob available on top side.
Oct 14, 2014 | Office Equipment & Supplies
Premier deh-p960mp
Not properly in place the screw / the unit cover to exact point..
Apr 14, 2008 | Pioneer Premier DEH-P960MP CD Player
How to fix display on Dterm80
Ribbon cable inside phone to display sometimes gets jarred loose. If you can remove the base, then unscrew the 2 screws holding the display in place, then slide it out and look for the ribbon cable being loose. If you have small hands maybe you can get that back to its spot. Better yet buy a replacement phone on eBay for 25 bucks instead of hoping it'll go back in and work properly. Some displays go bad line by line, in which case there's no help for it.
Jun 03, 2014 | NEC Dterm DTP 16D-1 Corded Phone
I HAVE PRINTRONIX P5005B PRINTER, RIBBON IS NOT MOVING
Check to see if the plastic ribbon hub is loose on the ribbon motor shaft. The plastic hubs will crack and while the motor shaft turns, the hub will not. If so, replace plastic ribbon hub.
Nov 27, 2010 | Printronix Line Matrix P5005B Printer
Dear i have same mobile.. but now a days there is problem on the front screen of mobile dat there is lining is showing.. i cant see main display properly tere is some light lines on the display.. plz ans...
check the flex/ribbon wire of the LCD may be loose or damage. but if try to use a good LCD, your LCD may be damage and need to replace with a good 1...
May 24, 2010 | Nokia 6131 Cellular Phone
My Kitchen Aid modelKGRC608LSS is not working on
Well it sounds like it is either the control key pad or the ERC(control module) is defective. The first thing you will need to verify is the condition of the ribbon cable that goes from the control pad to the ERC. You will need to unplug the range from the electrical outlet and then remove the back panel of the range. Now inspect the ribbon cable for any visible defects to it. Sometimes the cable will arc across itself and cause a short. Inspect each one of the lines(wires) on the ribbon cable and make sure they are not shorted. Now check to make sure the cable is found properly seated. If it is found loose or mis-aligned then remove and re-install it properly. You can also use a pencil eraser to clean the contacts on the ribbon cable while you have it dis-connected. Also verify that the wiring harness is properly seated and there is voltage going to the ERC. Hopefully these steps might get the range working again. The top burners/igniters can still work even if the touchpad or ERC is bad because they do not control the circuits for the igniters(they are mechanical switches) and mechanical burner valves. If not you might need to replace both the ERC and the Touchpad in combination to get the range to work again.
Apr 11, 2010 | KitchenAid KGRC608LSS Gas Kitchen Range
My pro 2096
I have same problem. First unplug and then turn radio on to clear any left over power. Open the radio by removing 4 screws on back, then 4 more screws to remove top of inner case. then you will see a white ribbon cable. This has either come loose or it is not lined up properly on the connector. There are tabs on each end of the connector, you will need a super tiny screwdriver like for use on eyeglasses to open the tabs. Slide them towards the display or front of radio to remove the ribbon cable. I then used some alcohol and a q-tip and cleaned the metal contact point. then I slid the cable into place, and being careful not to touch anything inside radio, turn it on and check display. It took some moving around for me but finally got it to come back. Then close tabs on connector to hold ribbon cable in place. It seems to be a common problem with this radio.
Jun 04, 2009 | Radio Shack Pro-2096 Base Scanner
Zebra S500 not sensing media
download the driver www.seagullscientific.com
recalibrate media, if necesseray Reset to Factory defult.
Apr 02, 2009 | Zebra Stripe S600 Thermal Label Printer
Balck lines
Yes, this is an LG/Zenith unit. You have one of two things going on here. 1) the X-driver board for that segment has failed (this is the board that the ribbon cable plugs into) or 2) the COF has failed on the ribbon itself. If you remove the two screws holding the metal plate that is attached to that ribbon, you will see components embedded in the ribbon. The ic may be visibly damaged or may have failed internally. Also, there are surface mount resistors on there too. Sometimes these open up, or are loose. Check for proper value and/or touch-up with soldering iron.
When neither of these solutions work, then the complete pdp display assembly will need to be replaced. Chances are the warranty company will replace the unit for the customer due to cost and/or part availability...Jeff :-) Recommend a trained person to check these
Jan 05, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
61 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
