Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Closed caption for sony trintron analog tv
I'm not able to bring the cc on in my TV. I went to the menu and selected the caption to CC1 and it is not coming.
Closed Caption will not turn off. Model: Sony Trinitron
Posted on Sep 04, 2008
How do I turn off the closed captioning?
Press the closed captioning button a second time.
Mar 20, 2016 | LG 47LS4500 47 Inch 1080p LED LCD HDTV -...
Can I turn the caption mode off with the remote?
CC (Closed Caption)
To select the options in the CC sub-menu, press the MENU button or the #
button. A new menu will be displayed showing the following CC settings:
CC
The CC feature is available when watching regular analog (NTSC) TV.
Select from CC1, CC2, CC3 or CC4. Closed Caption for regular TV is
usually CC1 or CC2.
Digital CC Style
The Digital CC Style feature is available when watching digital TV.
Select either As Broadcaster or Custom. If Custom is selected then
you can customize the way Closed Caption is displayed.
Feb 14, 2015 | Vizio VF550M 55 in. LCD HDTV
I haven't been able to put closed captioning on tv. I don't understand how and what code to use to get the closed captioning to work.
Enable Caption Using the Original Remote
  1. Press the [CCD] button to change the CCD mode.
  2. Using this button will set the Closed Caption mode when viewing a DTV or TV channel.
Enable Caption Using the TV Menu
  1. Open the Menu screen, select the third icon, in the middle, this is the Setup Menu.
  2. In the Setup Menu, choose the Caption option.
  3. Caption: There are three items in it - Analog Closed Caption, Digital Closed Caption and Digital Caption Style
  • Analog Closed Caption: CC1, CC2, CC3, CC4, TEXT1,TEXT2, TEXT3, TEXT4.
  • Digital Closed Caption: Service1, Service2, Service3, Service4, Service5, Service6.
  • Digital Caption Style: There are two Caption Styles. One is the automatic function set as the broadcaster, while the other is the custom style where you can adjust the font size, color, opacity, background color etc., accordingly.
Mar 10, 2011 | Element ELC-HS321 32 in. LCD TV
Can't turn off closed captions or find option to do so please helphelp
hi,
u can remove the closed caption optoin by the following setup.
1.Press the CC button on the remote to display the current Closed Caption setting.
2.Press the CC button repeatedly to choose from the four Closed Caption options (CC
Off, CC1, CC2, CC Mute). select CC off.
3.When finished, press the STATUS /EXIT button to remove the menu from the TV
Dec 26, 2010 | Philips 32PT6441/37 32" TV
My brand new Insignia tv has closed captioning that will not turn off. I followed the instructions in the manual but the menu item under settings can not be selected. Please helpw
You can use the TV buttons to get access to close caption by pressing menu. go to features make sure that cc when mute is on.
then use the mute button on your universal remote to toggle to cc1 or off.
May 21, 2010 | Televison & Video
Can not get Close Caption to dispaly>
CC in the TV will only work while watching the TV's antenna or cable inputs; not the video inputs.
May 08, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Closed caption
CC (Closed Caption)
Press the down button to highlight the CC (Closed Caption) selection.
Press the > button. A separate menu will appear with the following CC
settings
CC
When watching regular analog (NTSC) TV, the CC feature is available in the
Setup menu.
Press the down button to highlight the CC selection.
Press the > button to select CC1, CC2, CC3 or CC4.
Once the adjustments are completed press the LAST button repeatedly to exit
the OSD completely.
Closed Caption for regular TV is usually CC1 or CC2.
Mar 02, 2010 | Vizio VO42L 42 in. LCD TV
Cannot turn off Closed Caption
Here's the copy on CC from my manual LC-32SB23U.
1. Press CC.
This will present the Closed Caption information display.
2. Press CC while the Closed Caption information is
still on the screen.
Press repeatedly until you select the desired closed
caption service.
INFO BOX ON THE SCREEN,
Air ANALOG
Audio : MONO
CC : 1/2 CC1 ------ Closed Caption information
Ratings : NONE
Example:
If a program has three services (Digital CC(ENG), CC1
and Text1), the closed caption display will toggle in this
sequence:
1/3 ENG -- 2/3 CC1 --- 3/3 Text1 -- Off
The CC button keeps a record of the last service
selected in its memory.
If the last closed caption mode (e.g. 1/3ENG) you
selected is not available for the next program, or on
another channel, the closed caption service that is
available is automatically selected, and this service
appears in parentheses, e.g. “1/3(CC1)”.
Closed Caption services that appear in parentheses will
not be stored in the CC button's memory as your last
selected service. Only services that you have selected
with the CC button are stored.
If this doesn't work, the TV may need a software upgrade.
I can get you a copy of my manual LC-32SB23U for you. But, are you sure there is and "A" in the middle of your model number?
Jun 02, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Subtitle
Analog:
1. go to setup menu
2. press the DOWN menu button to highlight the analog cc section
3. press the right button to select off/cc1/cc2/cc3/cc4 (keep in mind closed caption for reg tv is usually cc1 or cc2)
digital:
1. Go to that handy setup menu again
2. Press the down button to highlight the digital cc selection
3. press the right button to select OFF or SERVICE 1 thru SERVICE 6 (any of these should work)
Dec 01, 2008 | Vizio Gallevia GV42LF 42 in. LCD...
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
436 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
