My speakers wont work
Ok, I got my new computer about a month ago It's great and all but my speakers just wont work. they are plugged in and It says the are working, but when I test them or try to play a video on Youtube.com it doesn't work.
Can you guys help me out?
  • 41 Answers
1. Check if its plugged into the right audio slot which is the green one on the mobo.
2. Check if its not on mute and or turned down on the volume master control which can be found in the control panel.
3. when you try to play and audio file does it give you a sound error?
Posted on Jul 24, 2008
2 days ago my speakers were working great then last night they just stopped working. they are plugged it but it says ''speakers unplugged'' ive checked andeverything is plugged in i dont know what to do
ok if you are on xp great if not you can still get there.
control panel
look for a speaker icon open it
where it says audio check to see if your sound card is defalt or not cahanfe it as you need to.
If his fails you may want to put in an external sound card (from ebay about 10 pounds.7 dollars)
Apr 05, 2011 | Computers & Internet
Speakers Plugged In Right But Wont Turn On??
If the power light on the speakers isn't on, then the power supply going to the speakers is either in a bad outlet (test the outlet with a voltage meter) or the plug isn't firmly seated. Best of luck in your new home and hope this solves your problem.
Greg
Jun 09, 2009 | Altec Lansing ADA 215 Computer Speakers
No sound from X-530 speakers
unless you are capable of replacing the jak on the speaker u need a new pair. the wiring functions the the jack which is now broken
Sep 30, 2008 | Logitech X-530 Computer Speakers
Right speaker doesnt have sound
1ST.-The right jack could be damaged!!
Usually, there is a [+} posaitve & [-] negative input\output to speaker connections. Not all [-]neg. is ground.Sometimes the [+] pos. is grounded. [The exception to the rule is that u SEE the black wire going to ground] the reason I am letting u know this is that u can test the INSIDES of the sound system.
If u can get inside of the unit. Cut the left speaker output [+] posative from both outputs. criss\cross wires.Place left speaker output to right speaker jack[ that does not work!!] & visa versa.If the [LEFT Output] stops working after u plug in the speakers,the internal RIGHT output is damaged. NEEDS TO BE TESTED
If nothing nothing changes.The left still works & the right still does not work, then it is the jack (shorted ?, opened internally ?)
Jun 11, 2008 | Logitech Z-2300 Computer Speakers
Soundsticks Sub
he has to configure his sound from internal speakers to the new configuration, via control panel. His speakers must be pluggen in when he does it
Mar 09, 2008 | Harman Kardon SoundSticks II Computer...
Speakers
Speaker issue desktop's only
1. Plug USB into USB port (any)
2. Plug Black speak cable into LIGH GREEN (NOT BLACK) connector
3. You will see a popup window - make sure it is on Front Speaker out
4. Click OK - you will a cartoon computer with speakers on either side -then click on one of the
speakers to test
5. if that does not work then follow this:
Reinstalling apps:
1. If in Windows - Start - Programs - Acer Empowering Technology - Acer E-recovery management -
click on Restore at bottom then "Reinstall apps and drivers" - look for hardware drivers that you
need. Click "install now"
Oct 05, 2007 | Acer 90.00012.30B Computer Speakers
Computer stopped recognizing the speakers
Check the sound card system Can your hear through headphones for example?
Nov 15, 2006 | Logitech X-230 Computer Speakers
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
