Question about Maytag Washing Machines
No matter what i do our clothes and washing machine always smell musty, is it our hard water?
    Genius:
  • 1,028 Answers
Have you tried filling tub with hot water and 2-3 cups CLOROX CHLORINE bleach and letting it wash a few min then letting set for 30-45 min ? bargain bleach tends not to be as strong as the old fashioned stuff also leave lid open as much as possible same applies if front load except wash door boot out inside inner lip.. roll back to clean with bleach solution
Posted on Jul 24, 2008
Washing machine smells musty
there is dirty water still in the m/c do a boil wash with nothing in it buy some nice smelling conditiner and poor some of that in it also this is a tip from my mam leave the door open when not in use to let the insides dry out
Aug 24, 2012 | Kenmore Washing Machines
I have never liked my lg and now it seems that
You might check the water inlet valve on the back of the machine where the water hooks up. There should be a blue plastic water valve. remove the water hose on both sides hot and cold. At the blue water inlet valve inside the connector there are small filtering screens (similar to an areator valve on your sink faucet) They may be clogged by sediment and this would cause your low water issue and possibly the smell. Simply pull out the screens with a pair of needle nosed pliers and replace. Hope this helped
Dave
Nov 05, 2009 | LG WM2016C
Musty smell in washer and clothes.water remains in rubber gasket
Two thing that you might try: Add two or three cups of bleach and have the machine run a cycle (with no clothes!!!). Second, always leave the door open after use to let it air out. Also, it wouldn't hurt to use straight bleach as a wipe to the entire rubber tub seal.
Jun 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Musty smell
Run your machine through its cycle with NO clothes and when it is filling up with water put bleach in the water. Put bleach in only at the start of cycle.
Before you do this clean all inside parts the best you can yes with bleach and you can run something like fleecy to make clothes soft and smell nice when you wash your clothes as well. Our machine has a special holder to put softener in.
Do NOT have clothes in when running the heavy bleach through it. This should kill the bacteria .
Aug 12, 2017 | Maytag ATW4475TQ Washer
1994 Kenmore 90 series washer smells musty
Do a boil wash without clothes & detergents, with a cup of bicarbonate of soda in the soap drawer.
Mar 30, 2009 | Kenmore Washing Machines
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front-load
you must remove bottom panel ,,in the center front you will find pump,,remove pump filter,,always unplug first..it has slugg,..than after you clean filter run your unit once a month with a pint of bleach and hot water only..also wipe your rubber gasket or bellows with a touch of bleach..
Dec 27, 2008 | Kenmore Elite 45986 Front Load Washer
Our Clothes smell musty and the washer smells too
clogged water screens , defective water level pressure switch , clogged drain, kinked drain hose ,. defective water pump , defective water tempeerture switch, damaged water valve solenoid , water inlet valve has an interal malfunction
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Musty smell, but can't tell from where
I have the same problem with a 3 month old ge front loading washer.after 1 month it started off smelling musty..I thought it was my imagination, now at 3 months old our clothes smell so bad I think we might just have to buy new clothes! everytime I wash a load the clothes smell worse and now you can even smell it just walking into our closet 2 floors up. A new washing washing machine should NOT be doing this! so far leaving the door open in between washes has helped a little but I plan on tipping it back and finding the hidden filter today. Isn't it lovely that they don't mention a filter that needs monthly cleaning or it's location in the manuals?!
Apr 25, 2008 | GE WBVH6240F Front Load Washer
Washing Machines Logo
81 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
