Question about Keurig Elite B40 Coffee Maker
CANNOT PRIME PUMP AFTER DESCALING - therefore CANNOT MAKE COFFEE
Per descale instructions, I followed instructions and descaled with vinegar - then let sit for 4 hours. Upon start up - pump will not prime - I have verified more than ample water in the reservoir. I've tried unplugging and let it sit for an hour. I've ensured the "handle" is lowered tight down to make contact - can't find a sensor anywhere in that area although I have tried cleaning the area thoroughly to remove minor coffee grind residue (film).
Red light next to "Heating" remains ON at all times - cannot get pump to prime and consequently cannot get EITHER small or large cup blue lights to illuminate. Unit is 4 months old and has performed flawlessly for 10 cups daily since March. I descaled 2 months ago with vinegar and everything returned as normal. Not this time. Stuck! Any suggestion? Many thanks, Bruce
  • Anonymous Mar 15, 2014
    followed the instructions using nespresso descaler now the lights just keep flashing and the coffee is luke warm and I can't seem to reset it
  • Anonymous Mar 20, 2014
    when you make 1 cup then it goes to the prime mode even when you follow instructions for fixing prime problem.
  • 2,039 Answers
First vinegar is not strong enought proper descaler for expresso machine and in our water container the hole in the bottom put water in the tank with a hoseor turkey juicer our anything you got push water in hole you need to pressurize to forse the pummp to trim itself hope it help fixya pierre
Posted on Jul 28, 2008
  • pierre laplante Jul 31, 2008
    it goes in the hole in the base and yes its a turkey blaster i use that term onse and the guy had no clue what i was taking about and sorry for the delay i was out for a few days thanks pierre
Reply from Bruce with the non-prime problem - The Keurig User Guide specifically prescribes the descale procedure as filling the water reservoir with pure white VInegar. Your message says Vinegar is not a strong enough descaler - what IS an appropriate liquid to DESCALE the Keurig B40 coffee maker?
With respect to your "hose or turkey juicer (do you mean turkey baster?) please advise if the turkey baster goes into the bottom of the water RESERVOIR or if the baster goes into the HOLE in the base of the Keurig? I will try this procedure once you clarify. Many thanx for your advice to PRESSURIZE the pump - that makes sense (reminds me of priming our well pump 5 decades ago!)
Bruce
Posted on Jul 29, 2008
Water temp and descaling lights flashing
you need to descale the machine as per instruction
Oct 15, 2012 | Solis Palazzo Espresso Machine
My keurig b60 says prime
This can go out by draw out some hot water. However if this happens very often then you need to perform a descale.The brewer should be descaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. Descaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend descaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The descaling process involves using 48 ounces of undiluted white vinegar. Learn how to descale your brewer.
Feb 24, 2012 | Keurig B60 Coffee Maker
How to clean the kitchenaid java express coffee maker
The Coffee Maker can be descaled using
a packaged descaling agent or vinegar.
Always mix the descaling solution using
cool water.
• When using a descaling agent, follow
the directions on the package for the
recommended amounts of descaling
agent and water to use.
• When using vinegar, fill the carafe with
a solution consisting of 1⁄2 vinegar and
1⁄2 water.
Descaling Steps:
1. Before descaling, always remove the
water filter (see “Installing the Ion-
Exchange Water Filter” on page 7) and
make sure the brew basket contains
no coffee or coffee filters.
2. Run the Coffee Maker through a
complete brewing cycle using a full
carafe of the descaling solution.
3. If the cleaning needed indicator lights
after the brewing cycle is complete,
repeat Step 2 using fresh descaling
solution. Keep repeating Step 2 until
the cleaning needed indicator no
longer lights after brewing.
4. Rinse the Coffee Maker by running
it through two brewing cycles using a
full carafe of fresh, cool water
each time.
5. Wash the brew basket in hot, soapy
water and rinse with hot water. This
part can also be washed in the upper
rack of the dishwasher.
6. Reinstall or replace the water filter.
Replace the filter every three months
under normal usage, or more often
with heavy use.
Mar 30, 2009 | KitchenAid JAVASTUDIO KCM534 14-Cup Coffee...
Red descale light is on
I use distilled white vinegar, but you can use specialized coffee cleaners with this model:
Descaling
Descaling 11
Descale your Tassimo machine every three months to keep it
operating at full potential.
Descaling products are widely available from stores selling coffeemakers and espresso
machines. Only use a product intended for descaling. Mix the descaling product
directly in the water container, following the instructions provided on the descaling
packaging. Replace the water container on the machine.
2 Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down,
and close the brew mechanism. When the AUTO light illuminates, press and release
the start/stop button. The brew cycle will fill the machine with descaling solution. Empty
the cup and let the machine stand for 15 minutes.
3 Open the brew mechanism and close it again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and release the start/stop button. When the
machine stops running, empty the cup, and let the machine stand for 15 minutes.
Repeat this step two more times for maximum descaling effectiveness. Discard the
remaining descaling agent from the water container, rinse it thoroughly and refill
with fresh, cold water.
4 Open and close the brew mechanism again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and hold the start/stop button to flush water
through the machine. The MANUAL light will flash. When the cup is full, release the
start/stop button, empty the cup, and replace it on the cup stand.
5 Repeat step 4, flushing clean water through the machine in the same manner and
emptying the cup as it fills. To ensure that all the descaling solution is completely rinsed
away, flush two full water containers through the machine before using it again.
Mar 26, 2009 | Braun Tassimo Coffee Maker
De Scaling instructions
Also, if you have an in sink garbage disposal, don't waste the hot vinegar.  Pour it into the disposal, turning the unit on as you pour, off when you're done.  The vinegar is mildly acidic and will disinfect the disposal unit.
Feb 17, 2009 | Keurig B60 Coffee Maker
Descaling problem
make sure the * is on the descaling line
Jan 25, 2009 | Miele CVA615 Espresso Machine
I want descalcificacian saeco easy sup 021ye what butons y press?
Warning! Never use vinegar as a descaling agent. You can use any commercially available non-toxic, non-harmful descaling product for coffee machines.
Descaling is necessary every 2 months; should water be very hard, descale the machine more frequently. The machine must be on; it automatically controls the distribution of the descaling solution.
  1. Switch off the machine.
  2. Fill the water tank with the descaling solution.
  3. Place a large receptacle beneath the steam tube.
  4. Switch on the machine.
  5. Open the knob.
    The descaling process starts.
  6. Dispense the descaling solution into the receptacle.
  7. After about 30 seconds close the knob.
  8. Switch off the machine and remove the receptacle.
  9. After 10 minutes, follow instructions 1 to 8 to the water tank is empty.
  10. Rinse out the tank and fill it with fresh drinking water.
  11. Place a large receptacle beneath the steam tube.
  12. Switch on the machine.
  13. Open the knob to rinse.
  14. If the receptacle fi lls, empty it.
  15. When no water is left, turn the knob to close the valve.
    Remove the container.
After descaling the machine, reload the machine circuit. Install the cartridge filter again in the water tank.
Jul 23, 2008 | Saeco Easy Espresso Machine
Tefal quick cup - descaling problem
Push red and black for 5 seconds to lunch descale then unit resets light at end oy cycle
Hampshireman
Feb 25, 2008 | Kitchen Appliances - Others
Keurig Elite B40 Coffee Maker Logo
3,007 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
