Question about Toshiba Office Equipment & Supplies
Toshiba TF 631 Copier
On the control panel show maintenance light on. after replaced the drum and cleaner blade, but the maintenance light does not off.
thank you for yours help
  • 1 more comment
  • wilyer Jul 24, 2008
    Thanks again, have a great night.
    Wilyer
  • wilyer Oct 01, 2008
    On the control panel show maintenance light on. after replaced the drum and cleaner blade, but the maintenance light does not off. Aditional the display show " printer disorder notify the serviceman "
    I have waiting for the help last 2 months
    tank you for yours help.
    Wilyer
  • wilyer Oct 21, 2008
    The display show disorder notify the serviceman
    Thank you
    President:
  • 2,072 Answers
I will look that up for you in the morning, There is simply a code that needs to be reset, I just have to be sure I tell you the right one.
Posted on Jul 24, 2008
Error code F 26-3 on Konica 7022
Sir/mam, you might have a bad drum density sensor or it was not cleaned or was destroyed by static electricity, if a vacuum cleaner was use to remove the old developer, NEVER use a vacuum cleaner for that procedure. Remove the drum and will see a small sensor near where the cleaning blade sits need to clean it replace it. Worse case the main control board is bad that what sensor talks to .Was the L Detect procedure run after the developer was replaced, and before you replaced the developer did you clear the developer counter, to let machine know it has new developer, because clearing the counter is the only way the copier has new developer, did you clear the counter for the new drum? The machine use the counters to determine voltages for certain assemblies. If L detect was not run and copies or prints where made get new developer and start over.
Jul 12, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Can a scratch be removed on the drum that gives a black line on the print. While cleaning the machine something touch the drum and created a line. TOSHIBA STUDIO 160
Hello
Unfortunately the scratch on the drum cannot be removed, as the drum is a organic material.
The drum and drum cleaning blade will have to be replaced.
Regards
May 09, 2011 | Toshiba e-Studio 161 Copier Copier
I replaced the drum and wiper blade and I need to clear the maintenance reminder on Toshiba eStudio 202L. I cant find the procedure in the service manual. Do you know which code will reset the...
switch off machine hold down 6 and print key switch on when the machine is on enter 2 and reset you counters switch off and wait 30 seconds and switch on again
Feb 11, 2011 | Toshiba e-Studio 202L Copier
Toshiba estudio 167 - time for maintanence appear so what can i do??
hi
you need to replace some parts on the copier (consumables)
KIT - 2340 Developer Maintenance Kit - Kit Includes: Drum Blade, Recovery Blade, ( 2 ) Drum Picker Finger, Main Charge Grid, Main Charge, ( 2 ) Transfer Separation Wire, Developer - Genuine Toshiba Part -- resells for about $240 , youc an buy this at any online store .. example , http://www.precisionroller.com/maintenance-kits-for-toshiba-e-studio-166/details_57969.html please rate me 4 thumbs up
Dec 29, 2010 | Toshiba E-Studio167 Copier
My e-studio 45 has 260,000 copies and says it needs maintenance. It works well. Do I just replace the drum or does it need other parts like a fuser too?
Hello sir; When it said need maintenance, it means need PM( periodical maintenance) that including drum, drum blade ,developer, corona wire, etc. the fuser and pressure roller depend on condition.
Feb 01, 2010 | Toshiba e-Studio 45 Black and White Copier
Sharp AR-M160 Maintenance light and developer replacement light have come on together. Where do I get developer from?
It's not developer light.
It is drum unit light and maintenance.
You have to replace the Drum, Blade and Developer.
After changing them you have to reset the maintenance, drum,developer counter.
This procedure must be made by a copier tech.
But if you still want only the developer the code is AR-202D
Dec 12, 2009 | Sharp AR-M160 Laser Printer
Toshiba 2860-changed Toner cartridge-black line on edge of copy
Hi there
send a print / copy through the machine stop the machine via the main switch before toe paper has come out remove the drum unit
you should now be able to see part of your print on the drum if you can also see the black line check for obstructions in the light path if these seem fine the chances are the dev or cleaner blade seals have spung a leak ( time to replace the drum cartridge
Regards Al "alstech"
May 26, 2009 | Toshiba 2860 Copier
Sharp AR-275 Copier
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
May 19, 2009 | Sharp AR-275 Copier
Toshiba 1360
Did you replace the cleanerblade?
Power off the machine, switch on while pressing 0 & 8, enter 200, then press the start button, the machine will run for about three minutes to adjust the Toner sensor. The machine will stop, press the interupt button to save the setting, switch off and then on.
If the older techies is reading this, please help to confirm.
May 09, 2008 | Toshiba 1360 Black and White Copier
119 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
