Question about Cameras
My camera's advance isn't working properly it doesn't move completely to the right the way it should to fully advance to the next frame (It is a manuel) an older camera. What can I do to fix this? It is a Minolta X9, Thank You.
  • 667 Answers
Sometimes there is an arm located in the bottom area of the camera that gets damaged. It is forked shaped on one end and lies below the coupler for a winding attachment. The other end of the arm attaches in the middle of the camera. You can remove the bottom cover on this camera fairly easily to have a look, you won't hurt anything.
Posted on Jul 24, 2008
How do i advance the film to the next frame in my Nikon N65
The Nikon N65 has a built-in film advance (power winder) so all you need to do is take a photo and it should advance. If no, the film isn't loaded properly or the drive is broken.
May 07, 2014 | Nikon N65 35mm SLR Camera
We have fully charged the battery but when we pull the paddle to move it doesn't go
Reengage the wheels again then give it a slit push you should fell some resistance .seems the freewheel is not fully in
Apr 24, 2013 | Electric Mobility Mobility Electric Power...
I have a porter cable roofing nailer model # RN175 that does not advance the nails everytime what causes this?
Some causes, in order of probability:
Roofing nailers get a lot of tar build up on them, especially around the nose safety and nail feed pawl area. Cleaning off this buildup will usually take care of most problems with roofing nailers.
On the side of the gun away from the side you load the nails on there is a small cylinder with a piston inside that attaches to the feeder pawl. If air isn't getting to the piston or the piston's o-ring or spring is damaged, it won't cycle properly to advance the nails.
If the driver doesn't retract fully, the next nail won't be able to advance properly for the next shot. This can be caused by o-rings in the head that are worn or out of their proper place.
Oct 06, 2012 | Air Tools & Compressors
I have a Nikon FM3 and the shutter opens at the correct speeds but when I put B&W film in it (Kodak TX 400) and develope the film, there is nothing on the film like it was brand new. Help please.
Check to make sure that the film is properly inserted into the take-up spool, and watch the rewind knob and make sure it is turning indicating that the film is going through the camera. Also check to make sure that the multi-exposure lever isn't stuck in the on position by spillage or impact so the camera just keeps taking exposure on one frame and the film doesn't move.
Sep 29, 2012 | Nikon F3 35mm Film Camera
I have a FOSSIL mens wristwatch model # AM3423. I recently had a watch repair person replace the battery. Battery type and charge confirmed. I received the watch used as a gift from a relative who was...
Quartz watches stop working most often for one of three reasons: (1) dead battery; (2) dirt in the gears blocking the train; and (3) a bad crystal. This is the order in which I typically troubleshoot watches.
If the watch isn't working after you change the battery, first check to see that the stem is fully pushed in. A watch movement can shift just enough inside the case that a stem sometimes looks pushed in, but isn't quite in far enough to re-engage the movement. Pull out and push in the stem a few times to see if that changes anything.
Next, assuming that the battery is indeed fine, look closely at the second hand. Is it moving at all, even a tiny bit? Hold the watch up to your ear. Is there any kind of "chunk" sound about once every second? If you can answer "yes" to either of these questions, a speck of dirt has gotten into the movement and is preventing the gears from moving freely. It doesn't take more than a a big spec of dust to cause this. Sometimes, advancing the time will move the gears enough to cause the dirt to fall out. Some watch repair places also have a special machine that spins the hands rapidly to blow out or compact any dirt in the train. It's usually not economically rational to have the movement professionally cleaned beyond this point.
Finally, if you don't hear anything coming from your watch, the battery is good, and the setting stem is pushed firmly and completely into the watch movement, you may have a bad quartz timing crystal. It does happen, and when it does, the only repair is to replace the entire watch movement. Sometimes, that's affordable; sometimes, it just doesn't make sense.
Sep 20, 2012 | Fossil AM3424 Wrist Watch
I purchased a Nikon N60 used. The film will not automatcally load therefore not shoot
Please follow these instructions: 1. Open the camera back 2. Pull the film leader across the red film index mark (red line) 3. Check to ensure film is properly positioned with no slack, then close camera back 4. Fully depress shutter release button to advance to frame 1. Check the rewind lever if it turns counter clockwise when you depress the shutter release button.
Keep on trying this procedure until you get it right. Most of the time, the error is in not pulling the film leader enough to reach the red film index mark.
If you're still having a problem with this, the next best option is to have the camera checked by a competent camera technician.
Mar 25, 2011 | Nikon N60 35mm SLR Camera
How do i get my advance lever to move it seems jammed
A Canon AE-1 is not an EOS camera the Canon "A" series is manual focus while EOS is auto focus. First thought In answer to the advance lever stuck or jammed I'm going to assume the camera is in serviceable condition and has not been subjected to water damage or harsh use. If we are dealing with just the advance lever then I'd say that you have over advanced the film at the last frame. I've done this myself after loading a 24 exposure and thinking I had a 36 exposure film. At the bottom of the camera there is a little pin which releases the advance lever and allows the user to rewind the film. Under normal conditions when it's time to rewind the film into the canister this pin offers little resistance to pushing in to release, however depending on how much force the advance lever has been subjected to increases the tension on this pin. Push the pin in and rewind the film.
Second thought is if you have film in the camera and it has not been used fully then it's possible that the film has already been advanced to a new frame and the shutter needs to be activated before the lever will become free and advance to the next frame.
Other problems with the Canon "A" series cameras is they have a tendency to dry out the lubrication and begin to squeak when the shutter is fired. This condition can eventually result is a shutter seizure and give the same advance lever condition.
Those are the three things that come to mind over this lever problem lets hope it's just run out of film.
Nov 20, 2010 | Canon EOS-AE-1 35mm SLR Camera
Hi, I was taking pictures with my camera and I turned the handle to get to the next picture and the button we press to open the shutter (capture the picture) I can push it but it wont click. Please tell me...
Sounds like the shutter has not fully cocked, which often happens when you get to the end of a film and the film advance won't move on a full frame. Try the film rewind crank(gently). If it is not able to turn either way, then you have used up a film and have to rewind it and remove it from the camera. You will then be able to advance the film wind lever to finish cocking the shutter and it will fire as normal.
Oct 18, 2010 | Nikon FE 35mm SLR Camera
Film not advancing fully
Are you sure that you have loaded the film properly?
Sometimes if you have not started the film so that the sprocket pulls the film correctly the film can aquire slack and the teeth of the sprocket may not be successfully pulling the film from the canister each time.
Sep 07, 2007 | Pentax ZX-50 35mm SLR Camera
Film Won't Advance After Shot is Taken
Do u want to move to the next frame without actually taking the snap?
Aug 29, 2007 | Bell & Howell PZ2000 35mm Point and Shoot...
Cameras Logo
37 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
