So has mine now but no body seems to answer your question, so is there a answer to the question and did anybody help youSo has mine now but no body seems to answer your question, so is there a answer to the question and did anybody help you
You can't post conmments that contain an email address.
Luxor is a budget brand made in Turkey for the Swedish market. You likely have failing components, probably electrolytic capacitors. You put the set on, they warm up and fail. They can be replaced but you are better to invest in a new set by one of the major makers like Samsung, Sony or LG. A quick search shows they have some history of faulting
There are a few potential reasons why your Luxor TV is not changing channels and some steps you can take to troubleshoot the issue.
Check the connection between the TV and the cable or satellite box to ensure that they are properly connected and not loose.
Check the input source on the TV to make sure it is set to the correct source (e.g. HDMI, cable, or antenna).
Check the settings on the cable or satellite box to ensure that it is set to the correct channel.
Check the remote control for your TV to ensure that the batteries are not dead, and that the remote is not too far away from the TV.
Check the TV settings to make sure that the channel auto-tuning feature is enabled.
Try unplugging the TV from the power source for a few minutes, then plug it back in to see if it resolves the problem.
If none of the above steps resolve the issue, it's likely that the problem is with the TV's tuner or a malfunctioning component, in this case, you may need to contact Luxor's customer service for further assistance or consider getting it repaired by a professional technician.
It's important to note that the troubleshooting process may vary depending on the specific model of your Luxor TV. If you are not comfortable working with electronic devices, it's best to contact a professional technician to diagnose and fix the issue.
what is a Luxor? posted to PC computers help. what OS does it run? XP, W10, android what? Lexor is a game, nah not that. I google to learn what it is and failing why? 1billion hits for a game (a game APP) are you in N.America or USA? and we have no LEXOR PCs here. Where in the world are you? many places no here have endless other names for things not here. this I know. if confused post photo of this Lexor or tell where you bought or tell or show the store where you bought and a URL link to this PC. if not a PC but is some TV then post to TELEVISION ahhhhhhh lots of hits for Television so is off topic here. and no model LuXOR told so answers will be wrong.(rear sticker label tells this)
vast old TV's can not run Netflix player at all now, its too old most old TV can not even upgrade it. unless is Android TV. based.(CASE BY CASE NO TV TOLD)
the easy cure is ROKU. box. added, for sure. cure 2 is go find Lexor web site tell them this and ask for update. now the diagnosis a TV has like 20 to 100 streaming players, not just netflix so if all Players fail that is a network (www internet) failure not related at all to NETFLIX, (sorry not them) lets lay real blame doing simple tests.
A TV MIGHT HAVE 2 CONNECTIONS, ETHERNET OR WIFI SO IF USING WIFI , DO ALL THING FAIL USING your wifi and Ethernet both? at home ( are you at home/)? if all things wifi fail then that is the problem wifi not LEXOR do tell and we can work that real problem.
The TV (television or tellie) has button called settings, set it to you choice of internet. 1: ethernet wired 2: wifi, using your SSID name and your wifi pass phase credentials. and not all player work if subscribed. a quick test is TUBI (free onces are best for testing) see/.
Since it has an internet connection, I'm sure you could buy a set of connectors that plug into a 110 outlet, one to the ethernet connection on the TV, one to a port on the router. Example:
Check the power supply for burned-out electrolytic capacitors. The power supply board has a two- or three-wire cable going to the power cord connector, possibly through a power filter module. The picture below shows burned-out capacitors with domed-up tops next to some that are good (the tops are flat). I recommend replacing bad capacitors with Panasonic FR-series parts; these have a good combination of power handling ability, longevity and price.
Failing capacitors will work for a while, but as the power quality deteriorates, it gets harder for the set to operate, just as you have observed. It is possible that there is another part with a thermal problem (quits working when it gets warm), but this is the most common failure mode.
I have a luxor 32in TV LUX0132009/01 model. It's been fine but now the volume symbol wont go off the screen which then stops the remote doing anything. Is there a way I can fix this myself? Thanks
I'm afraid if the power was lost during the update, the TV has a real software problem. But you don't have the tools to put in a complete set of new firmware. When the TV is still working, the processor and the program can manage the upload to the memory and after a restart everything should work fine. But no perfect firmware in the TV now that can do the upload rot the flash memory. A technician has to connect the TV to a computer and flash the firmware manually.
The best thing is to contact a certified service centre from luxor and ask them.
