Cd player stuck on pause
Player was left on pause and then shut down while still in pause mode. The player is now stuck on pause
  • 473 Answers
SOURCE: stuck in Play-Pause mode.
Simply press REC/PAUSE to return to normal Playback mode.
Posted on Sep 06, 2005
SOURCE: zen player stuck on -shutting down
Try to find a small hole with the text "Reset" next to it. Find something small(paper clip for instance) and simply just press the button inside the hole, you will hear a small "click".
Posted on Jan 26, 2009
smarthome2
  • 1114 Answers
SOURCE: alpine cdm 7861 stuck in pause mode
Check for a "jammed" button. They use a little rubber membrane behind buttons and over time they do wear out. It is possible to push a button on the corner, make it shift enough to jam behind the faceplate & hard to see. Just push the button and see if it pops back like the rest of the buttons on the unit. If it still has a problem, post a comment and I will help you some more. Hope this helps
Posted on Jun 23, 2009
  • 191 Answers
SOURCE: Sansa MP3 player stuck in pause mode
take apart and clean the contacts on the buttons
Posted on Aug 06, 2009
SOURCE: My mp3 player nwz-e436f is stuck in pause mode. Plus, it says no
i have just reset my mp3 and its fine now but it was also stuck couldnt turn on or charge
Posted on May 02, 2010
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
Tip
Voulme unlock for A1000 and A3000 Sony Walkman
So here you have it free information on unlocking the volume to your NW-A1000 and NW-A3000 this will allow you to have the maximum volume level for you to fully enjoy this product.
1. Press HOLD to put the player in hold mode.
2. Hold down LINK and press in order UP, DOWN, OPTION, UP, DOWN, RIGHT, LEFT, RIGHT, LEFT, LEFT, PLAY/PAUSE, OPTION.
3. Press HOLD to turn hold off. You will now be in test mode.
4. Press RIGHT to display menu items
5. Press UP/DOWN until you get to “OTHERS”
6. Press RIGHT to display next menu.
7. Press UP/DOWN until you get to “SP SET”
8. Press PLAY/PAUSE, “ON/OFF” is displayed.
9. Press OPTION, “ON/OFF” will be selected.
10. Press PLAY/PAUSE and it will be entered.
11. Exit play mode by pressing and holding BACK for more than a few seconds, release, and then turn the player off.
N.B> this is manufactures default to the lower level to save your ears perhaps to prevent a law suit, however I use mine on this max level and I can still hear my Wife nagging me !!!
LOL
on Sep 23, 2009 | Sony NW-A1000 MP3 Player
Pause/resume function in analogue, manual recording mode
This player has essentially the same guts as my Pioneer PDR-509, so this is what it means...
'Repair' means the player lost power in mid-recording without commiting the track memory to a table of contents. It would likely take up to 40 minutes for the player to reconstruct it from the disk.
There is NO reason the player need be turned off (if that's where it took you) for a track pause.
Just press Pause, flip the LP over and hit Play or Pause again when you wish to continue recording.
Perhaps you don't know how to Finalize the disc either. It's not that intuitive. Press Finalize, after a while it will display a time, like 4:07. That means how long it will take to do the operation. Now press Pause and it will count down to 0:00 and be done. Then you can play it on any other CD player.
Feb 14, 2010 | HHB 830 Plus CD Recorder CD Player
Sansa Clip 8GB is stuck in pause mode
You mean it hangs up at pause mode and you can't turn off you device? if so, push up/press power button and hold for 10 to 20 seconds until the device turn off.
Then, turn on. if it' working. You should update new firmware.
Good luck
Jan 17, 2010 | SanDisk Sansa Clip MP3 Player
Alpine cdm 7861 stuck in pause mode
Jun 22, 2009 | Alpine CDM-7861 CD Player
How do I shut off my zune!?!?
hi,
keep pressing the play button for 10seconds. it must shut off.
thanks you
Feb 08, 2009 | Microsoft Zune JS8-00001 Digital Media...
Hard disk prob
hard disk is bad.
can you format?
  1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
underneath your player, beside the data/power connector. Keep on holding the
Play/Pause button while you release the Reset button. The Rescue Mode screen will
then appear.
4. After the recovery mode has started, release the Play/Pause button
It will display the following options.
Clean Up Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Dec 04, 2007 | Creative Labs Zen Touch MP3 Player
CD player restarts cd from beginning each time
1) What year and model is it?
2) Probably not.
I have an Emerson from several years ago that I've taken all apart and put back together.  My guess is, unless it auto powers off when paused, or there's another button besides play/pause, stop, Back, forward, mode, prog, and antiskip, your problem is better-solved with an mp3 player. An ipod shuffle would do fine. The shuffle feature can be turned on or off, and one may jog without disturbing the electronics.
Nov 05, 2007 | Emerson (CKD2330) CD Player
Player stuck in scan mode
Hi...
Unplug it from the wall...give it a couple minutes. Try playing a CD again (using manual controls) If that works , your remote might be the issue.
If you bought the thing new you paid good $$ for it.
It's worth having it looked at by a Pro.
Oct 22, 2007 | NAD C521 CD Player
44 people viewed this question
 Grubhead
Grubhead
