Question about Dryers
GE Dryer Will not start
Hello I just bought an older gas GE clothes dryer from a yard sale. I got it all hooked up except for the exhaust duct. I turned it on just to test it and it started up and ran fine. Only ran it for a short amount of time (a few seconds) but there weren't any odd noises. I went and got the duct and put it on, added a load of clothes and then it wouldn't start. The electrical works since the I can hear the timer running but the "push to start" lever does not turn it on. I also checked inside the contols panel to see if a wire came loose but it all looked fine minus some cobwebs.
Any ideas or tips? The model number is DDG4580GDLWH.
Thanks,
Brian
  • level11 Jul 24, 2008
    It was the door switch! I took the wires off and taped them up with some electrical tape and it turned on. Is it fine to leave like that until I can get another switch or do you foresee any problems with that.
    Thank you!
    Genius:
  • 1,028 Answers
Possible door switch broke when uou shut it back also ck wiring diagram under console for thermal fuse in motor circuit
Posted on Jul 24, 2008
  • oldfixer Jul 26, 2008
    should be fine untill you open door while it's running and clothes fall out
I have a GE washer/dryer Model WSM2700RAWWH stack type and the dryer is taking very long time to dry the clothes. Please advise if it can be fixed. If not what will be best alternate washer/dryer stack...
first things first. if any dryer regardless of brand takes 2-3 hours to dry cloths 90% of the time it is your exhaust duct. take the exhaust duct off the back of the dryer and dry some clothes if the clothes dry fast then you need to have your exhaust duct cleaned. either DIY or call a professional
if it still takes a long time to dry then it could be the thermostats or the thermistor.
but in my experience its normally the exhaust duct.
Feb 10, 2011 | GE Washing Machines
I have a GE model # DCVH680EJOMS front end loading Dryer and it seems to take multiple cycles to get my clothes dry. I discovered that Water is collecting in the flexible exhaust tubing...not just a...
Hi and Welcome to FixYa. I am Kelly
You already have discovered the problem. Lint has built up in the vent / exhaust ducting. Most of the time the through the wall vent flapper gets lint build up on it outside the house and then as that restricts airflow you get condensation in the ducting. The condensation causes the lint to form a cake like paste inside the ducting. THOROUGHLY Clean out your vent ducting from the dryer connection all the way thru the outside wall and your dryer will be fine. If you need to replace the ducting please do so. Ducting is cheaper than the electricity you waste on clogged ducting. You proved your dryer will work correctly when you dried a load of clothes with the ducting removed.
Thanks for choosing FixYa
Kelly
Sep 27, 2010 | GE DCVH515EF Electric Dryer
Ge gas dryer doesnt dry, I have cleaned lint screen and ducting is clean and straight. clothes are damp after two hours run time, so the sensor seems to be okay or atleast it knows the clothes arent dry.
How old is this dryer? The older ones would do this when the vent was clogged with lint near the outside exhaust area, or if the belt is worn or stretched. (this allows too much heat inside the dryer at one time, and forces the unit to shut down to prevent a fire hazard)
Jun 22, 2010 | Dryers
DBV512gfoww dryer does not dry clothes completly on auto cycle. I have replaced both gas coils.
If the dryer is heating up, and clothes are being partially dried, then your dryer may be overheating. Check the ducts for lint balls / clogs, pay attention to the exterior opening, as well as the duct tube on the back of th e dryer itself. If everything appears normal / clear, you may have a limit switch that is acting up.
If the dryer is not heating up, then likely air movement (through ducts) is not high / fast enough to trigger that indicates that air flow is okay. Check all the duct work. If clear, then sensor / vane switch for air movement may not be closing like it should, which won't allow the igniter / gas valves to function.
Jun 11, 2010 | GE DBXR463GB Gas Dryer
Slow to dry
Hi!!
Have you cleaned the filter and the exhaust duct??
Lint plugs therm up, the heat sensor shuts off heating element thinking it is hot enough. Result: Clothes not getting dry.
Unplug duct and clean it, also clean the exahust passage of dryer. (where duct hooks to dryer)
Click below if this was helpful, Good luck.
Mar 28, 2010 | Dryers
Our GE gas dryer is burning clothes that are fleece fabric or blankets. Any suggestions?
I recently solved this problem on my ELECTRIC dryer by taking apart the lint collection area. Some dryers allow you to do this by removing a couple screws surrounding the lint screen holder. Others require some dis-assembly of the top and front panel.
Once you have access behind or below the lint screen, use your hands or a strong vacuum (shop-vac) to clean out any collected lint that has fallen below the collection screen and settled in the exhaust duct. I pulled out about 100 cubic inches (~1.6 liters) of collected lint, cat hair, and debris that was obstructing air flow.
Obstructed airflow can cause metal parts near the electric heating element to overheat and scorch clothing and is a serious fire hazard. I expect similar problems can occur with gas dryers.
Dec 28, 2009 | GE DBL333GB Gas Dryer
My dryer won't heat
is it a condenser or vented tumble dryer
Jun 28, 2009 | Dryers
Clothes not getting dried
Are you sure that the duct is clean and free flowing? If the duct is partially blocked the dryer's efficiency drops dramatically. I would double check the duct at both ends and clean out as required - air flow is very important - with the dryer on - go check the air coming out of he duct outside - if it is very forceful - then the problem is elsewhere - however if only a little bit of sir is coming out - your all plugged up!.
Nov 19, 2008 | Kenmore 63942 Dryer
Dryer takes more than one cycle to dry clothes
Did you clean the entire length of the vent ducting? Or, did you only clean the lint trap on the dryer and the exhaust vent outside? If you didn't clean the ducting as well, you may still have a clog somewhere causing your dryer to be "starved" for air. A dryer needs proper air flow to dry properly. One way to check is to turn the dryer on and go outside to the exhaust vent opening. Feel to see if you have sufficient air flow. If the air flow is weak, you have a clog. If not, you may have a high limit thermostat cutting off prematurely, not allowing the heating element to heat long enough. Check your ducting first and let me know if this helps.
Jul 28, 2007 | GE DBSR453EBWW Electric Dryer
Dryers Logo
185 people viewed this question
Top Dryers Experts
