I need a Versa Pak Interchangeable Battery System , where can I get one. Please replied. Thank You, Martha Echeverry
3 Suggested Answers
  • 77 Answers
SOURCE: Looking for powerpak
sorry but the only one i found was $129.99 and out of stock
Posted on Apr 05, 2008
ShatteredSun
  • 40 Answers
SOURCE: i have an old N64
If your Nintendo 64 console operates without error when the jumper pak is installed, but fails to function when the expansion pak is installed, by process of elimination this most likely means that the expansion pak you purchased is defective.
However, prior to purchasing another expansion pak (or attempting to exchange/get refunded for it), make sure the contact points on both the pak and the console slot are free of any dust, dirt, or other contaminants. Use a lint-free, dry cloth to do this. Water and/or cleaning products can further damage the system.
If, after cleaning the contacts, it still fails to function, seek an exchange or refund.
Posted on Mar 03, 2011
Pokemon stadium said that i need pak but i have one
Verify that only licensed accessories are being used with the system. Unlicensed products are not fully compatible with Nintendo systems, and may not work correctly.
Check the game pak manual or packaging to verify that the game is designed to be used with the N64 Transfer Pak.
Make sure the Game Boy game pak works properly in a Game Boy system. It may be a problem with the Game Boy game pak and not the Transfer Pak.
Verify that the game paks are inserted in both the control deck and the N64 Transfer Pak. If they are not, insert them and then turn the control deck power off and back on again.
Verify that the controller is plugged into the proper controller socket on the front of the control deck. If it is not, secure it and then press reset on your control deck.
Remove and re-insert the N64 Transfer Pak, making sure the pak is fully inserted into the bottom of the controller. If it is not, secure it and then press reset on the control deck.
If possible, try another controller. If the Transfer Pak works in another controller, it may be the controller that is having a problem. Check out controller troubleshooting (click here).
If the issue persists, the Transfer Pak may need to be replaced. For information on locating replacements for older products, please click here.
Jan 02, 2013 | Nintendo 64 Console
What does an expansion pack for the n64 do? what is its purpose? and are they interchangeable?
I will refer you to a page on Wikipedia that explains it -- but the simple explanation is that the Nintendo 64 Expansion Pack increases the RAM on the N64 from 4MB to 8MB. There were a few games with improved graphics and game play that REQUIRED the expansion pack.
Yes you can remove the Expansion Pak from one N64 and put it into another. However, your N64 will NOT work without either the Expansion Pak or the Jumper Pak in that slot. The original memory card that came in there was called the Jumper Pak which was 4MB. The Expansion Pak was 8MB.
http://en.wikipedia.org/wiki/Nintendo_64_accessories#Expansion_Pak
Jun 16, 2011 | Nintendo 64 Console
I have an old N64 and to play majora's mask it says i need an expansion pak so i ordered an expansion pak but when i replaced the jumper pak with the expansion pak the system still turns on but for some...
Mar 03, 2011 | Nintendo 64 Console
When we change games, we have trouble getting some of them to come on. if we switch the system on and off a few times, it will come on. sometimes it doesn't come on at all and we give up. is this the...
Nintendo 64 - Game Pak Troubleshooting
Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your game. Please check our game play help for assistance.
Insert the Game Pak into the system. The Game Pak label should be facing the front of the Nintendo 64.
Make sure the Game Pak firmly clicks down into place.
Remove all accessories (with the exception of the N64 Expansion Pak) to see if the Game Pak works correctly without the accessory. If the game does work correctly once the accessory is removed, then the game pak and the accessory may not be compatible. Check the game pak instruction manual.
Check the instruction manual for the game to see if it requires any special accessories, such as the Expansion Pak, to operate.
Check the list of specific game issues to see if there are any known problems for the game you are playing.
Due to the age of the system, we no longer offer factory repairs directly from Nintendo. Please click here to find out what options are available for repair or replacement of your product.
Feb 12, 2011 | Nintendo 64 Console
I have dell optiplex 755. I am unable to upgrade BIOS, BIOS is needs to be unlocked so I can upgrate BIOS to the latest. Please help.
Hi Martha,
If you need to unlock/reset bios password, here's what to do:
Unplug the pc and remove the cover. Look at the manboard (the big circuit board inside). look for a round silver button cell battery, about 1.5 centimeters wide. Remove the battery from it's socket and leave it out for 1 hour. Then put the battery back in the same way it came out. Plug in the pc and turn the power on. The bios is now cleared, and you can update it if you like. If this is not what you wanted, or you need more help, reply to me and I can help more.
Hope this helps!
Regards,
Joe
Jan 03, 2011 | Computers & Internet
What do you do when the controller turns off by itself while playing but still has full battery life (wireless)
Your product is not 'licensed by' it's system.There are no off brands which are 'licensed by' the major gaming systems which means that they are not able to be built with the exact specifications of the manufacturer due to patent laws.They would have to pay a fee to be able to make the exact specs.Things such as controller input size,voltages,and power requirements are not exactly what they need to be.Off brands like Mad Catz and Logitech have packaging which says 'licensed by Mad Catz' but means absolutely nothing and many times will cause problems.It is best to buy only name brands for your system or ones 'licensed by' your system but I worked on various systems for a few years and always watch for one,but have never seen one licensed correctly yet in 14 years.
That's all that is wrong.If you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.Good luck,Greg
Dec 08, 2010 | Microsoft Xbox 360 Console
Where is the cmos battery for an acer aspire 1690 laptop
CMOS is usally on the back side of the laptop. you might have to take the back panel off. The bios is flashed onto the board its really not a chip that is interchangeable it is just there to hold the info for your bios
Feb 12, 2009 | Acer TravelMate 2300 Notebook
Apr 04, 2008 | GoVideo DP8440 Portable DVD Player
Nintendo 64 expansion pak
Barb3: The Jumper Pack (JP) is a bypass for the expansion cartridge. You were supposed to turn off the equipment remove the JP and then use the expansion cartridge. Your N64 Ram it's probably gone for good. Is either replace the RAM, which is hard to find or replace the N64. Sorry for that.... SithPitt
Jul 03, 2007 | Nintendo 64 Console
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
