Question about Microsoft Xbox 360 Console
Xbox 360 black and white
Can somebody please help me? My 360 will not play in color on a color tv. Yes i've tried it on my other tvs and still the same thing has happened. I even tried switching the cables around and still all i get is black and white. Can somebody help me solve this problem or at least explain to me the problem.
  • 22 Answers
I would check to make sure your video settings aren't set to PAL-60 by mistake. It might be easier to resolve if you could let us know what leads you have and where you've plugged them in to.
Posted on Jul 24, 2008
Black and White signal could be caused by using an NTSC (i.e. American or similar) Xbox 360 on a PAL (i.e. Europe, Japan etc) TV. Unless the TV can support the type of signal it is very common to get what you describe. Are the TV and the Xbox 360 from the same region?
If you are using component cables - i.e. you have three cables - a red, a green and a blue end - if they are put into the TV the wrong way around you can get all sorts of funny colours - including black and white.
If you are using S-Video cables (so the end looks like a circle with a number of pins - no more than 9) then you may have the Xbox 360 set to output in a format the TV doesn't like - try setting the Xbox 360 to use the lowest format it will let you - i.e. not 720p or 1080i and normal not widescreen. If you're using a PAL Xbox 360 set to 50 hz.
If that fixes the problem then work up through the settings until you get the highest your TV supports.
If this info doesn't help then please post which country you are in (and which country the Xbox and TV were bought in, if different), the model of TV you're using and the kind of cable you are using - a description will be enough if you're not sure of the name!
I hope this helps,
Pal-60 won't dispaly a picture so ignore that ****
Posted on Jun 16, 2009
Screen is black and white but plays fine
try a different tv set as it could be setting on you tv which is causing the black and white.
Oct 30, 2009 | Microsoft Xbox 360 Console
Xbox 360 plays in black and white
Well, I have a couple of solutions that might work...
  1. Check your AV cables, it's possible that they could be the main problem (or try purchasing/borrowing a new cable to test with)
  2. Check your TV's settings, such as if it's NTSC or PAL (if the option exists) and it's colors.
If it's not the TV at all, then I'd say it's definitely #1 -- especially if it's a "Mad Katz" cable. Also, be sure that the AV cable is tight into the ports. One last suggestion would be to try a different TV. Hope this helps! Rob
Jan 09, 2009 | Microsoft Xbox 360 Console
Black lines on screen
try taking it off hdtv and putting it on tv using the yellow,red, and white cord If it doesn't work contact Contact me and i can probably solve it then
Dec 20, 2008 | Microsoft Xbox 360 Console
My 360 when i start up it does everything in black and white
You can send your broken xbox 360 to my shop Fixit repair service and I can send you a refurbished xbox 360 system for $80 and one year warranty here is the number 206-271-0529
Nov 08, 2008 | Microsoft Xbox 360 Console
XBOX 360 COLOR KEEPS GOING ON AND OFF
Nov 07, 2008 | Microsoft Xbox 360 Console
No Color
check the color and display settings on the 360 as well as the tv
Oct 24, 2008 | Microsoft Xbox 360 Console
No color on Sony TV, all other tvs are great
check the av cables in back of your tv and also check the wires connected up to the xbox 60 it's self
Sep 01, 2007 | Microsoft Xbox 360 Console
Black and white picture
do u have your 360 display settings at 60hz if so the tv might not be compatiable with a 60hz signel go to display setting and drop back to 50 hz and colour may show it self but remember some games wont play in 50hz if this is the case try find a ntsc to pal converter
May 07, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
274 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
