The router for my wireless is upstairs in my bedroom, which is fine if i want to sit in my room, and use my laptop. but if i try to connect in the living room, it doesn't pick up the network ???? I have the Acer aspire 5920. is there away around this ?????
    Sergeant:
  • 287 Answers
You can try a couple of things...
  1. get an external antenna to boost signal strength
  2. ensure you are not sharing a channel with someon else causing interferance and degrading your signal. download NETSTUMBLER and scan for vacant channels.
  3. ensure cordless phones are not near router antenna as they often share similar frequencies causing interference
  4. move router if possible to get a "clearer" path - try to put it somewhere that reduces the number of walls etc between it and where you want to work on the laptop
BTW - I have an external antenna and I cover my 3600 sqft house easily
Posted on Jul 25, 2008
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Router issues in my apartment.
When to moved into the penthouse, there are more walls between the wireless router and the laptop in the bedroom. The walls are probably reinforced concrete walls which will stop or weaken the radio waves penetrating into different rooms. When you lived in a house this was not a problem.
The only way to solve this problem is to move the wireless router near an opening such as a door and move the laptop as close as possible to the wireless router to get a better signal strength.
The outer way is to install a wireless repeater or connect a long network cable to the router and the laptop.
Jul 29, 2009 | D-Link Dlink DES-3028P Switch 24-port...
Connecting to a lapto
Hi rgf47331,
When you move upstairs there is a solid wall in between that interfears with the signals.The only thing you can try is calling up belikin and asking them to check your settings on the router and see if changing the mode or channel helps. i wont recommend you do that on your own as you may end losing the connection altogether.
I hope this helped
Keshey
Feb 16, 2009 | Belkin (F5D7230-4) Router (587009)
Wireless connection very low only on this laptop
Yes its the computer I have a 5100 with 512MB of Ram and constantly have problems with it.Are you using the internal wireless card? I recommend the Linksys Srx400
Also Try updating(flashing) the Bios here
Please rate this post....
Oct 05, 2008 | Dell Inspiron 5100 Laptop
Low signal from my wireless adaptor / router
Have you tried connecting the laptop in a different wireless network? Try changing the channel in your router and you may also upgrade the firmware of your router.
Oct 04, 2008 | NetGear WGR614 Wireless Router
Signal Problems
try to bring another laptop to the location where you are having problem and see if the other laptop will have the same problem. if thats the case the problem is with the router. You can try upgrading the router's firmware or change the wireless channel
Apr 21, 2008 | NetGear WGR614 Wireless Router
Wireless Router Range Problem
Have you tried switching channels in the router I have seen suggestions to use challen 1 or 11 instead of the often defaulted 6. You may have increased traffic from your neighbors and non-it devices like wireless phones.
Dec 21, 2007 | D-Link DI 514 Wireless Router (DI-514)
Can see my network but wont connect
Yes you may trying chaing the channel to 11, because i have hear that chaning the channel will resolve this problem
Oct 23, 2007 | Belkin (F5D9230-4) Wireless Router...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
