Gear Toshiba e-studio 45
Sorry, I forgot to tell what portion is the gear can be found. The gear that I was talking about is the small gear in the developer with 21 teeths. It has worn-out in a month time. Do you think there is a problem that causes it to worn-out easily.
We clean the parts where the corona wire is placed which is near the drum. It also have a screen which always darkens. If this portion darkens the copy will blacken also so what we do is to clean it from time to time.
Thanks for the help again.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
1-Can you turn the developper by hand? if no ther unit is starting to go bad, usually the bearings and seals need to be replaced ( I did it maybe three times and refused to ever do it again, they hardly ever work even when rebuilt, and very messy.
2- the recovery blade,( where excess toner is suppose to go, is failing)
Posted on Jul 24, 2008
My Toshiba e-studio 45 displays "close duplexer cover" and stops there. The cover sensor is fine. The circuit is open somewher-where?
Hello
I encountered the same problem a few years back, I found the power supply to be faulty.
You can try checking all the fuses on the power supply.
Sorry that is all i have at the moment.
I will see if i can download the pcboard repair manual.
Please let me know where i can email it to.
Regards
Apr 26, 2011 | Toshiba E-STUDIO 450 Copier
A new clutch was just put into my 1990 Honda Civic sedan. Right after, I noticed that I have to "shift" sooner from gear to gear than I previously did. For instance, where before I could wait...
Sounds like the clutch wasn't installed right. I think the pressure plate or clutch plate is slipping. Take it back as it should be covered under the workmanship portion of the warranty. When clutches are shipped, the pressure plate is machined and then coated with oil so it doesn't rust. Your installer may have forgot to take the oil off.
Dec 27, 2010 | 1990 Honda Civic
Does anyone know where can i get toshiba e-45 gear for the developing uniT?
I use Precisionroller.com
Here is a link that will list the eStudio 45 gears that they have including pictures.
http://www.precisionroller.com/search.php?q=estudio+45+gear
Good Luck and Thank You for using Fixya.
Sep 21, 2010 | Toshiba e-Studio 45 Black and White Copier
Toshiba estudio 3511 keeps giving error c360. I've checked the charger and the gears are messed with drive motor. Motor turns initially but gets to stopping point and gives error. Is there a charger...
At our repair shop we have begun to put a small (1/8" or so) washer in between the frame and the bracket the worm gear is attached to when we get this error intermittently. It seems to pull that worm gear closer to the main charge cleaner gear to give it better meshing. Hopefully this helps you!
May 27, 2010 | Toshiba E-Studio 3511 Color Copier
Scan Color document by Toshiba E-Studio 45
E-studio 45 or E4500 is a black and white copier. Hence, it can only scan original document to black and white only. There are some copiers which have the color scan capability but not this one.
Feb 03, 2010 | Toshiba e-Studio 45 Black and White Copier
Toshiba e-studio 45call for service 254292
Press "clear/stop" and "8". While holding this combination of keys down, an error code will be displayed....what code are you getting?
Sep 15, 2009 | Toshiba e-Studio 45 Black and White Copier
Admin Password
The master password for the Toshiba e-Studio 45 (using controller gl-1010) is 349845. Use a web browser to open the printer's built-in web access: TopAccess, and click the log-in link on the right hand side to use this password.
Jan 29, 2009 | Toshiba E-STUDIO 450 Copier
TOSHIBA E-STUDIO 45
U need to press clear+8 to check the error code...
Dec 07, 2008 | Toshiba e-Studio 350 Copier
Toshiba e-studio 45
sorry no manual, the seperation is the unit that is directly opposite the drum, it is a black unit with wires
Aug 09, 2008 | Office Equipment & Supplies
jasbo
jasbo
